Synthetic Line vs. Cable - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 05-02-2012, 10:46 AM   #1 (permalink)
jwallmuth's Avatar
Member # 208656
looking into buying a new winch, and was just wondering is synthetic line really that much stronger and does it last longer to cost that much more more, and is it really worth it?
http://www.summitracing.com/compare.aspx
91 JEEP YJ, CHEVY 350, TH400, ATLAS 3.8,
44" CUT BOGGERS ON 1 TONS
jwallmuth is offline   Reply With Quote
Old 05-04-2012, 10:36 AM   #2 (permalink)
Fredy_C's Avatar
Member # 141714
do a search in gen4x4 and you will get most of your answers.
Only thing i can see is if you drag it through alot of mud and dirt it could work its way between the fibers and shorten its life span
"A liberal is a commie with a college education thinking negro thoughts"
"Ugly Betsy"
'85 f250 reg cab/long bed
6.9 IDI/T-19/bw1356
d50 TTB/sterling 10.25
Soon to have a build thread...... Someday
USMC 7051 crash fire rescue
Fredy_C is offline   Reply With Quote
Old 05-04-2012, 10:50 AM   #3 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
After running synthetic rope for a couple of years now, the thought of going back to lugging that unwieldy metal cable around pretty much brings the suck
If you're not worried about weight, or don't pull cable that often - save your money. But if you pull cable often, it's awesome.
That said - in lots of mud, I'd suggest following through with a good cleaning session if the rope gets covered in mud. The grit can and will get worked down into the rope itself and can accelerate wear.
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote
Old 05-04-2012, 04:36 PM   #4 (permalink)
Member # 66858
If you are doing comps or clean snag free winching then you cant beat the synthetic rope. If you are winching in dirty rocky snaggy stuff then I wouldn't run synthetic on a dare. Steel cable lasts much longer in all conditions too.
Member
Deep Woods Extreme 4X4 Club Of Southern NH.
LASER is offline   Reply With Quote
Old 05-04-2012, 08:55 PM   #5 (permalink)
Member # 111714
Yeah if its going to be exposed to a lot of mud, then steel all the way. I'd bet that even with constant cleaning, there will still be shit worked into the synthetic line that will eventually require replacement.
Tyler C is offline   Reply With Quote
Old 05-04-2012, 10:06 PM   #6 (permalink)
jwallmuth's Avatar
Member # 208656
this is what I was thinking, the mud and dirt would cut down the life of the rope vs. the cable.
Old 05-04-2012, 10:43 PM   #7 (permalink)
retards everywhere
Tigerchief's Avatar
Member # 124967
The biggest issue (for me anyway) is that synthetic line doesn't hold any energy if it happens to snap. It flops dead and won't whip-lash.
If steel cable snaps, it could get dangerous in a hurry. Use a weight blanket on the line if using steel cable.
Also, synthetic line floats for those pulls when you get stuck in water.
Some things to consider.
Tigerchief is offline   Reply With Quote
Old 05-04-2012, 11:05 PM   #8 (permalink)
jwallmuth's Avatar
Member # 208656
i bought a winch for my rhino, and it came with cable and rope. the cable lasted about a year and broke in the middle, so then i put the rope on, it's lasted about 2 years so far. so maybe the rope is better. it does cost more.
Old 05-05-2012, 03:30 AM   #9 (permalink)
jwallmuth's Avatar
Member # 208656
I found this online. all the info you need to know about. I think I'll go with synthetic rope.
http://blog.promarkoffroad.com/categ...ic-winch-rope/
Old 05-10-2012, 11:40 AM   #10 (permalink)
Rope Dude
Custom Splice's Avatar
Member # 122622
Feel Free to call me with any questions.
Todd
Custom Splice- AmSteel Blue Winch Ropes
We Stock - Safety Thimbles, Tube Thimbles and Excel Hooks
Office- 785 856 1844 Cell-580 504 1405
Need WINCH Rope? pirate4x4 is the secret code in the store for free shipping.
Have you seen APE EATER RACING's site
Custom Splice is offline   Reply With Quote
Old 05-11-2012, 08:26 AM   #11 (permalink)
jwallmuth's Avatar
Member # 208656
I'm sure we all have the same questions, which is better? and why? which is better and will hold up better, and last longer in different conditions such as, mud, sand, rock, snow, etc? just general facts. thanks all info will be great.
Old 05-11-2012, 02:14 PM   #12 (permalink)
Rope Dude
Member # 122622
As with anything, the better you treat it the longer it will last.
Rope does best when it is kept clean, after a ride I was off the rope using a garden hose, I do not suggest power washing.
Synthetic line is lighter, stronger and more user friendly.
AmSteel Blue does not stretch so it does not store energy, and whip back.
Steel and Ropes life depend on how you use/abuse them.
I have guys that use theirs everyday and it lasts years, but they are not in a hurry and make sure to watch what the rope is rubbing against and how it is being used.
Todd
Old 05-11-2012, 05:47 PM   #13 (permalink)
Member # 206556
In my experience with the rope, I found that it tends to cut into the spool more than cable, & gets hung up causing the red ass to set in.
E-Mc is offline   Reply With Quote
Old 05-12-2012, 05:31 AM   #14 (permalink)
retards everywhere
Tigerchief's Avatar
Member # 124967
Speaking of AmSteel blue, how about a discussion of Dyneema versus Technora fibres?
Or others that may be available as winch rope...
Old 05-12-2012, 04:13 PM   #15 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
I just spent the day wheeling with 3 rigs, all with synthetic lines. None had any burying that needed more than arm strength to get out.
The last time I went with some who had steel, it was so bound up the rig had to back down while winching out to get the line free.
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 05-14-2012, 05:43 PM   #16 (permalink)
Member # 183431
the way i look at it, if the military, aircraft industry and space industry arent using the synthetic stuff, im not. I have always had steel and will continue to. You just cant be an idiot when winching with it...ie no snatching. its meant to have slow steady weight applied, not blunt force.
bofer is offline   Reply With Quote
Old 05-14-2012, 06:16 PM   #17 (permalink)
and Scooby
BenE's Avatar
Member # 80653
Originally Posted by bofer View Post
the military, aircraft industry and space industry arent using the synthetic stuff.
you dont think they use syn line?
they do.
She’s got a silk dress, and healthy breasts, that bounce, on his, Ital-ian lea-ther so-fa.
My Junk here
BenE is offline   Reply With Quote
Old 05-15-2012, 02:33 AM   #18 (permalink)
retards everywhere
Tigerchief's Avatar
Member # 124967
So many assumptions and zero examples on actual use here, that this post is fawking useless.
Don't give a fuck about opinions, only real world experience and scientific fact.
Old 05-15-2012, 02:44 AM   #19 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Thanks Todd!
>David
> 4x4Spot.com
