#51 (permalink) | |
Member # 132098
Transfer Case Support Kit from TMR Customs
The mounting bolts on the case are all concentric aside from the bolt between the breather and speedo housing. You may also experience some interference if you plan to use the bolt that's right behind the speedo output.
TMR CUSTOMS YOUR PREMIER SOURCE FOR CUSTOM FABRICATION & OFFROAD ACCESSORIES! SPECIALIZING IN: Rod Ends & Tube Adapters - DIY/Builders Components - Transfer Case Support Kits - Gussets - Link & Shock Tabs - 3 & 4 Link Brackets and more.... Check us out on FACEBOOK! Online - www.tmrcustoms.com CALL US TOLL FREE @ 1.877.503.TMR1 (8671) |
#52 (permalink) |
I should have some picture to add of the 205 case support in the next day or two. Mine is clocked about even with my 203.
I am offended by reality all the time. My 1 ton fj60 build: /forum/toyota-land-cruiser/708363-fj60-build.html |
#54 (permalink) | |
Member # 132098
I just sent you a follow up email with the tracking information.
#56 (permalink) |
need to bend up my tube to mount the second half (support for the 205) but here's the idea:
I am offended by reality all the time. My 1 ton fj60 build: http://www.pirate4x4.com/forum/showthread.php?t=708363 |
#57 (permalink) | ||
Member # 132098
#58 (permalink) |
little more done:
I have to stop there though because plans have changed.... something a little bigger is going up front now and I"m not sure if things will need to be moved around a bit.
#60 (permalink) |
How much would you charge for just the main mounting plate with or without the gusset plate? This is for a np205. My mounting is different then most. The whole setup mounts to a plate and the plate then has bushings to the xmember. I will try and post a pic of what I'm working with tomarrow
89 K5 Trazer, TBI350/TH350, 203/205, 60/14bff, 52s/64s, 42" TSLs on beadlocks For the best fullsize chevy parts: http://www.diy4x.com RIP Jason "WillysWanter" |
#61 (permalink) | ||
Member # 132098
D300, NP205 and Atlas Support Kits from TMR Customs
#62 (permalink) |
Member # 132098
Thanks for the orders guys! We've sold a few 205 kits this week without the bushings, and we're machining more of the Atlas Supports as we speak.
Don't forget to check out our support kits for the D300 in both Standard and Flipped configurations!
#63 (permalink) |
Member # 132098
Atlas Support from TMR Customs
We've got more of the Atlas Supports on the mill right now being machined...please keep the orders coming!
Don't forget to take advantage of the Pirate4x4 discount code upon checkout
#64 (permalink) |
Member # 132098
Transfer Case Support Kits from TMR Customs
Thanks to Pirate 4x4 Members for the orders! Don't forget to mention you are from Pirate when ordering online or over the phone to save.
#65 (permalink) |
Member # 132098
We often get calls asking why you should purchase our Atlas Transfer Case Support Kit over the competitors kits....here's two reasons: ![]() 1: The bore on our ring is machined after laser cutting to precisely mate with the machined housing on your Atlas. This guarantees a perfect fit every time. 2: Our kits are always in stock and ship the same day they are ordered. ![]()
#66 (permalink) |
Member # 132098
Just finished machining more of our support kits Friday afternoon.
Don't forget to use the code "Pirate 4x4" to save 10% upon checkout. You can also call us via our toll free # to place your order 1.877.503.TMR1 (8671).
#68 (permalink) | |
Member # 132098
TMR Customs - Transfer Case Support Kit
Your kit will ship this afternoon, and you will be sent the tracking info shortly. I tossed in a few extra decals
#70 (permalink) |
Member # 132098
I've had a number of inquiries so I thought I better post up....
We will sell any of the rings/flanges on their own without the bushings & tabs. Just call or email and we'll get you taken care of.
#71 (permalink) |
Member # 132098
Please keep the orders coming Pirate! Any kits ordered over the weekend will ship Tuesday morning.
#72 (permalink) |
Member # 132098
Couple more kits shipped out this morning, thanks Pirate!
#73 (permalink) |
Member # 51210
price and approximate delivery time to 95125. I need it by next friday.
[COLOR="Red"]cj7 SOA fullwidth thread[/COLOR] [url]http://www.pirate4x4.com/forum/showthread.php?t=538197[/url] |
#74 (permalink) | |
Member # 132098
Thanks to everyone else for the orders....please keep them coming!
