Dana 60 flange for 1410 finally! 38 degree's too - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 11-08-2007, 04:53 PM   #1 (permalink)
onetoncv's Avatar
Member # 2160
here's the first conversion for a dana 60 to a pinion flange for 1410 series - ironically My own truck needed - you could have with this shaft 42 degree's max off the t-case and 38 operation off the diff- This will be sold with the driveline (a long slip) due to the way its made- And add 189.00 to the cost of the shaft- Then you will need the flange for the 60- This is a good thing because yokes are not happy with the rocks usually- Its a 6 bolt flange by the way- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 11-08-2007, 05:01 PM   #2 (permalink)
onetoncv's Avatar
Member # 2160
And a better close up- the bolts are shielded by the flange- So the rocks don't get to eat them-Jess
530-877-2875
Old 12-23-2007, 09:36 PM   #3 (permalink)
Member # 17953
Hey Jess,
I'm running reworked, rockwell driveshafts with 1410 joints to standard yokes front and rear. I have the slips mounted at the t-case. They are well protected up there and are fine on a trail-only rig.
I do have a problem with bashing up the yokes at the diffs though.
What would I need from you to convert to the flange style mounting to get rid of the yokes?
Costs?
How much length would be added to each driveline?
Thanks in advance.
Adamik Offroad, DIY4X, Jantz4X4, Marco Customs, Milky4X4, PitBull, Popz Fab, Shagz Offroad, SMW
thebigdaddyof2 is offline   Reply With Quote Quick reply to this message
Old 12-30-2007, 08:50 PM   #4 (permalink)
onetoncv's Avatar
Member # 2160
Sorry for the delay- It was nutz around the holiday- You would have to convert to the flange -as for the cost it would be best to call- Jess
530-877-2875
