LS Engine to an Oil Accumulator Adapter - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 08-31-2009, 05:49 PM   #1 (permalink)
Member # 41800
This is an adapter to make plumbing in an oil accumulator possible on an LS based engine. A oil accumulator is supposed to have -10 lines plumbing it in but until now there was not a good way to get the -10 fitting on the engine.
The adapter mounts right above the oil filter and is threaded with an "O" ring sealed thread instead of a pipe thread. This way you don't have to worry about destroying threads when you need that 90 degree fitting to end up in a certain spot.
The adapter also is also taped for 1/8" pipe on the top side so you can run an oil pressure sending unit there.
Our adapter comes with every thing you need to adapt this up to your engine. The Adapter AND the -10 fitting and "O" ring. On all LS engines there is some thing either blocking off the port or it is being used for oil cooling lines on some trucks. Our adapter reuses the stock bolts and gasket and installation is very easy.
We have these in stock and ready to ship.
Call the shop to order 615-962-9135
Selling price is $49.99
WideOpenDesign.com
615-962-9135
Woodlee is offline   Reply With Quote
Old 08-31-2009, 06:05 PM   #2 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Fawsome! Several headaches cleared up at once! Will be calling you in the AM!
J. J.
patooyee is offline   Reply With Quote
Old 08-31-2009, 07:30 PM   #3 (permalink)
No comment
camo's Avatar
Member # 4
Send a message via Yahoo to camo
gonna bolt mine up in the morning
thanks for stepping up and making these.
camo is offline   Reply With Quote
Old 09-01-2009, 05:27 AM   #4 (permalink)
Member # 15461
Very cool! I'll be ordering one soon. Can you snap a picture of the backside? how does the passage look? what sealing mechanism is used?
95geo is offline   Reply With Quote
Old 09-01-2009, 05:36 AM   #5 (permalink)
BigWoodyWag's Avatar
Member # 26468
Send a message via AIM to BigWoodyWag
Dang, I thought you were making it for the block. I'm not running a stock oil pan.
Triple Nickel Racing, Lead Foot Syndicate & TGTW Lemons Racing
555race on TWITTER
BigWoodyWag is offline   Reply With Quote
Old 09-01-2009, 06:08 PM   #6 (permalink)
Member # 45977
Kick ass!! I will be giving you a call!
Would make pretty good giveaway fodder.....
twentyfootdaredevil is offline   Reply With Quote
Old 09-09-2009, 11:03 AM   #7 (permalink)
Member # 8335
These are such a clean alternative to running a remote oil filter, etc. Great idea.
I will be calling and placing an order.
Partially Erect YJ
WideJ is offline   Reply With Quote
Old 09-09-2009, 11:46 PM   #8 (permalink)
Member # 124182
Originally Posted by Woodlee View Post
I take a chunk of Aluminum and mill it to fit the port right above the oil filter. Then I put ports in mine for the Accumulator, Oil Pressure Sensor, and oil cooler. Its crowded but works like a champ.
If you want me to make you one up let me know. I have been thinking about setting these up on the CNC any ways. I think its a common problem that no one offers a good solution for.
These ones are just for the sensor/accumulator right? Did you make any with the ports for the sensor/accumulator/cooler?
IrkedCitizen is offline   Reply With Quote
Old 09-19-2009, 02:00 PM   #9 (permalink)
matts88yj's Avatar
Member # 62615
X2. This is what I would need to run if possible.
Unstacking Hardass
matts88yj is offline   Reply With Quote
Old 09-25-2009, 08:28 AM   #10 (permalink)
BottomsUp RockRacing
SlowmoSU's Avatar
Member # 26608
Send a message via AIM to SlowmoSU Send a message via Yahoo to SlowmoSU
Thanks, Just ordered mine, along with an Accumulator, Better price than summit.
Bottoms Up Rock Racing
A.J. Condon Driver/Competitor - New to me - JeepSpeed soon to be Line Mountain approved.
#4414/Ultra4 -The Timberwolf 2 - aka TW2 Rebuilt For Racing Build Thread - SOLD !
Cell - 410-259-3577
SlowmoSU is offline   Reply With Quote
Old 10-11-2009, 10:39 AM   #11 (permalink)
Member # 41800
We now have these that are just tapped 1/8" NPT for an oil pressure port ONLY.
A few guys on here PMed me about this so we made them.
Call 615-962-9135 to order.
WideOpenDesign.com
615-962-9135
Old 01-03-2010, 06:11 PM   #12 (permalink)
Member # 10184
Send a message via Yahoo to Bigcountry
Do you make these for water pumps on 6.0LS engines. I need a bolt on adapter for my water pump to an -AN fitting for rear mounted radiator.
Thanks.
SAVE TELLICOhttp://www.pirate4x4.com/forum/showthread.php?t=595745
11' Rock Buggy, 2 Seater Built 5.3L, 700R-4, Atlas, Prorock 60's, 42" Irok Stickies, 2.5" Air Shocks.
Nothin better than Southern Rockbouncing.
JOHN 3:16
Bigcountry is offline   Reply With Quote
Old 01-24-2010, 08:28 PM   #13 (permalink)
Member # 2386
Bigcountry,
We do make a thermostat housing with -16 an on it. It is built so the thermostat can be kept in place. I will try and get a picture up tomorrow.
Rocky
RockYJ is offline   Reply With Quote
Old 02-15-2010, 09:05 PM   #14 (permalink)
Newbie
Member # 123420
How much for one of these including shipping to Perth , Western Australia 6154 please??
Bog Warrior is offline   Reply With Quote
Old 07-11-2010, 11:12 PM   #15 (permalink)
Member # 30600
I'll be ordering one of those soon!
99tantj is online now   Reply With Quote
Old 07-12-2010, 10:39 PM   #16 (permalink)
YellowJeep39157's Avatar
Member # 56678
Send a message via AIM to YellowJeep39157
I will be ordering one also SOON WOODLEE! Always, been jealous of ur builds
-YellowJeep39157
YellowJeep39157 is offline   Reply With Quote
Old 08-26-2010, 04:38 AM   #17 (permalink)
Member # 30600
Better late than never
Old 10-27-2010, 12:04 AM   #18 (permalink)
Member # 18540
Send a message via AIM to YJ_OVER_SJ
Order placed.
Thanks to Rocky for spending some time explaining a few things on the phone. Looking forward to improved oil pressure safety with the setup I'm getting from you guys.
"OBie"
CalRocs 2010 #5150
YJ_OVER_SJ is offline   Reply With Quote
Old 10-27-2010, 09:18 AM   #19 (permalink)
Parts Super Store
WideOpenDesign's Avatar
Member # 167988
Boxed up and headin' out today.
Appreciate the order!
Rocky
WideOpenDesign is online now   Reply With Quote
Old 11-01-2010, 09:53 PM   #20 (permalink)
grumpyoldguy
dedmetal's Avatar
Member # 121858
Originally Posted by RockYJ View Post
Bigcountry,
Rocky
Interested, pics?
dedmetal is offline   Reply With Quote
Old 11-02-2010, 08:39 AM   #21 (permalink)
Parts Super Store
Member # 167988
Originally Posted by dedmetal View Post
Interested, pics?
Here is the link to our web store:http://www.wideopendesign.com/Produc...t-Housing.aspx
If you have need additional info dont hesitate to ask.
Rocky
Old 01-05-2011, 05:24 PM   #22 (permalink)
Parts Super Store
Member # 167988
Guys, thanks for all the orders.
We stock Moroso 1.5 & 3 quart accumulators and all the plumbing parts too.
Great product and cheap insurance for LS engines.
Keep'em comin'
Rocky
Old 03-20-2011, 10:27 PM   #23 (permalink)
BomTec Racing #4476
Sand Crab's Avatar
Member # 149669
Rocky
Is your thermostat housing for routing the steam port when using a rear radiator?
Sand Crab is offline   Reply With Quote
Old 03-21-2011, 07:24 PM   #24 (permalink)
Parts Super Store
Member # 167988
The T-stat housing is a replacement unit built with -16 AN and still holds a OE thermostat.
The steam port is run from the cylinder head cross tube up to the radiator near the top.
I hope that answers your question. If not fire away.
Rocky
Old 03-21-2011, 08:15 PM   #25 (permalink)
BomTec Racing #4476
Sand Crab's Avatar
Member # 149669
Rocky
I asked that question before doing some more research. Haven't got my engine home yet to see how the cooling is laid out. I've got some other questions I'll call with.
