CR250 tech....sorta - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Motorcycles/ATVs
Old 01-31-2012, 03:33 PM   #1 (permalink)
Member # 73107
CR250 tech....sorta
What is the best 2 smoke oil?
Should I run straight AVGAS and oil mix?
Best power mods?
I have had a ported, polished, and bored YZ and it hauled serious ass for an 80/92cc bike, I ran shitty outboard oil in it. I can get AVGAS all kinds of places and can't get good ethanol free 91/93 most places I go however, with all the little airports out here I can find 100LL. The bike is a 2000 (PWK carb) has a pipe and will be getting a JD kit and possibly a spare top end just in case. Will also be buying a set of wheels most likely WARP 9's from mountainpeakspowersports so I can throw a paddle on the factory rear and a decent front on the factory wheel. What else should I get
[QUOTE=fatdan460;14154037]why did i just look at sturgell's dick?[/QUOTE]
Sturgell is offline   Reply With Quote Quick reply to this message
Old 01-31-2012, 05:02 PM   #2 (permalink)
Wholesale Fasteners
707offroad's Avatar
Member # 187534
I like me some Redline. smells just like it tastes.... delicious! Can't help ya with the cr250 tech but on my ktm 300 xc-w e I run 87 or 91 with redline mixed 60:1 and it runs fuggin tits bone stock
Wholesale fasteners
707offroad is offline   Reply With Quote Quick reply to this message
Old 01-31-2012, 07:37 PM   #3 (permalink)
Brutpwr's Avatar
Member # 481
Dumonde Tech Z1...once you start uses this you won't want to run anything less!
Brutpwr is offline   Reply With Quote Quick reply to this message
Old 02-04-2012, 03:06 PM   #4 (permalink)
Member # 140945
Hey Sturgell how do you like the CR250 so far? My buddy has a 98 with super low hours for $1000. It has been in storage for the last 4 years so it'll need some TLC to get back in top shape. Anyway I am 5'6" and wear 30" inseam jeans am I going to be way too short?
malo periculosam libertatem quam quietam servitutem
-Jake- is offline   Reply With Quote Quick reply to this message
Old 02-05-2012, 03:34 PM   #5 (permalink)
Member # 73107
I'm 5'10" 32 inseam and this thing is a fucking handful on pavement, haven't ridden on dirt yet but it is a salty little bastard.
Old 02-05-2012, 07:10 PM   #6 (permalink)
Member # 152532
Use to run a YZ250 a few years back with some v-force 2s, FMF expansion and silencer, and mild port work. I ran Golden Specro for a few years and then Amsoil. I had excellent luck with both, both burned clean, only switched to Amsoil due to availability issues with the GS. How I miss my 2 smoke.
Some porn while we're on the subject:
f350n4.6ranger is offline   Reply With Quote Quick reply to this message
Old 02-05-2012, 09:15 PM   #7 (permalink)
Member # 73107
This bike is worlds better than the Service Honda...
Old 02-06-2012, 09:24 AM   #8 (permalink)
Pook's Avatar
Member # 3370
Seen some promising results with people running the amsoil. Going to switch to it soon.
Really like my 2000 cr250 for woods/trail riding. Suspensions been tuned for it, flywheel weight, gnarly pipe etc.
Pook is offline   Reply With Quote Quick reply to this message
Old 02-06-2012, 09:47 AM   #9 (permalink)
mjlogan88's Avatar
Member # 23553
honda HP2 and 91 at ~32:1. Expensive, but has never given me problems
mjlogan88 is offline   Reply With Quote Quick reply to this message
Old 02-07-2012, 07:06 AM   #10 (permalink)
Member # 73107
It came with a bunch of Maxima which will get ran before I buy any more, I'm seriously contemplating Amsoil but I fail to see what makes it so much better since it is sold like Mary Kay. You would think if it is so bad ass places would carry it.
Old 02-07-2012, 10:42 AM   #11 (permalink)
Member # 140945
I call it scamsoil
Old 02-07-2012, 03:28 PM   #12 (permalink)
Member # 73107
I call it scamsoil
Upcoming is how to fix a dented pipe, I held speed a little too long and couldn't get it shut down enough to make the corner and the result was the bike laying on top of me and a nice dent in the pipe.
I foresee a lot of sore mornings with this thing.
Old 02-07-2012, 05:33 PM   #13 (permalink)
Member # 73107
Dented pipe
Name:  2012-02-07 15.53.38.jpg
Old dirtbike tube and hose clamp
Name:  2012-02-07 18.29.36.jpg
Rubber compression plug thing with some rigged safety apparatus
Name:  2012-02-07 18.29.47.jpg
Mapp gas was sufficient although I think I could have got better results with more heat.
Name:  2012-02-07 18.40.14.jpg
Got tired of holding that little torch so here is where I stopped which is worlds better than it was
Name:  2012-02-07 19.22.40.jpg
I started with 20psi, initial heat took that to 30psi and ended up at a little over 50 gradually increasing pressure while heating.
Old 02-08-2012, 05:51 PM   #14 (permalink)
FordX4-offroad's Avatar
Member # 202878
i always ran the amsoil lean in my 2010 yz250 and never had any problems out of it.
amsoil dominator is what i always used. i believe 57:1 (with VP C12) was the most reliable mix i used...
but i did rebuild the topend every 11 hrs. and the bottom every 3 to 4 topend builds
423-883-2456 Donovan
<----Click here to see our full line 4x4 products!
full inventory of Advance Adapter products!
your premier source for RCV Performance products
FordX4-offroad is offline   Reply With Quote Quick reply to this message
Old 02-09-2012, 06:26 AM   #15 (permalink)
mjlogan88's Avatar
Member # 23553
You gota be kidding me. I'd be doing topends every other month
Old 02-09-2012, 09:49 PM   #16 (permalink)
Member # 202878
lol i did that every week...
summer of 2010.
living in my van, barely making it from race to race.. living my dream i guess
now... seems like i never ride
/hijack
Old 02-14-2012, 01:52 AM   #17 (permalink)
Member # 56456
Amsoil dominator and erc110k is my usual drink, mix around 40:1. rode the piss out of my bike for about 5 years. pismo wide open for days, all over never had any failures with the bike. Topend still looked good when I rebuilt it. 2 strokes love leaded fuel, a little extra lubricity aint hurt no one. especially in the upper end.
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205
Fordman500 is offline   Reply With Quote Quick reply to this message
Old 02-14-2012, 01:54 AM   #18 (permalink)
Member # 56456
I call it scamsoil
its great oil
Old 02-17-2012, 09:03 AM   #19 (permalink)
Member # 205023
I've been running straight 110 and the maxima GP7 for a few years now, burns nice and clean at 32:1.
On my 01' 265cc EricGorr Built, 110 ported,v force, 38mm Keihn Airstryker, etc....
Actually just cleaned her up.... Here's a pic next to my roomies 2011 CRF 450.
2 of the most winning-est bikes in history, EXACTLY 10 years apart.... Thanks Honda!
LQ4,216/220, 14B FF,80E
Dirtmafia is offline   Reply With Quote Quick reply to this message
Old 02-18-2012, 03:04 PM   #20 (permalink)
pwerrec's Avatar
Member # 119530
I run whatever I can get the cheapest. Belray generally but sometimes Valvoline from auto zone.
Never had any trouble. And when I did the top end recently, I did not notice any excessive carbon or increased wear that my friends who insist on paying more tell me I will have.
I understand the argument that it is not that much more for peace of mind.
I guess it is an experiment of sorts.
06 ktm300xc
Edit: a friend runs klotz, I think the kind with castor oil, and it smells the best for whatever that is worth.
pwerrec is online now   Reply With Quote Quick reply to this message
Old 02-19-2012, 07:09 AM   #21 (permalink)
Kevin003's Avatar
Member # 72735
Send a message via AIM to Kevin003
Also ran klotz for a while and i agree it does have a wonderful scent. I pretty much ran whatever i could find for the most part and never had and noticeable issues/differences other than the smell. And btw you guys mixing at 60:1 have more ballz than i do
Kevin003 is offline   Reply With Quote Quick reply to this message
Old 03-03-2012, 11:10 AM   #22 (permalink)
Member # 73107
I bought a 168 main jet from the Honda dealer, I can only guess that the jet is smaller than the 165 that was originally in the bike (didn't check the plug because it seemed to run fine and I'm a tard.) As soon as it started making noise I shut it down and pushed it back to find that I had tons of aluminum on top of the piston that came from the crown but the cylinder is fine(whew).
Damage....melted piston and dinged up head, parts are here, I'm just waiting on my JD jet kit to get here so I can load it up with a great big jet and work my way down. Total cost....122 for new Wiseco std bore piston and used head, 75 for jet kit, pretty cheap up to what I would have had to spend with a 4t.
Old 03-10-2012, 06:16 AM   #23 (permalink)
Member # 73107
The JD jetting kit came with factory Keihen jets and says to start out with a 182 main jet and 45 pilot, a little different than the 48pj 165mj that come in these bikes. The only thing I can figure is that the previous owners did not ride the bike far/long enough to get the piston to self destruct from a lean condition, however me bombing down dirt roads for miles at a time was enough to make the lean jetting into a real problem.
Name:  2012-03-09 20.53.42.jpg
Name:  2012-03-09 20.54.17.jpg
Name:  2012-03-09 20.55.58.jpg
Old 03-10-2012, 06:28 AM   #24 (permalink)
Member # 192462
I always had great luck with the Amsoil Dominator. 2 Banshees and a Quadzilla....never an issue. AV100LL in all of them....40:1 mix. All were ported so I went a bit richer for the higher exhaust temps
84 F-150 soon to be D44 high pinion front with 8 lug outers, D70 rear, 302, NP435, NP208
mikey8450 is offline   Reply With Quote Quick reply to this message
Old 03-16-2012, 11:15 PM   #25 (permalink)
Member # 56456
The amount of oil in the fuel doesnt make a lean or rich mixture like everyone thinks, its quite the opposite
