Member # 7356
Hayes leverl replacement?
so I flipped over and wrecked a hayes hydraulic lever. The ledge was bigger than I thought.
Can you replace those things (I assume so, but I haven't really looked at it yet...) ?Or should I just heat it w/ the Mapp torch and try to bend it back? If I do that, I'm kinda worried I'll snap the alloy and be SOL.
work is for suckers |
1962 YellowSubmarine
Member # 1494
they are replaceable, but I'm not sure if you have to rebleed the system or not... a couple months bac one of the mags did a report on another company's lever and said they didn't think Hayes hyd brakes couldn't get any better - till they tried this lever...I'll try to find it for ya today...
Peter S. Di Primo PSD Enterprises, LLC - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small. Prototyping and small production is our specialty, but we have the network to handle large jobs as well. Email me if you need something cut, bent, formed, milled, machined, etc. Founding Member - VCAS4WDC www.axlesnappers.org Help Fight Global Warming- turn your A/C on high and open all your windows. Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!! |
Member # 1494
found it, but my memory failed me a little, they loved the levers but didn't think they were "$70 better" than the factory levers...
read the article here also check out http://www.hayesdiscbrake.com/ for ifo and contacts on factory parts... HTH, PSD also let me know what you do and how you like it (if you change levers) as its only a matter of time before I'm in the same situation ![]()
Member # 7356
thanks yellow sub
appreciate the info. No way I'd spend 70 to upgrade a lever that I'll probably just bend again anyway. Unless of course Hayes wants 60 for theirs.
thanks again, I'll let you know if there are any tricks to it. Matt
Member # 5686
My friend who races DH raves about the Stiffy levers, but he probably doesn't pay what we do....
I've bent my levers back 'cold' several times, just never bend them back all the way to straight to avoid cracking them.... |
