GM PCM Tunes - $150 for life - Page 13 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 06-18-2012, 08:30 AM   #301 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
Originally Posted by Y5mgisi View Post
Any problems taking a computer that has a LS1/manual program in it and putting one of your 5.3 tunes in it? Running a th400 so the manual part of it could basically stay.
As long as it's the LS1/Truck PCM and you have the harness to match. If it's the early LS1 PCM, then no.
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 06-18-2012, 05:25 PM   #302 (permalink)
Member # 11491
Should be good then. Its running my 02 5.3 right now. Runs pretty decent on a ls1 tune!
Cant imagine how much better it will run with a good 5.3 tune it it!
Now takeing donations, For the "GET MICHELL A DANA 60" fund........... :)
Y5mgisi is offline   Reply With Quote
Old 06-19-2012, 07:07 AM   #303 (permalink)
Yukon Gear and Axle
Member # 35700
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-19-2012, 07:40 PM   #304 (permalink)
Member # 11491
One last little question i guess. Am i correct in my understanding that torque management only applies to vehicles with electronically controlled transmissions right? And its only "activated" during shifts right? So, with me running a th400 TM would just be deleted right? Thanks alot by the way for taking the time to answer my questions before i have even spent money with you! Shows alot about your customer service right there!
Old 06-20-2012, 07:46 AM   #305 (permalink)
Yukon Gear and Axle
Member # 35700
Depending on engine/trans combo, and mileage, I will either leave all, some, parts, or none of the torque management. Even manuals from the factory came with some torque management.
A 5.3 in front of a turbo 400, I would delete all TM, everywhere. I feel a 400 can handle the power of the 5.3 nicely. Same with a built 4l60e/700r4. But if it's a stock, high mileage 4l60e, then I'll keep it and maybe enven add TM to keep the trans alive.
Of course all of this goes out the window when I'm specifically told what to do
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-20-2012, 08:06 AM   #306 (permalink)
Rockjock's Avatar
Member # 21189
Hey Wayne,
What can you do for a stock 2002 Chevy 2500HD 4x4 with a 6.0 in it? First I need it to be reliable then economy based - power based tune. We use the truck as a spare vehicle for towing and general hauling. Has 130k on it now.
Thanks
Never let out!
Rockjock is offline   Reply With Quote
Old 06-20-2012, 08:07 AM   #307 (permalink)
Yukon Gear and Axle
Member # 35700
Originally Posted by Rockjock View Post
Hey Wayne,
Thanks
Yup, can do all the above. I can also set it up so that towing on hills is easier, with less applying of the brakes....
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-20-2012, 08:11 AM   #308 (permalink)
Rockjock's Avatar
Member # 21189
Alrighty sounds good. I guess I need to do some research and figure out (in a more specific manner) how to descibe the changes we need or would like.
Never let out!
Old 06-20-2012, 08:24 AM   #309 (permalink)
Yukon Gear and Axle
Member # 35700
Sounds good. I don't really need 'specific' instructions. If you tell me more power, I know what to do. Or better fuel economy, or we tow a lot in the hills or....
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-29-2012, 02:19 PM   #310 (permalink)
1pistol1's Avatar
Member # 176217
wayne on the harness i got back from you it has a wire that says 4x4 switch, im using a np241 with the vss in the tale housing so do i still need to use the switch?
1pistol1 is offline   Reply With Quote
Old 06-29-2012, 05:54 PM   #311 (permalink)
Member # 20092
question on TM - what is the seat of the pants difference on a 5.3l with and without TM? thinking of getting my 4l60e built for abuse
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
Old 06-29-2012, 10:24 PM   #312 (permalink)
Yukon Gear and Axle
Member # 35700
That's what it's for, so the PCM knows when it's in 4lo and recalculates because of the 2.72:1 ratio change.
Depends on motor/setup... But GM can pull up to about 40* of timing because of torque management. The difference between being able to power brake it or not
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 06-30-2012, 09:23 AM   #313 (permalink)
Member # 20092
Does TM also prevent a downshift at times?
Old 07-01-2012, 08:25 AM   #314 (permalink)
Yukon Gear and Axle
Member # 35700
No, I don't believe so.
Shift points are based off of TPS and MPH, or if WOT, RPM's and MPH.
Now, on the newer DBW rigs, I'm not sure if it's commanded or actual TPS. If it's commanded, then it just goes off the pedal. But if it's actual, then yes, it could be TM controled. Since TM can vary actual, regardless of commanded.... But I don't believe it's this way....I've never logged/monitored to see.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 07-03-2012, 12:40 PM   #315 (permalink)
Member # 184346
Harness on it's way.
Wayne-
You should be receiving my harness today or Thursday.
I did end up sending an ECM that I had, let me know if it works.
Thanks
67Steven is offline   Reply With Quote
Old 07-04-2012, 07:17 AM   #316 (permalink)
Yukon Gear and Axle
Member # 35700
Originally Posted by 67Steven View Post
Wayne-
Thanks
I'm in CA for a funeral. Looks like I will be heading home today. I have all of my packages put on hold at the shop, so I should get them all Friday, if I can get the hold released. If not, Monday.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 07-10-2012, 05:16 PM   #317 (permalink)
Member # 11491
Looks like im finally going to be able to send you me computer this week! Im so excited! Make Checks payable to Wayne Hartwig right?
Old 07-10-2012, 05:35 PM   #318 (permalink)
Yukon Gear and Axle
Member # 35700
Yup
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 07-12-2012, 01:45 PM   #319 (permalink)
1pistol1's Avatar
Member # 176217
can the speedo and vss run off the same plug ?
Old 07-12-2012, 09:03 PM   #320 (permalink)
Yukon Gear and Axle
Member # 35700
No. but the computer can output a speedo signal.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 07-14-2012, 06:12 PM   #321 (permalink)
Member # 165446
02 Votex 4.3
I have a 02 4.3 gm motor that I need the computer flashed if you get it on tuesday can u flash and send back so I can have friday?
Let me know asap.
Killercruiser is offline   Reply With Quote
Old 07-15-2012, 09:25 AM   #322 (permalink)
Yukon Gear and Axle
Member # 35700
Let me know asap.
Yes. Just put a return label and $150 in the box
Put a piece of paper in the box with all of your info on it, including your phone number. On that piece of paper also include the specs of your rig and the rig that the motor/trans/PCM/TCM came from - ie year, motor, trans, gear ratio, tire size, etc. And anything special you want me to do - ie delete o2 sensors, increase idle RPM's, change shift points, give it more power, etc.
Also put on the paper if it's a new install or if I'm modifying an existing install. If it's an existing install, let me know on the paper if there were any issues - ie check engine light, running weird, etc.
If you don't know, that's ok. But the more info you give me, the better our chances for success are.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 07-16-2012, 11:25 AM   #323 (permalink)
Member # 2499
Wayne
Sent ecm 3 day select with a return label. I think I gave u all the info you will need. Original motor and trans to 2001 tahoe. Let me know if you need any more info.
Thanks
Mark
72 k5
OneTonK5 is offline   Reply With Quote
Old 07-16-2012, 04:54 PM   #324 (permalink)
Yukon Gear and Axle
Member # 35700
Originally Posted by OneTonK5 View Post
Wayne
Thanks
Mark
Perfect!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 07-18-2012, 06:39 AM   #325 (permalink)
Member # 165446
Wayne this is Jacob, I tried to send you a message yesterday about the 2000 ecm flash and I dont see it, So i will send another one. You should receive the ecm today around 10:30am, can you flash and send back today, please delete out the air temp sensor and the idle control sensor. I for got to fill out a return slip so If you can give me a fax # or a email I can send you a the retun label.
