Pit truck - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 05-07-2012, 01:29 PM   #1 (permalink)
Member # 7412
Pit truck
It might see some hunting duty also. I picked up a 80 model suburban, 454/465/205. I was thinking a cam intake and headers to get it where's it fun. I want tractor tires but not sure how far I can go with the 10 bolt. I was planning on leaving it open and welding the rear. Am I missing anything?
i would rather be spanking the monkey offroad
99 Durango sitting on tons and fortys
gunracer1 is offline   Reply With Quote
Old 05-07-2012, 03:45 PM   #2 (permalink)
Member # 198969
Send a message via AIM to xjbrian219
swap in a dana35
xjbrian219 is offline   Reply With Quote
Old 05-07-2012, 06:13 PM   #3 (permalink)
Member # 195097
Pit truck
Good luck with the ten bolt. I tried it with 35" boggers and broke a stock one. I would go dana 60. I run one now and havnt broke it yet with stock shafts and hubs and 37" cut boggers.
flashdog is offline   Reply With Quote
Old 05-08-2012, 02:40 AM   #4 (permalink)
Member # 7412
I watched a ten live with some 40" or so tractor tires a couple of months ago. Thats why I was floating the question. I don't expect a miracle from it, I will keep a watch for a passenger drop 60.
What are some of the better lift ideas?
Old 05-08-2012, 02:44 AM   #5 (permalink)
Member # 7412
Originally Posted by xjbrian219 View Post
swap in a dana35
Pad your post count in someone elses thread. As in stfu
Old 05-08-2012, 07:46 AM   #6 (permalink)
Member # 195097
Pit truck
If its off hwy only u got a few options for lift. U can buy springs and u bolts. I have seen guys around here cut there spring hangers off and drop them. Some even keep stock springs. U can also go blocks but need traction bars to prevent axle wrap. Depends how much u wanna spend and how hillbilly u want it to look.all these options i have seen work well. I just finished building tractor rims for 8 on 6.5 pattern. Cut out centers on a cnc table and welded them in. Tires r cheap too.
Old 05-08-2012, 07:50 AM   #7 (permalink)
Banned
trkklr77's Avatar
Member # 29016
says the dip shit wanting to ag tire a 10b......
oh wait, this is the mud section, full on retardation is normal, never mind, as you were.
Old 05-08-2012, 08:33 AM   #8 (permalink)
Member # 7412
So another uninformed dumbass bumping up his post count.
This whole rig will be put together for cheap. I have no desire to put money at it if I don't have to. I not looking to compete, just play in the mud. I watched a old suburban on a set of 40" or so ag tires go all over the pit. He didn't have a bunch of motor but he damn sure had a good time. Not on the side lines like most of us with Dana 60s and dot tires.
Old 05-08-2012, 09:24 PM   #9 (permalink)
Member # 172875
Well, it sounds like you've answered your own question then.
Gibson75 is offline   Reply With Quote
Old 05-09-2012, 05:47 AM   #10 (permalink)
Banned
trkklr77's Avatar
Member # 29016
you are right, i have no idea what im taking about, i never broke 3 stubs and 4 inners with less motor, less traction and the same trans/tcase. go ahead full speed dumbass.
Old 05-09-2012, 06:31 AM   #11 (permalink)
Member # 7412
So you are one of those bad ass 10 bolt killers. Man I wish I was capable of you Internet whit. I have never broken a ten bolt, matter of fact I have never broken a open diff anything So you were just driving around a muddy field and it broke?
Old 05-09-2012, 10:42 AM   #12 (permalink)
Member # 43251
Got 5 new american farmers 44x18x16.1 never used and marsh racing wheels sitting 7 hours from you, just buy some 12 inch springs and slap them on it and enjoy the truck in the mud, would take $2500 for the whole set of 5 tires and wheels and tubes, 78102 Beeville texas pm if interested.
dillo is offline   Reply With Quote
Old 05-19-2012, 05:57 AM   #13 (permalink)
Member # 7412
Well I ended up with some tires and rims. Wider than I was planning but they were cheap. 920 bucks delivered, so I will be looking for a 60 a bit harder. I have 3 ford 60s at the house, just no chevy or dodges. I need to redrill the rims to 8 on 6.5. I'm thinking about just buying a cheap 6" lift and cutting the hell out of it for clearance.
We fired the 454 up and it sounds just fine.
Old 05-19-2012, 05:59 AM   #14 (permalink)
Member # 7412
Heres the cream puff, and the tires beside my 40 mtrs
Old 06-05-2012, 04:55 AM   #15 (permalink)
Member # 7412
My buddie Jai bird came through.
Old 06-05-2012, 04:49 PM   #16 (permalink)
88mitsu's Avatar
Member # 125523
meh, If its just a play truck who cares what axles you run. Take it easy and you won't break a lot of shit.
If it was me, I would have put some AGs around 33-36" and go around pulling smaller trucks out.
The American public has Stockholm Syndrome.
88mitsu is online now   Reply With Quote
Old 06-05-2012, 05:08 PM   #17 (permalink)
Member # 11491
Yea just run it till it breaks. You WILL blow up that front end fur sure. But when you do, just play the rest of the day in 2wd and have fun!
Now takeing donations, For the "GET MICHELL A DANA 60" fund........... :)
Y5mgisi is offline   Reply With Quote
Old 06-05-2012, 05:59 PM   #18 (permalink)
Member # 55817
Been running 10 bolt fronts for years...of course occasional breakage, but only a handful of times in many years of running. Usually with 40" cuts on the front too...and it's spooled. Usually only have broken as a result of very rough pit or rough landings.
deranged1 is offline   Reply With Quote
Old 06-06-2012, 05:34 PM   #19 (permalink)
Member # 7412
Well I was just going to weld on the spacers and redrill the rims, but that was a no go. Had to weld up two holes to keep it all in good metal.
Old 06-06-2012, 05:45 PM   #20 (permalink)
Member # 195097
Pit truck
That will work. Make sure u countersink the holes.
Old 06-08-2012, 10:08 PM   #21 (permalink)
78stepsideUAK10's Avatar
Member # 92930
Interested in seeing this come together
How heavy are those tires?
Web wheeler
78stepsideUAK10 is offline   Reply With Quote
Old 06-08-2012, 10:29 PM   #22 (permalink)
Member # 174087
Need more pic's !!!! 454+4speed+10bolt+agg tires look for some rockwells ,perfect gearing and strength $900
jumbo2 is offline   Reply With Quote
Old 06-09-2012, 04:59 AM   #23 (permalink)
Member # 7412
If a set shows up I will snag them, but then I want bigger tires. 40" tires are just to small for rocks.
Old 06-09-2012, 05:24 AM   #24 (permalink)
Member # 7412
Well I bolted one on the Durango, and looked pretty good. So if a set of rocks showed up I would have to save these for back ups for the durango. And get some 48" or so tires for the suburban. But for now I'm just going forward with the original plan.
These tires and rims are some heavy bastards. The rim centers are 3/8 thick. I would guess 150 pounds each.
Old 06-09-2012, 08:45 AM   #25 (permalink)
POS
chev85k10's Avatar
Member # 118893
You are welding on the wheels with the tires mounted?
85 K10 BBC th400 203/205 60/14 yellow jackets robin nest spiderwebs
"all you will really be able to do is mash the gas, close your eyes, and hope it all works out ok."
chev85k10 is offline   Reply With Quote
