1987 toyota Mud Truck...350 engine swap build - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 02-05-2012, 12:52 PM   #1 (permalink)
snoopdog970's Avatar
Member # 140162
Okay I figured I might as well post this build since its hard to find a lot of pics and information on the IFS 350 toyota builds. Bought this truck 2 years ago for 500 dollars..It was sitting on some wore out 35's, but had detroit lockers front and rear and 4.88 gears and the suspension and body lift already. I started running it in 2010 in the stock class and had it painted last year after I added the tacoma bed....This past august the motor threw a #2 rod, so thats what got the 350 build started.
87 Toyota 4x4 w/lock rite locker Front & detroit locker Rear, 4.88 gears, 33 boggers. 500 HP SBC 355
snoopdog970 is offline   Reply With Quote Quick reply to this message
Old 02-05-2012, 01:01 PM   #2 (permalink)
Member # 140162
Okay here is the video for the one pass in august..It already had a little knock before the race started..So advanced the total timing to 34 degrees and drained the tank and put 2 gallons of VP 110 fuel ( only because I had been accused of running alcohol the month before.
Cox City Mud Boggs august 2011 Quack Attacks Pass!! - YouTube
Old 02-05-2012, 01:09 PM   #3 (permalink)
Member # 140162
Okay after going thru 4 four bolt main 350 blocks and all being bad I found a complete motor on craigs list that helped two guys out...He needed money and I needed a motor...Plan is to run Schoenfeld tractor/truck pull headers for exhaust...Will post pics as the build goes along....Oh already took it outside and washed it down to have a clean restart cause I hated all that mud in my eyes...
Its a 2 piece 4 bolt main, 5.7 rods, 30 over speed pro flat tops with 2 valve relief, brodix spec aluminum heads w/ 2.02/1.60 valves, R294/300 Reed solid roller cam, 1.5/1.6 roller rockers, aluminum intake and complete serp built setup. Will be going with TH350 and 4000 stall adapted to the toyota gear drive T case...
bottom end:
Head setup:
Intake:
Prepairing the pull:
Old 02-14-2012, 08:40 PM   #4 (permalink)
Member # 140162
Well had a little issue this past weekend. The engine builder forgot to install a galley plug that was under the drivers side rear of head that went straight to the bottom end. So tore the motor all the way down to short block double checking everything...I now know what s exactly in the engine and know that everything is right...here is some pics of the other parts inside...
Old 02-15-2012, 06:10 PM   #5 (permalink)
Member # 146872
Lovin the build , One concern though
4000 stall converter + toyota t-case ?
WESTWELD - Fabrication, tube bending, mill maintenance
stuck720 is offline   Reply With Quote Quick reply to this message
Old 02-15-2012, 10:08 PM   #6 (permalink)
Member # 140162
Well I have talked to lots of builders and they say the toyota gear drive t case is tough...I am going to try and run it this season then next year go 205 and dana 60's, but I have talked with a couple guys that run the gear drive t case and run biggger tires than me and say its no problem but will cross that bridge when it comes...Just hope we can make this season before we shed something in the drive train...
Oh got the stall convertor today and its a 4500...I used to work for a place that builds there on trannys and has a convertor shop...I bought a 10 inch kit and they built me a tough ass stall...They say with the low gears and running low range that I want really feel a true 4500 stall....I will post videos hopefully in the next couple weeks....
Old 02-16-2012, 02:49 PM   #7 (permalink)
Member # 201433
you paid 500 bucks for that and it ran? sweet little truck btw
2001ChevyZ71 is offline   Reply With Quote Quick reply to this message
Old 02-16-2012, 06:04 PM   #8 (permalink)
Member # 204699
I used to race with a Suzuki Sammy that had a 383 stroker, powerglide, and a yota t-case. The 383 was easily over 600 horsepower, I think it was a 4500 converter in the glide. It was fast as fuck.
You're gonna hate that predator with a passion...hunk of junk...may as well not even bother and just send it to me...
Scooter402 is offline   Reply With Quote Quick reply to this message
Old 02-17-2012, 04:58 AM   #9 (permalink)
Member # 54478
We ran a 406 in our toy. We use the 350/205. here a link to our truck.
http://forum.ih8mud.com/79-95-toyota...they-last.html
cruisers4wdtoy is offline   Reply With Quote Quick reply to this message
Old 02-17-2012, 09:46 PM   #10 (permalink)
Member # 140162
Nice yota crusier...What you using for air intake?? What size of cam setup did you have.....Not sure I am going to give it that much on the first few races...Going to set the limiter around 6300 to not hurt it....
Old 02-17-2012, 09:53 PM   #11 (permalink)
Member # 140162
Well got the motor setting in it and going to put the trans case and T case and cross memember in tomorrow to mock up to make sure all right...Then its time to starting wiring in all the goodies and adding everything to wait on the tranny builder to get done....
Old 02-18-2012, 06:45 AM   #12 (permalink)
Member # 54478
Looking good snop. We ran a roller cam in the 500 lift range. You going to go with upright headers? We had a little problem with drivers side the steering shaft. Keep posting the build.
Old 02-18-2012, 08:03 PM   #13 (permalink)
Member # 140162
My motor has a 651/667gross lift solid roller Reed cam..Yes we ordered the schoebfeld vertical headers that kick forward for the brake booster. Do you have any pics how your got around the steering shaft??? I was looking at that today and was hoping with the kick forward ones it might miss the steering shaft...
Old 03-05-2012, 11:39 PM   #14 (permalink)
Member # 140162
Well had issues with the predator carb. Never would run kept flooding out and wouldn't take fuel. I called Predator and they told me what to check to see if it getting bumped around in shipping could have caused some issues. I took it apart and followed the manual settings from the book and when I put it back on it started right up and idled somewhat high but once I get the leaking radiator back in I will fine tune the carb...
http://youtu.be/2PlBa7lsad0
Old 03-11-2012, 02:30 PM   #15 (permalink)
Member # 204699
THAT....is fawkin' sexy!
Old 03-11-2012, 06:54 PM   #16 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
Ive got a 4wd th350 to toy case adapter outof my mud truck if ya need one.
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
85 Toy SR5 xcab DD
86 GMC K1500 SWB
88 4Runner Fambly Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 03-19-2012, 09:38 PM   #17 (permalink)
Member # 140162
Thanks for the offer but I have already gotten a adapter, but waiting on builder to find time to finish the transmission. All he likes is kitting the valve body and we are installing a transmission and hearing it run and fine tunning this bad boy..
Old 03-20-2012, 12:19 PM   #18 (permalink)
831kid's Avatar
Member # 190926
the bed actually looks pretty good
831kid is offline   Reply With Quote Quick reply to this message
Old 03-22-2012, 06:24 AM   #19 (permalink)
Member # 140162
Finally got predator carb back from predator and its running real smooth and feels like its got lots of torque....
http://youtu.be/HDoZ04N6QX4
Old 03-25-2012, 11:43 PM   #20 (permalink)
Member # 140162
Okay guys trucks together and 1st test and tune run...Was running it in 4 High and just feeling her out...she feels real good but going to have to buy a new shifter...the one I was donated by another mud bogger doesn't have 3rd gear/neutral lock, so I hit neutral a couple times....
http://youtu.be/5P61mq6hQPw
Old 05-21-2012, 01:14 PM   #21 (permalink)
Member # 140162
Update....Well had her running good and got to much of a bite while turning around and it sent me into a barrell roll for 1 1/2 times....
before...
after...
Old 05-21-2012, 04:32 PM   #22 (permalink)
Member # 172875
Dude. That's a bitch man.
Gibson75 is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 07:07 AM   #23 (permalink)
Member # 7412
Damn that sucks
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 08:09 AM   #24 (permalink)
rstycj's Avatar
Member # 125507
That does suck. Looks like the cage did its job!
78 cj5 350sbc sm465
97 one ton s10 5.3/sm465/NP203/205
rstycj is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 08:23 PM   #25 (permalink)
Member # 140162
Thanks guys...The cage did its job..Going to take this week off and go relax and relieve some stress in Puerto Rico..Then back out to check it all out next week....Have a few options but not sure yet...
