NP231 Planetary crawlbox (box4rocks)$499 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 07-05-2008, 03:46 PM   #1 (permalink)
Member # 11168
Send a message via Yahoo to d.d.machine
This is a simple kit that takes a np231 Transfer case and makes a low cost crawl box out of it, It uses the front half of a NP231 case that you provide and in about a hour or so of work you can have a crawl box that will lower your gearing by 2.73 to 1 ...
Just take a 231 case with the right input spline count to fit your trans output
(21 or 23 spline for the jeep guys) and (27 spline for the GM guys) and pull it apart , lay the big plate on the front casting and mark it about 1/2 inch "PAST" the left edge of the plate and cut it there, then file or grind the block off plate that comes in the kit to fit where you cut it off. Next tig weld the block off plate to the front casting, And thats it!
Its just that simple to make a crawl box ( doubler ) out of a np-231
All of the parts are made in house on CNC equipment
The plates are made from 6061-T6 alum and we make all are shafts out of 4340 cromo steel then through harden them.
What sets us above the other kits?
Simple
We offer clocking every 6 degrees meaning 60 clocking positions
(they offer 3 positions)
We are the leader in sales and support with more than 500 kits sold to date.
( they`re at about 25 ) We have shipped more in a single day than they have "EVER" shipped
We offer mid shafts in 21,23,27,31 and 32 spline
(They offer 23 spline only )
We offer two oil drains and a fill hole. so even if you flip the crawl box you can still fill and drain it
( they offer "NO" way to fill or drain the box)
We offer a "full" kit
we ship you the block off plate and the shifter rod you will need.
(They don`t only not provide them they want you to gap the 8" where the block off plate goes with out any bolts to seal it) just asking for a leak and a burned up gearbox
Here at D.D.Machine we do all the work in house on our equipment, We have been splining shafts longer than
the other guy has been alive. the other guy jobs his parts out to other shops. so what that means to you is simple ( We have a huge investment in our equipment and our products ) we`re not some part time side hobby.
We are there to support you before and a long after the sale.
There $499 and a set $15 shipping in the US
We keep a good stock on the shelf and ship orders 2 or 3 times a week.
Thanks
Duffy
D.D.Machine
(360)649-4465
we do paypal ( 4x4machine@gmail.com
or visa / mastercard direct
d.d.machine is offline   Reply With Quote Quick reply to this message
Old 07-08-2008, 09:34 PM   #2 (permalink)
Member # 77824
Hay Duffy welcome back to pirate . Your shit kicks ass .did you get your new shop going ? thanks jeff
jeffs350jeep is offline   Reply With Quote Quick reply to this message
Old 07-13-2008, 12:26 PM   #3 (permalink)
Mac5005's Avatar
Member # 92932
Thats for a great purchase Duffy, Everything went together well. I would recommend Duffy to anyone. Quality and Service were top notch.
Mac5005 is offline   Reply With Quote Quick reply to this message
Old 07-15-2008, 11:47 AM   #4 (permalink)
charlieboyd65's Avatar
Member # 31211
Duffy, would you please list the overall length of the 231/300 setup compared to the stock 231 w/ original slip yoke? I would appreciate it. Also, IIRC you sell a kit for shifters for a flipped D300. Do these shifters work with the doubler kit?
Thanks,
Charlie
charlieboyd65 is offline   Reply With Quote Quick reply to this message
Old 07-15-2008, 01:59 PM   #5 (permalink)
Member # 11168
the 231 crawl box and a D300 comes to the same length as a "stock" 231 with the slip yoke. I have has some guys say its 1/4" shorter and others say it 1/4" longer . Lets face it its a slip yoke were you slide it to well change.
As for the D300 flip sticks I make there for this crawl box setup. Well a lot of guys just run a flipped Dana 300 with out the crawl box and they work and fit up for that setup to.
Thanks
Duffy
D.D.Machine
(360)649-4465
Old 07-16-2008, 11:09 AM   #6 (permalink)
Member # 32464
hey duffy,
how about my chevy to chevy ring.
I did not know you were back on Pirate or I would have posted this sooner.
Kevin from Kansas,
still waiting.
Oh! tried calling like you asked me to and didn't even get a machine?
jkh533 is offline   Reply With Quote Quick reply to this message
Old 07-18-2008, 11:34 AM   #7 (permalink)
Member # 85028
Got mine yesterday!! Can't wait to hook it all up.. Thanks for an easy purchase Duffy..
92orangeyj is offline   Reply With Quote Quick reply to this message
Old 07-24-2008, 11:42 PM   #8 (permalink)
Member # 77971
Duffy, work in NP241D+dana300?
Regards
NIDERHAUSER is offline   Reply With Quote Quick reply to this message
Old 07-25-2008, 10:06 AM   #9 (permalink)
Member # 11168
I do have a few np-241 "GM" drivers drop kits left, if your dodge 241 is a drivers drop I would think its the same kit.
Thanks
Duffy
D.D.Machine
(360)649-4465
Old 08-02-2008, 12:36 AM   #10 (permalink)
Member # 44659
I am interested in a 241 Driver drop kit with a 32 spline shaft, is the cost still the same?
I am going to be bolting a 6 bolt 205 to it, I know I will have to customize some things, like new shift rails for rear shift, any other suggestions you have?
Thanks Duffy!
88K5 14b/d60 Self destruct mode switched to on! 97 Xcab Dodge crawler in the works. 77fj40/94fzj80
lumpdog is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 10:40 AM   #11 (permalink)
Member # 55165
Send a message via AIM to AQHACowboy
Duffy,
What do you suggest for a support for the crawl box combo?
AQHACowboy is offline   Reply With Quote Quick reply to this message
Old 08-03-2008, 12:24 PM   #12 (permalink)
Member # 11168
Lumpdog
I still have a few of the 241 drivers drop setups in stock. There the same as the 231 only the big plate is larger. and I have a few 32 spline shafts on the shelf to go with them.
All you have to do is bore the back side of the "rear" shifter rail for a seal and make a new shiter shaft out of 3/4" drill rod. I have been using W1 steel
it runs about $20 for a 3 foot chunk,
I well sell of the last few 241 kits I have on the shelf for $475 + $15 shipping
cowboy
I don`t know what setup your looking at 231-231 or a 231-D300 setup
but 90% of the guys run a D300 setup flipped or non flipped.
What I have done and it works out great is build a plate that comes of the back side of the D300 thats hooked to the front output steel cover and to a couple of the bolts on the rear tail housing then put a plate under the crawl box up to the stock tail housing mount.
then just run a mid 70`s GM np-203 stockT case mount under it to a X member
( The trick with T case mounts is to remimber that when you stick torque
to the rig it trys to push the T case thrue the floor)
so run a simple strap over the T case to keep it from pulling the mount apart.
Thanks
Duffy
D.D.Machine
(360)649-4465
Old 08-03-2008, 10:46 PM   #13 (permalink)
Member # 44659
Duffy, thanks a lot for the info, I am definitely going to want one!
Old 08-04-2008, 02:19 AM   #14 (permalink)
Member # 55165
Duffy,
Sorry I was talking about the 231/300 combo. Thank you for the info it helps a lot.
Old 08-06-2008, 09:41 AM   #15 (permalink)
Member # 44659
Sent a PM your way Duffy the other day, did you get it?
Old 08-09-2008, 10:21 PM   #16 (permalink)
Member # 103598
Has anyone found a way, ever thought of or figured on putting a Dana 18 transfer case behind one of these? *scratching my head - smoke coming out my ears* I really need a double offset transfer case (both outputs front and rear offset to the pass side) --- unless some one has a way to convert a Dana 300 to dual offset!
Doug
"DD" I sent you an email via the Fleabay auction......
Roving Beetle is offline   Reply With Quote Quick reply to this message
Old 08-11-2008, 10:00 AM   #17 (permalink)
Member # 11168
Doug
There is no simple way to run a D18 /D20 type T case with this setup do to the input gear is held by the output shaft of the trans or the tail housing with that T case setup.
h some screwing around I think one could use a tailhousing off a TH400 to D20 setup and make there "OWN" adapter to go to the big plate.
I do stock the 32 spline shafts that you would need to go from the crawlbox to the th400 tailhousing.
The TH400/ D20 was used in a ton of the 1970`s Waggys.
Thanks
Duffy
Old 08-14-2008, 03:44 PM   #18 (permalink)
Member # 11168
We have over 50 kits on the shelf ready to ship and over 100 shafts in stock
Please feel free to call my cell # at (360)649-4465 if you have any questions or need to order a kit.
We take paypal ( 4x4machine@gmail.com )
or visa / mastercard over the phone.
Thanks
Duffy
D.D.Machine
Old 08-27-2008, 11:11 PM   #19 (permalink)
Member # 77971
Thanks
Duffy
D.D.Machine
(360)649-4465
Hi Duffy
is right side or copilot, my dodge truck with 5.9 V8 A518 + NP241
for the right side do not make?
Regards
Old 08-30-2008, 12:04 PM   #20 (permalink)
Member # 11168
the few 241 kits I have left are for a drivers drop 241 case, I don`t know It one can just flip them over and tap out the oil holes from the other side to use with a pass drop 241 case or not.
but finding a used driverd drop 241 case should be easy and cheap.
Thanks
Duffy
Old 09-03-2008, 10:26 AM   #21 (permalink)
XRAIDEDJ's Avatar
Member # 119389
how does the shifter work.....I got an MJ standard cab...gonna run aw4..got any pics? As of right now...the drive shaft is long enough I don't need the SYE kit with 5.5 inches of lift....do you know if this would change if I put one of these in?
XRAIDEDJ is offline   Reply With Quote Quick reply to this message
Old 09-03-2008, 10:50 AM   #22 (permalink)
jesster's Avatar
Member # 49468
I already have your 231 kit, but didn't realize that you offered a 32spline output shaft for the doubler.
How much for just a 32 spline shaft if I decide to upgrade?
jesster is offline   Reply With Quote Quick reply to this message
Old 09-06-2008, 07:40 PM   #23 (permalink)
bentonedge's Avatar
Member # 20369
Send a message via AIM to bentonedge
duffy i sent ya a pm the other day did you get it?
i got a shit box, and i kill people for a living.
bentonedge is offline   Reply With Quote Quick reply to this message
Old 09-12-2008, 06:37 PM   #24 (permalink)
Member # 73968
so the 231 and 300 are pretty close to the same measurement, as a stock 231? do you have the kit ready to go what is the down time? thanks
bassbelly is offline   Reply With Quote Quick reply to this message
Old 09-13-2008, 10:54 AM   #25 (permalink)
Member # 11168
yes I have the kits on the shelf ready to ship.
As for the 32 spline shaft there $250 for shaft only.
( all kits are the same price $499 with the 21,23,27,31 or 32 spline shaft )
Thanks
Duffy
D.D.Machine
(360)649-4465
