The BlackBox Planetary GearBox - Page 9 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 01-24-2012, 10:08 AM   #201 (permalink)
NorthWestFab's Avatar
Member # 40695
Originally Posted by bronco69 View Post
Question about NV4500/RockTrac setup sent via PM.
Thanks!
PM Sent!
The Little BIG Guys.
250-248-6024
www.NorthWestFab.com
NorthWestFab is offline   Reply With Quote
Old 01-30-2012, 03:41 PM   #202 (permalink)
Member # 88325
I went to your website and saw you have an integrated version.... whats the skinny on that?
cruisertime is offline   Reply With Quote
Old 01-31-2012, 09:15 AM   #203 (permalink)
Member # 40695
Basically uses the same internals as the Standard BlackBox, but instead of the output shaft of the BB sliding into the Input of the transfer case the output of the BlackBox-i is the Transfercases Input. It will only work with Dana 300, Bronco D20, Stak or Atlas II.
Kris
250-248-6024
Old 02-04-2012, 08:28 AM   #204 (permalink)
Member # 155973
Price on 32 spline black box to go in between 4L80E and 241. Shipped to 89444.Thanks
Neventy is offline   Reply With Quote
Old 02-06-2012, 11:53 AM   #205 (permalink)
Member # 40695
PM Sent!
250-248-6024
Old 02-10-2012, 12:49 PM   #206 (permalink)
Member # 210445
Kris I guess I just missed that sale, thanks for getting my box shipped out, going thru customs now. Cant wait to get that blackbox-i infornt of the dana 300 & behind my new SM465 in the Jeep.
Thanks,
David
crawlin CJ7 is offline   Reply With Quote
Old 02-17-2012, 12:21 AM   #207 (permalink)
Member # 989
Send a message via MSN to cobyhughey Send a message via Skype™ to cobyhughey
Need price and more importantly, ETA, for a blackbox i to go between 4l80e and an atlas II 3.8, shipped to 80524. Can you get one here quickly?
Coby Hughey
I did it like this, I did it like that, I did it with a whiffle ball bat
cobyhughey is offline   Reply With Quote
Old 02-17-2012, 10:15 AM   #208 (permalink)
Member # 40695
PM Sent!
250-248-6024
Old 02-24-2012, 07:49 PM   #209 (permalink)
Member # 183431
looking for a price quote on a blackbox sent to 32801. I keep going back and forth between a Blackbox and an np203 doulber or a Klune. This is going between a Ford C6 and np205.
Bo
bofer is offline   Reply With Quote
Old 02-29-2012, 08:49 AM   #210 (permalink)
jopickens's Avatar
Member # 126456
Taking the plunge... hope the prices are good!
Quote on a *woops!* for use in front of a nv241D and behind an a518 to 26330!
jopickens is offline   Reply With Quote
Old 02-29-2012, 09:13 AM   #211 (permalink)
Member # 40695
Bo
PM Sent!
250-248-6024
Old 02-29-2012, 09:40 AM   #212 (permalink)
Member # 40695
Quote on a goliath for use in front of a nv241D and behind an a518 to 26330!
PM Sent!
250-248-6024
Old 03-02-2012, 08:43 AM   #213 (permalink)
Lost One's Avatar
Member # 935
Could I get a quote for a 32 spline input BlackBox-i to D300 and TH400 to D300 adapter (BA-400-SAL3) shipped to 80122 please? Also, does your triple stick shifter work with a D300 and if so a quote on that as well?
06 LJ with stuff
72 J2000
89 Grand Wagoneer
“You have enemies? Good. That means you've stood up for something, sometime in your life.”
-Winston Churchill
"Just because I don't care doesn't mean I don't understand."
-Homer Simpson
Lost One is offline   Reply With Quote
Old 03-02-2012, 10:28 AM   #214 (permalink)
Member # 40695
PM Sent!
250-248-6024
Old 03-05-2012, 09:52 PM   #215 (permalink)
wide fucking open
mitchm's Avatar
Member # 158596
Send a message via Yahoo to mitchm
could i get a quote th 350 to 205 shiped to 99692 thanks
73 gmc crew cab on 41 inch iroks 56's in front with d 60 with wfo hd springless arms x-over hydro assist high steer with tie rod behind axle 14 bolt with disk brakes inborded 63's in rear 4 foot bed
mitchm is offline   Reply With Quote
Old 03-06-2012, 11:08 AM   #216 (permalink)
Member # 40695
PM Sent!
250-248-6024
Old 03-06-2012, 02:30 PM   #217 (permalink)
MtnYota's Avatar
Member # 83913
Quote for blackbox between GM NV4500 and 32 short spline GM NP205 shipped to 95018
'85 Xtra Cab 3rz,Duals, D60/14b, Detroit front/rear, 35spline chromos,rears/chevys, bad temper
MtnYota is offline   Reply With Quote
Old 03-11-2012, 07:55 PM   #218 (permalink)
mj
Member # 1919
pricing to change my BB from 31 spline input to 32 spine input for a th400, and maybe some info on how short can we get a th400/BB
mj is offline   Reply With Quote
Old 03-12-2012, 10:13 AM   #219 (permalink)
Member # 40695
PM's Sent!
250-248-6024
Old 04-02-2012, 07:50 AM   #220 (permalink)
Member # 162087
Quote for a blackbox-i between a 4l60E and a dana 300 to 84065? Also, price on the triple shifter?
Any other adapters needed for this setup? ...do you offer any type of VSS integration?
Thanks!
jeepin4x4james is offline   Reply With Quote
Old 05-07-2012, 02:12 AM   #221 (permalink)
Member # 218227
hi mate, glad to see your product is selling well.
Just a quick question. On your web page you have 2 versions, one called blackbox integrated. I note it is smaller in size.
Why wouldnt you use that one instead of the longer one, thus saving some lenght ?? cheers
Valian is offline   Reply With Quote
Old 05-07-2012, 09:24 AM   #222 (permalink)
Member # 40695
The only way to make the BlackBox shorter would be remove the rear bearing saving about an inch of length. In our opinion it is not worth it.
Most guys running the BlackBox to a transfer case that cant be integrated are running full size trucks where driveline length is not an issue and the BlackBox usually helps these guys with front driveshaft angles.
If you are worried about length run a BlackBox-i/D300, Atlas, or Bronco D20
Kris
250-248-6024
Old 05-07-2012, 02:40 PM   #223 (permalink)
Member # 218227
Hi Kris, thanks for you reply.
Does the Blackbox-i have the same spline count as the bigger unit, ie 23 spline input & output?
cheers
Old 05-07-2012, 02:52 PM   #224 (permalink)
Member # 40695
cheers
No, the i comes with the shaft thats suited for the t-case example, Bronco D20 has a 6 Spline gear, New Atlas has a 32 spline gear.
I could put any Output shaft we carry in the back of it but it wont solve the t-case input issue
Kris
250-248-6024
Old 05-08-2012, 01:00 AM   #225 (permalink)
Member # 218227
Kris, thanks again.
The reason i ask is that i have a non standard application in mind but could be limited by space, hence my interest in the smaller unit. I think the larger unit might be a tad too long. There is a dirty big crossmember in the way.
I want to run the unit in the Mitsubishi Pajero Gen 2 circa late 90's.
The Pajero of that era has the Aisin AW 30-43LE automatic transmission , similar to what some jeeps ran as well. The tranny has an output shaft with 23 splines mated to the transfer case. One clever guy from the US has actually made a doubler using 2 NP231's mated together & mounted to the transmission with a custom adaptor. He had a few hassles with speedo as the VSs for the Paj comes of the transfer case. Custom drive shafts were needed as well.
I want to keep the pajero case as it allows the vehicle to be used 4x4 fulltime & can be shifted to 4x4 at speeds up to 100kph. I run the Paj in 4x4 mode all the time, even on the highway. it has a centre diff in the case that allows this. Other modes are 4x4 with locked centre diff & 4x4 Low with locked centre.
The Paj case has a low of only 1.90 so low is around 25:1 , not very good I am sure you will say, but actually good in some applications. There are 3.14 reduction gears made in Aus & I have a set fitted. This brings the low down to 40.1, a bit more useable.
Your unit would give me 113.1 , way more than I want so i would probably take out the 3.15s & put the 1.90 back in, giving me 68.1.
I am not into rock crawling but do use the vehicle extensively around my property. I find the current reduction gears not low enough (when I need deep gearing) although they are a big improvement over standard. With your unit I could have standard low 25.1 and deep low 68.1 which would be ideal.
Anyway now that you know my application, i need to know whats possible.
Can the smaller unit be fitted with an output shaft of 23 splines similar to that of the larger unit?? I would hope to get 2 adaptors made up here locally that will allow your unit to be put in between the tranny & the existing transfere case.
Sorry about the long post, & I do appreciate your time, cheers.
