1996 Polaris Sportsman Trouble - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Motorcycles/ATVs
Old 02-07-2010, 01:26 PM   #1 (permalink)
Member # 11975
Send a message via AIM to MikeW Send a message via MSN to MikeW Send a message via Yahoo to MikeW
ATV is a 1996 Polaris Sportsman 400. It was working in all wheel drive but now I am having trouble getting the AWD to engage, only rear tires are spinning. Does this have something to do with a drained battery?
AWD is pushbutton.
MikeW is offline   Reply With Quote Quick reply to this message
Old 02-07-2010, 01:32 PM   #2 (permalink)
ky scrambled's Avatar
Member # 85771
Is the throttle working fine? I mean can you go full power?
Play stupid games, win stupid prizes
Old 02-07-2010, 01:38 PM   #3 (permalink)
Member # 11975
Yes, rear tires will spin.
Old 02-07-2010, 03:38 PM   #4 (permalink)
ih4x4's Avatar
Member # 11362
Send a message via AIM to ih4x4 Send a message via Yahoo to ih4x4
Im told that with a dead battery the hubs will not engage,
also when you are in 4x4 there are 2 switches that need to be working,
the switch on your handle bars and a switch in the shifter,
in reverse there is an additional override switch that needs to be pushed
fj 25/40/45 troopie clone work in process
82 landcruiser with tbi sbc
ih4x4 is offline   Reply With Quote Quick reply to this message
Old 02-07-2010, 03:42 PM   #5 (permalink)
ih4x4's Avatar
Member # 11362
on my scrambler i have a twist grip and the stock awd button is part of the stock thumb throttle, so I have it wired from the switched side of the ignition thru a toggle switch to the hub wire (i think its the purple wire)
Old 02-07-2010, 04:43 PM   #6 (permalink)
Member # 11975
Its the hubs. Is there a good write up on this? You have to put synthetic fluid in there I am told.
Old 02-07-2010, 05:11 PM   #7 (permalink)
ih4x4's Avatar
Member # 11362
a polaris dealer will have hub oil,
here is a good writeup on serviceing the hubs
http://www.atvtime.com/phpBB2/viewto...c0c7a30cead999,
and a good polaris forum
http://www.gen3usa.com
Old 02-09-2010, 05:31 PM   #8 (permalink)
Member # 150216
I am a mechanic at a polaris shop, and yes the battery being dead will keep the 4x4 from working.
If you have a problem with it pulling to one side or the other you may have one hub dry, in which case you need to disassemble, clean and possibly replace a seal on the rear of the strut. only use the polaris demand drive fluid in the hubs.
You can change the fluid by removing the 3/16 allen and draining it. Then add fluid until it runs out of the hole with the hole positioned at 9 or 3 o'clock.
Wicked YJ is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 05:34 PM   #9 (permalink)
Member # 11975
I will be posting pics of progress soon. Right side had very little fluid, left had more. Gotta find a snap ring pliers to borrow, tips on mine is too thick. My question is once I get everything back on, what am I supposed to torque the axle nut to? And lugnuts?
Old 02-09-2010, 05:45 PM   #10 (permalink)
Member # 150216
I dont remember the exact numbers for the axle nut. Snug it down and then spin the hub a few times. If you can, jack the whole machine up and rotate the rear tires so the axle shaft spins in the hub to set everything.
Then loosen the nut and just snug it down so the hub spins without binding. I think it's like 5 ftlbs or less. Don't forget the cotter pin.
The lugnuts are torqued to 29 ftlbs-ish if I remember right.
Old 02-09-2010, 09:36 PM   #11 (permalink)
Member # 11975
Very little fluid in the right side, it only would fill half of the bottom, I only shifted the fluid over to find that snap ring that popped out of my hands
This bearing is the last bearing which goes in the race that is attached to the spindle. Is this worn?
Bearing shown above came out of this part. I feel a sight ridge where the bearings ride, you can barely feel it.
Soaking bearings
Old 02-09-2010, 10:17 PM   #12 (permalink)
Member # 11975
Pole clearance is good. Tested the magnetism system, it works.
Old 02-09-2010, 11:02 PM   #13 (permalink)
Member # 11975
Last thing for the night. I was wondering if there was a way to test the AWD system before adding oil. Can you just push the pushbutton and then see if the hubs lock in place and don't rotate?
Old 02-10-2010, 09:06 AM   #14 (permalink)
Loftis61's Avatar
Member # 148442
I would...
Semper Fidelis
Loftis61 is offline   Reply With Quote Quick reply to this message
Old 02-10-2010, 05:07 PM   #15 (permalink)
Member # 150216
If the magnets work when you turn the switch on, then the awd should work. They use a one way bearing that is activated by the magnet.
Old 02-12-2010, 09:58 PM   #16 (permalink)
Member # 11975
This area is taken care of. Now something is draining the battery. When you connect the battery with the key off, it will spark.
