Dana 300 Clocking Ring $45 shipped!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 01-14-2011, 07:28 AM   #1 (permalink)
CNC Machine Shop
4WHEELSUPPLY's Avatar
Member # 180013
NEW DESIGN INCORPORATES BOTH PASS AND DRIVER OUTPUTS. SO ONE CLOCKING RING FOR ALL APPLICATIONS!!!!!
Dana 300 clocking ring $45 shipped anywhere in the lower 48. I have these in stock ready to ship for either driver side or passenger side drop. These should work with most NP 6 hole round pattern cases. All grade 8 Hardware included!!! HD plasma cut from 3/8 A36. And CNC Machined! Ring's ID is bored for slip fit over front input housing. This is a pirate4x4 special price, I sell these on ebay for $50 shipped so dont forget to mention you are a pirate member when you order one.
THIS RING WILL NOT FLIP YOUR STOCK DANA 300 TO A DRIVER SIDE OUTPUT!!!! YOU WILL NEED MY FLIP RING TO DO SO.
DRIVER SIDE CLOCKING WORKS ON FACTORY DRIVER SIDE OUTPUT CASES WITH THE SAME 6 BOLT ROUND PATTERN AS D300 i.e NP208 241 AND MANY OTHERS
Use code PBB10% to get the $45 price on my website!!
Paypal address is fourwheelsupply@yahoo.com
4WHEELSUPPLY is offline   Reply With Quote Quick reply to this message
Old 01-22-2011, 05:13 PM   #2 (permalink)
CNC Machine Shop
Member # 180013
Thanks for all the orders!!!
Old 02-01-2011, 05:35 AM   #3 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 02-12-2011, 05:11 AM   #4 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 02-20-2011, 03:50 PM   #5 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 02-20-2011, 06:56 PM   #6 (permalink)
5-Speed XJ's Avatar
Member # 169016
BUMP,I need a d300 first then flip it then clock it.
xj with some stuff done to it
5-Speed XJ is offline   Reply With Quote Quick reply to this message
Old 03-06-2011, 05:24 PM   #7 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 03-10-2011, 10:12 AM   #8 (permalink)
CNC Machine Shop
Member # 180013
Thanks for all the orders!!!!
Pirate members are the shit!!!!
Old 03-11-2011, 12:51 PM   #9 (permalink)
bc35339's Avatar
Member # 89214
this will work with a gm nv 4500 right? if so how long would it take to get one to 40047?
bc35339 is offline   Reply With Quote Quick reply to this message
Old 03-11-2011, 12:55 PM   #10 (permalink)
CNC Machine Shop
Member # 180013
It will work with all round six bolt pattens used in Dana 300 and NP cases.
They are in stock ready to ship.
Old 03-11-2011, 02:06 PM   #11 (permalink)
Banned
Member # 178399
Sweet the one part I didn't want to make that and the shaft. Is there a limited supply would like to what to pick up my D33 and NP242
GeneticDisposition is offline   Reply With Quote Quick reply to this message
Old 03-14-2011, 04:20 AM   #12 (permalink)
Member # 9045
ordered thursday.. arrived saturday! Looks great... Thanks!!
lococj7 is offline   Reply With Quote Quick reply to this message
Old 03-14-2011, 06:23 PM   #13 (permalink)
CNC Machine Shop
Member # 180013
Thanks for the orders !!!!!!!!!!!!!!!!!!!!!!!
Old 03-20-2011, 08:01 AM   #14 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 03-27-2011, 01:30 PM   #15 (permalink)
Member # 123144
I need one of these for a 300 going to a nv4500 how long will it take to get? Leave me a number to call you at.
Bigblockscramb is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 04:47 PM   #16 (permalink)
CNC Machine Shop
Member # 180013
They are in stock ready to ship. We ship USPS flat rate. so anywhere from 2-5 biz days. We can ship faster if needed on your dime. If you want to purchase you can paypal to fourwheelsupply@yahoo.com just be sure to put in the message what you application is. i.e. pass side output that you want to clock up or driverside output that you want to clock down. Thanks
Old 03-27-2011, 04:47 PM   #17 (permalink)
CNC Machine Shop
Member # 180013
Number is 276-971-4549 M-F 8-5
Old 04-18-2011, 08:57 AM   #18 (permalink)
gtxracer's Avatar
Member # 25303
Can anyone with a AX15 comment on how these work with a D300? Do the shift rails hit the AX15 case or not? I'm not home and can't go look.
97 TJ 4500 wannabe Build Thread:
Instagram: @DukeEngineeringSolutions
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more!
gtxracer is offline   Reply With Quote Quick reply to this message
Old 04-18-2011, 06:17 PM   #19 (permalink)
CNC Machine Shop
Member # 180013
As far as I know you will need a thicker clocking ring for a AX15. 7/8 if I am not mistaken. And with that thick of a spacer you will have to have a different input shaft or adapter to have enough spline engagement.
Old 04-18-2011, 07:37 PM   #20 (permalink)
Member # 141351
price check;
mating a D300 driver side drop > AW4
shipped to
L1E 1V7
Ontario, Canada
if possible?
thanks
beakie is offline   Reply With Quote Quick reply to this message
Old 04-18-2011, 07:39 PM   #21 (permalink)
gtxracer's Avatar
Member # 25303
You're correct on the thickness but the AX15 input shaft protrudes 1/2" out of the case so a new input isn't needed. If you have the NV3500, you will need a new input shaft. I had to do some research now that you mentioned that.
Old 04-19-2011, 08:18 PM   #22 (permalink)
CNC Machine Shop
Member # 180013
Originally Posted by beakie View Post
price check;
shipped to
L1E 1V7
Ontario, Canada
if possible?
thanks
ring 45$ shipping usps 26$ In stock ready to ship.
thanks
Old 04-19-2011, 08:21 PM   #23 (permalink)
CNC Machine Shop
Member # 180013
Looks like I need to make a 7/8 ring? I have had a bunch of you ask about it. I will Try and get one in the works and pick someone to send a freebee to and try. Keep your eyes posted.
thanks for all input.
Old 05-14-2011, 06:24 PM   #24 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 05-24-2011, 02:42 PM   #25 (permalink)
Member # 152637
any word on a 7/8 spacer yet?! i'll GLADLY be the guinea pig for this
danfrommass is offline   Reply With Quote Quick reply to this message
