Brute Force750 Carnage - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Motorcycles/ATVs
Old 04-26-2008, 04:00 PM   #1 (permalink)
Member # 106872
Anybody ever blow up a torque converter on a Brute Force 750. I think that's what happened to mine this weekend. It started making some nasty knocking noises coming from my belt drive snorkels. I just had a utility clutch kit put in it. Has anyone had the same problem.
[SIZE="5"][COLOR="Blue"]R.I.P. Jonathan Efird, We love you and miss you.[/COLOR][/SIZE]
[SIZE="3"][COLOR="Lime"]What's that like?[/COLOR][/SIZE]
dixierods is offline   Reply With Quote
Old 04-27-2008, 01:27 AM   #2 (permalink)
Member # 6002
Send a message via ICQ to Toy 4Runner Man Send a message via AIM to Toy 4Runner Man
Looks like the newly installed clutch kit wasn't installed correct. there is no torque converter.
Toy 4Runner Man is offline   Reply With Quote
Old 04-27-2008, 07:14 PM   #3 (permalink)
Member # 112754
yea just need to adjust the kickdown bands and recalibrate the exhaust servo
seriously though sounds like a bad install or you just need a new belt
jmack is offline   Reply With Quote
Old 04-27-2008, 08:47 PM   #4 (permalink)
Member # 106872
Would this also be the reason my engine brake was not working properly. A few hours before it started knocking.
Old 04-28-2008, 06:24 AM   #5 (permalink)
Member # 112754
There is an actuator inside the clutch housing that activates the engine braking, it could be effected by the clutch not being installed right or simply they may not have plugged it back in. It sounds to me as though the primary clutch bolt may have come loose from not being tightened properly so i definitely wouldn’t ride it any more.
Old 04-30-2008, 08:13 PM   #6 (permalink)
Member # 106872
Well I checked out the belt drive/clutch that is not the problem. It's in the motor I have the extended warranty I just hope they won't bullsh*t me about and fix the problem.
Old 05-01-2008, 06:07 AM   #7 (permalink)
Member # 112754
well then that sound is probably the crank, good luck with that
87 Chevy Fo Ninety Six, 39" boggers, uncomplete
