Toyota Dual Transfer Case Cross Member and Mount - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 10-30-2007, 08:34 AM   #1 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Send a message via Yahoo to traxman25
When 4x Innovations set out to design a new transfer case cross member we knew it wouldn’t be easy. After talking to may wheelers like you found out what mattered the most. Based on this we came up with this gem. Your new custom built cross member is designed to be low profile, but strong, and protective. This tube cross member is built from 1.5x.120 tubing to provide a great low profile fit, and durability and features 4 hard frame mounting points to help stiffen up your underbelly. These mounting points also allow it to stretch it’s reach and cover the bottom of the fragile cast aluminum transfer case and transmission housings that tend to crack if they meet face to face with a rock or hard place.
To help keep everything tucked up nice and neat under your rig we designed this cross member to use a new heavy duty transmission mounting bracket. This bracket replaces the stock mount with a new unit that houses poly round bushings to help eliminate play in your drive train. No more ripping stock mounts apart! By replacing the stock mount we were able to nest the tubes and the mount, meaning no valuable underbelly real-estate is wasted. As always, the new mount and all high grade hardware is included.
This cross member will fit your 84-95 Toyota pick up or 4 Runner that is or has had a Solid Axle swap. The stock torsion bars and torsion bar mounts must be removed. Don’t forget that 4x Innovations builds parts for YOUR truck, so customization for body lifts, 0-3 inches, is available FREE of charge! You can also order your cross member to be built for a 10 degree clocked transfer case, or a standard case.
Cost is $230 for the cross member, all mounting plates, hardware, and the HD transfer case mount, in either clocked or non clocked versions. To order you can use the online shopping cart here, or contact us.
For those of you who already have a cross member, but keep ripping your stock mounts; we have a solution for that too! Our stock replacement heavy duty transmission/transfer case mounts are now available!
4x Innovations - Adam
Hardcore Toyota Rock Crawling Armor
1-608-348-4880
traxman25 is offline   Reply With Quote
Old 12-06-2007, 06:14 PM   #2 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Don't forget we build these to custom fit your rig! Included is adjustments for clocked/non clocked t-cases AND we'll build it to fit perfect with your body lift for free! Not to mention the full transmission/tcase protection and HD mounting technology!
1-608-348-4880
Old 12-09-2007, 08:37 AM   #3 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
can you sell me just the plate youve had bent with the holes for the t case mount?(i dont need the poly bushings and tube)....thanks!
Amongst the best of the toyota vendors:
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is offline   Reply With Quote
Old 12-09-2007, 12:28 PM   #4 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
not at this time.
1-608-348-4880
Old 01-15-2008, 03:57 PM   #5 (permalink)
Member # 9001
Send a message via ICQ to Lord Orange Send a message via AIM to Lord Orange Send a message via Yahoo to Lord Orange
I ordered mine, just not a double case thou! Thanks Adam.
[URL="http://www.pirate4x4.com/forum/showthread.php?t=530797"]Don't be the nice guy anymore[/URL]
Lord Orange is offline   Reply With Quote
Old 01-28-2008, 05:49 PM   #6 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Thanks for the Order Lord Orange! It's gonna be a great addition to the buggie!
1-608-348-4880
Old 04-13-2008, 06:11 PM   #7 (permalink)
TacoRunner's Avatar
Member # 31873
Hey Adam can I get a price for the crossmember and shock hoops and S/h to 30134. The cage I got from You is doing great when the top come off in a couple weeks it will get a new paint job.
King James
TacoRunner is offline   Reply With Quote
Old 04-14-2008, 08:38 AM   #8 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
TacoRunner,
I sent you an email and PM, Thanks!
1-608-348-4880
Old 05-05-2008, 03:12 PM   #9 (permalink)
Member # 22519
Send a message via AIM to werty
Will your cross member work with a 700r4 with duals? Im a 1/2'' away from stock mounting on the first t-case.
84, 4 seater, dove nosed, cut excab, 4.3l-36s= not so slow, Locked front and Rear FOR SALE!!!!
[url]http://pirate4x4.com/forum/showthread.php?t=743586[/url]
[QUOTE=ev13wt;9871460]Bad time to post nips?[/QUOTE]
werty is offline   Reply With Quote
Old 05-05-2008, 04:58 PM   #10 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
werty, the 1/2" would not be a problem but the shape of the 700r4 most likely will be. If you can give me a call we can chat about it some.
1-608-348-4880
Old 07-25-2008, 08:08 AM   #11 (permalink)
Member # 43236
i have an 81 toyota with 87 transmition and duel top shift cases and i was wondering if that crossmember would work. i dont see why not but thought i would ask anyways. thanks
rObbsTOY is offline   Reply With Quote
Old 09-28-2008, 09:47 AM   #12 (permalink)
NE-89-4Runner's Avatar
Member # 87247
looking for a price for a clocked crossmember shipped to 02871? got any more pics of a clocked adapter installed, I keep seeing the same 3 pics...looking for some side views
NE-89-4Runner is offline   Reply With Quote
Old 09-28-2008, 10:11 AM   #13 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
PM sent, thanks!
1-608-348-4880
Old 11-11-2008, 06:32 PM   #14 (permalink)
Member # 28033
Send a message via AIM to SkimtheYotaHead
How about a side pic showing how much below the frame the cross member sits.
85 Long Bed SR5
SkimtheYotaHead is offline   Reply With Quote
Old 11-11-2008, 06:34 PM   #15 (permalink)
Member # 28033
Is there a skid plate that is included ?
85 Long Bed SR5
Old 12-17-2008, 05:33 PM   #16 (permalink)
POWERSTROKEN's Avatar
Member # 40246
Send a message via AIM to POWERSTROKEN Send a message via Yahoo to POWERSTROKEN
I am in need of a mount for a dual Toy case set up rotated 10 degrees. It is for use in a 98 Chevy 4 door Tracker. Can you make something somewhat universal? It be nice if it had a skid plate also. Thanks Jim
[SIZE="3"]"Don't RAM it...STROKE it" [COLOR="DarkRed"] Family Krawler 98 4 door Tracker in the works CPI 4.3, 700R4, MC Dual Ultimate Toy's, Rockwell's, Fox air shocks[/COLOR] [COLOR="Navy"]2000 E350 4x4 7.3 Powerstroke D60/D70 35" IROK's on 20" Trail Ready's, Powershot 2000, Edge Evolution programer [/COLOR] [/SIZE]
POWERSTROKEN is offline   Reply With Quote
Old 03-08-2009, 10:20 AM   #17 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
btt!
1-608-348-4880
Old 03-11-2009, 06:19 PM   #18 (permalink)
Member # 70681
Bump for a nice design! I was thinking of fabing something similar, but I might have to save myself some time at that price.
Some people are like a Slinky-not really good for anything, but you still can't help but smile when you shove them down the stairs.
Bigredwelder is offline   Reply With Quote
Old 03-24-2009, 08:06 AM   #19 (permalink)
Member # 89058
Hey Adam, I sent you a email or PM (can't remember) about a week or so ago and have not heard back from you yet. Shoot me a PM if you didn't get it.
nissanclay is offline   Reply With Quote
Old 03-24-2009, 08:19 AM   #20 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Please resend, apparently I did not get whatever you sent.
1-608-348-4880
Old 05-31-2009, 04:07 PM   #21 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Here's a pic sent to us by Gassman4x4 here on Pirate. Thanks for the pic, looks good!
1-608-348-4880
Old 06-10-2009, 01:08 PM   #22 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Back to the top!
1-608-348-4880
Old 07-07-2009, 09:23 AM   #23 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Thanks for the orders!
1-608-348-4880
Old 07-28-2009, 06:31 AM   #24 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Top for great cross members!
1-608-348-4880
Old 08-13-2009, 06:53 AM   #25 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Check out these great cross members!
1-608-348-4880
