Infinitely clockable GM T-case adapter kits replaces stock full spline engagement! - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 04-18-2012, 01:57 AM   #176 (permalink)
MCMLXIX's Avatar
Member # 110338
Had another question: I mated the 4L80e to my round pattern NP205 and measured 4.18" from mating surface to mating surface. In your diagram back on page 5 (i think page 5) your CAD file said 2.5" ... What am I missing?
Also, how much exposed tube is left between the two round mounting plates if the overall outer length of the adapter ends up at 4.25"?
I almost ordered last week but the guy that was supposed to buy my old TH350 bailed....
1972 K5 Blazer Mall Crawler
LQ9 / 4L80e / NP205 / D60 / AAM 14bff / Hydroboost / Fox 2.0
MCMLXIX is offline   Reply With Quote
Old 04-19-2012, 06:14 AM   #177 (permalink)
mpascino's Avatar
Member # 31320
The setup in your photo is a "stock" 4l80E 4x4 to a round Chevy 205(long input. We would typically manufacture a 4.5" long face to face adapter in that application. The drawing on page 5 is a custom 4l80E(cut down output shaft) to a Ford 205(shorter input). The setup can be shortened down if you really need to but you would have to replace the input in your 205 with a shorter one to make it worth the effort.
Below is a pic of a 4l80E Chevy 205 adapter. The approximate length of exposed tube is 3" the way this one is configured, but it can be longer if needed.
Let us know if you have any other questions.
Thanks,
Mike
Trail Tech Fab
Trail Tech Fab
Home of Infinitely Clockable T-Case Components and Adapter Kits
CNC plasma cutting up to 1 inch, PM me for more info.
http://www.trailtechfab.com/gallery/main.php
mpascino is offline   Reply With Quote
Old 04-19-2012, 12:46 PM   #178 (permalink)
Member # 216723
Clocking np205
Mike,
I need a Figure 8 NP208 Clocking plate. For my 205 to sm465
70blazer is offline   Reply With Quote
Old 04-22-2012, 07:14 AM   #179 (permalink)
mpascino's Avatar
Member # 31320
In stock, sending PM.
Trail Tech Fab
Old 04-24-2012, 03:47 PM   #180 (permalink)
MCMLXIX's Avatar
Member # 110338
OK Mike, I'm ready now...
4L80e to NP205 round pattern at 4.5" overall length.
Ship to 89129?
Old 04-24-2012, 06:56 PM   #181 (permalink)
mpascino's Avatar
Member # 31320
Ship to 89129?
Sending PM. Thanks.
Trail Tech Fab
Old 04-30-2012, 06:37 PM   #182 (permalink)
mpascino's Avatar
Member # 31320
Thanks for the orders guys!
Trail Tech Fab
Old 05-01-2012, 08:48 PM   #183 (permalink)
toolman75's Avatar
Member # 145776
6 bolt th400 to gm np205 crazy 8 clockable adapter to ukiah ca 95482 please
toolman75 is offline   Reply With Quote
Old 05-02-2012, 06:26 PM   #184 (permalink)
mpascino's Avatar
Member # 31320
PMs sent.
Trail Tech Fab
Old 05-18-2012, 02:15 PM   #185 (permalink)
mpascino's Avatar
Member # 31320
Trail Tech Fab
Old 05-24-2012, 04:13 AM   #186 (permalink)
mpascino's Avatar
Member # 31320
Getrag,NV4500,NV5600 to NP 205
Keep the questions coming!
Trail Tech Fab
Old 05-24-2012, 10:23 AM   #187 (permalink)
Member # 218762
I have two applications: 2000 model 2wd 4l80e to Ford 205. 2002 model Allison 1000
4wd trans to Ford 205
AsBadAsYouWant is offline   Reply With Quote
Old 06-13-2012, 04:15 AM   #188 (permalink)
mpascino's Avatar
Member # 31320
Trail Tech Fab
Old 06-14-2012, 05:42 AM   #189 (permalink)
Member # 220482
4l80e to 205
i would like a price on the kit to adapt a 2wd 4l80e to a np205. i have the 205 with the 8 bolt and female input. however i had hoped to not cut down the shaft on the 2wd 4l80e due to im getting one with a warranty. could u make it and how long would it be? i havent ordered the 4l80e yet. and my zip is 33813
dwlakeland is offline   Reply With Quote
Old 06-15-2012, 04:31 AM   #190 (permalink)
mpascino's Avatar
Member # 31320
PM sent! Thanks
Trail Tech Fab
Old 06-21-2012, 05:30 AM   #191 (permalink)
Newbie
mopar800b's Avatar
Member # 39046
How about a ford 435 to a gm 8 bolt 205 with ford 31 spline input?
cj5 buggy, rocks and stuff
mopar800b is offline   Reply With Quote
Old 06-22-2012, 04:29 AM   #192 (permalink)
mpascino's Avatar
Member # 31320
Not a problem, sending PM.
Trail Tech Fab
Old 06-28-2012, 04:30 PM   #193 (permalink)
Member # 222445
In need of a 4l80e 4wd to a round np205
brauch is offline   Reply With Quote
Old 06-28-2012, 04:51 PM   #194 (permalink)
twoslo4five0's Avatar
Member # 87916
Location: a few miles from hopesmell va. Where you loose cell phone servise..
700r4 to figure 8 205 w/ support ring shipped to 23860 please.
88 3/4 ton blazer- total junk
77 Rockwell truggy think- even more junk
twoslo4five0 is offline   Reply With Quote
Old 06-29-2012, 03:57 AM   #195 (permalink)
mpascino's Avatar
Member # 31320
PM sent, Thanks.
Trail Tech Fab
Old 06-29-2012, 04:01 AM   #196 (permalink)
mpascino's Avatar
Member # 31320
PM sent, Thanks!
Trail Tech Fab
Old 07-16-2012, 04:11 AM   #197 (permalink)
mpascino's Avatar
Member # 31320
Thanks for the business! All open adapter orders shipping today.
Trail Tech Fab
Old 07-27-2012, 05:18 PM   #198 (permalink)
Member # 152523
Long shot but cummins nv4500 to chevy 205
bighroder is offline   Reply With Quote
Old 07-27-2012, 05:29 PM   #199 (permalink)
mpascino's Avatar
Member # 31320
I assume you are swapping a 29 spline input in the 205 correct? If so we can make an adapter kit for either the figure 8 or round pattern gm case. Which case do you have? A pic of the figure 8 adapter is above.
-Mike
TTF
Trail Tech Fab
Old 08-08-2012, 08:26 AM   #200 (permalink)
Member # 225625
-Mike
TTF
I too am in need of this adapter. I'm using a Cummins with a dodge nv4500. I've already swapped my input to the 29 spline and am using a Chevy round pattern NP205. Mounting face to mounting face seems to be just under 4" but I also want to clock it just a tad bit, the only adapters I can find are 2" and are for the chevy nv4500.
ferebeescott211 is offline   Reply With Quote
