dirt bike gearing - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Motorcycles/ATVs
Old 05-17-2008, 09:02 PM   #1 (permalink)
Turner-2000TJ's Avatar
Member # 75097
Post dirt bike gearing
I'm wanting to make my son's rm85L slower off the line, actually decrease low end power. I think the best way to do this is to change the sprockets out but I don't know if I need to decrease or increase them in tooth count. Any one know?
Thanks
00 TJ - Goin thru a change
Turner-2000TJ is offline   Reply With Quote
Old 05-18-2008, 08:53 AM   #2 (permalink)
Member # 71073
front smaller/ back bigger = lower gearing. Front bigger/back smaller = more top end. Remember a one tooth jump makes a huge difference. Hope that helps
tacobuggy101 is offline   Reply With Quote
Old 05-18-2008, 11:21 AM   #3 (permalink)
Nosebag's Avatar
Member # 112915
Gearing wont really reduce the power much. It only changes how the power is spread. It will still haul ass when it gets going.
Two good ways to reduce power is to run two base gaskets, which lowers compression, or a flywheel weight, which slows the revs. You could also run a combination of both if you feel the need.
Nosebag is offline   Reply With Quote
Old 05-19-2008, 07:25 PM   #4 (permalink)
jamesboise's Avatar
Member # 52564
Are you trying to slow it down for his skill level or get some more grunt off the bottom?
jamesboise is offline   Reply With Quote
Old 05-20-2008, 08:26 AM   #5 (permalink)
Member # 1418
X2 .... what are you tring to gain from this??
as for sprockets .... think of how mountain bike gears works, same thing with a motorcycle.
sounds like a heavy flywheel would be best......
Is this your sons first bike?
Arizona Trail Riders ....... BRRRaaaAAAPPPPPPP
Kyron is offline   Reply With Quote
Old 05-21-2008, 07:14 PM   #6 (permalink)
Member # 75097
I'm trying to slow it down for his skill level but then be able to return it to current condition as he gains experence.
Thanks for all the info.
Old 05-22-2008, 07:37 AM   #7 (permalink)
DiscoDino's Avatar
Member # 15296
I dropped my front sprocket from 15T to 14T and love it...so lower gearing is better for controle...
'92 Land Rover Disco truggy:
Beadlocked 42" Iroks, V8, ZF, dual cases, ARBs, Longfielded, M8274-50s with ropes, etc...
'98 Land Rover Discovery:
29" BFG ATs
'02 D90 TD5 ST:
33" BFG ATs
'91 Defender 110:
Build in progress
'07 BMW G650X Challange:
Interco Terraflex 29" rear tire
DiscoDino is offline   Reply With Quote
Old 05-25-2008, 08:48 AM   #8 (permalink)
Member # 101611
could you use a throttle governer?
toyoscraper is offline   Reply With Quote
Old 05-25-2008, 12:37 PM   #9 (permalink)
Discount!
dog walker's Avatar
Member # 156
Send a message via ICQ to dog walker
Or an exhaust governer.
Jeff Fretwell
72 FJ40
67 FJ45
83 Toyota 4x4 LB
dog walker is offline   Reply With Quote
Old 05-25-2008, 02:52 PM   #10 (permalink)
Member # 69594
If you want to take away bottom end, jump up a tooth on the front sprocket. That will make the gearing taller, like going to 3.90 gears in your truck from 4.10's or whatever. A flywheel weight might help him out a lot though, they'll make the bike easier to get rolling from a start and smooth out the hit a little when it gets on the pipe. My dad and I put one in a CR250 for a guy, it really helped him out in the trail because he was all over the place once he got into the power. Front sprockets are cheap, if he hates it after you put it on, they are easy to change out and you didn't lose that much on the deal.
I did it on my first bike, to make it easier to control taking off on a hill or whatever, I was running out of time in 1st gear before I could get ready to shift again. I kept it on because I liked the extra speed on sections where fire roads connected trails. I geared my current bike lower than stock (dropped one tooth off the front) for more low speed control (I ride a ton more technical trails than I used to), and this one has a 6 speed that still lets it go all of the 65+ mph I care to do on knobbies.
Nothing happens when you die.
TrikeKid is offline   Reply With Quote
Old 05-25-2008, 05:24 PM   #11 (permalink)
Member # 103026
i beleive it takes 3 teeth on a rear sprocket to equal 1 tooth on a front sprocket....learned that from some sand drag guys that have gearing fine tuned
BrianGriff321 is offline   Reply With Quote
Old 05-26-2008, 06:55 PM   #12 (permalink)
Member # 75097
should I drop 1 tooth or 2 on the front sprocket? The stoch gear is 14 teeth. Does it affect chain length at all?
Old 05-27-2008, 08:07 PM   #13 (permalink)
Member # 69594
You want to add teeth to the front to take bottom end out of it, dropping teeth will make the bike quicker. Just do one, that is a notieable difference. One tooth shouldn't require anything more than a chain adjsutment. BrianGriff is correct, one tooth on the front is equal to 3-4 on the rear.
More teeth in front = taller gearing
Less teeth in front = lower gearing
More teeth in the rear = lower gearing
Less teeth in the rear = taller gearing.
Old 05-28-2008, 02:31 PM   #14 (permalink)
mjlogan88's Avatar
Member # 23553
2 teeth on the front is huge. stick with one. and your chain will be fine you should be within adjustment range.
[QUOTE=davey2451;8082797] i just looked at mjlogan88's ranger and it sucks [/QUOTE]
If all else fails, immortality can always be assured by spectacular error
mjlogan88 is offline   Reply With Quote
