Mate a Turbo 400 to a Muncie 4 speed - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 02-03-2012, 10:30 AM   #1 (permalink)
Member # 210526
can anyone tell me who or where i can get the mating plate so i can connect my GM Turbo 400 to a Muncie 4 speed. This is going on a swamp buggy. Thanks
twistedmetalfabFL is offline   Reply With Quote
Old 02-12-2012, 12:53 PM   #2 (permalink)
Member # 9041
If I understand your question right I think you'd need some kind of splined coupling. To connect the output of the auto to the input of the muncie?
Give it just a little more, you'll make it
mudtrux is offline   Reply With Quote
Old 02-12-2012, 03:29 PM   #3 (permalink)
Member # 199321
So, you are connecting a automatic transmission to a manual transmission?
D.Reilly582 is offline   Reply With Quote
Old 02-12-2012, 03:39 PM   #4 (permalink)
ROCK HUGGER's Avatar
Member # 4329
Are you going to run a clutch between the auto and the manual? If not how are you going to shift the manual tranny when the auto is not in park?
ROCK HUGGER is offline   Reply With Quote
Old 02-12-2012, 06:08 PM   #5 (permalink)
Loftis61's Avatar
Member # 148442
Seems to me like the 4 speed is simply a cheap ass gear reduction box. Put 4 speed in granny low, and put the auto in gear. Yes?
Ask spdr.
The computer beat me at checkers once, but it was no match for me in kickboxing.
Loftis61 is offline   Reply With Quote
Old 02-12-2012, 06:26 PM   #6 (permalink)
TEX
Member # 603
I remember a buddy having one set up with a clutch. Was wild hearing him dump the clutch & then the auto going through the gears. T18 (maybe NP435?) & C6 IIRC.
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 02-13-2012, 04:13 AM   #7 (permalink)
Member # 117013
there was a member running two SM465s on here a while back.
Afghanistan Veteran, US ARMY 13F SGT
vic_v8 is offline   Reply With Quote
Old 02-13-2012, 05:08 AM   #8 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
Yes, like stated earlier....ask spidr
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 02-13-2012, 11:52 AM   #9 (permalink)
Karnage
spidr's Avatar
Member # 55444
It's unpossible
Its actually quite easy. Used to drive mine around in 3rd gear in town, kick it into 4th on the highway.
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is online now   Reply With Quote
Old 02-14-2012, 12:42 PM   #10 (permalink)
Member # 162452
2 trannys
when i was younger adding a second tranny was pretty common,my neighbor had 2 trannys in his 56 plymouth so he could tow his bulldozer.
shelfboy1 is offline   Reply With Quote
Old 03-19-2012, 03:39 PM   #11 (permalink)
Member # 203678
hey i did this a few years back give me a call 816/810/4555
keith
creepykrawler is offline   Reply With Quote
