ford tranny - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 05-19-2012, 01:13 PM   #1 (permalink)
Member # 179727
ford tranny
for all you ford guys with big blocks what all did you guys do to your trannys to hold 500-600 horse as far as internals, thanks
mud racing is a lifestyle, not a hobby...
custom724x4 is offline   Reply With Quote
Old 05-19-2012, 09:02 PM   #2 (permalink)
Member # 17313
well, in my cousins ranger(a 600/600BBF), he runs a stock used c-6 with a simple shift kit, and 3K stall... Been taking home hardware for the last 5 years with it..
C-6's unlike chevy trannys, don't take much to hold up to mild(600hp range) big blocks...
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 05-20-2012, 02:17 PM   #3 (permalink)
Member # 123202
mudevil is offline   Reply With Quote
Old 05-20-2012, 07:14 PM   #4 (permalink)
Member # 178499
my buddies truck lived for several years with a mildish big block and C6, pretty sure all it had was a reverse valve body, low gear set and a 3500 ish stall. nothing incredibly exotic.
It finally gave up on him after he let some cheby boy talk to much trash to him and he nuetral dropped it while on the rev limiter at a bog.
fordtrucknut77 is offline   Reply With Quote
Old 05-20-2012, 10:26 PM   #5 (permalink)
Member # 179727
I appreciate the input, i have a c6 that i was just gonna put a rebuild kit in with a tci reverse valve body and a 3000 stall, i was also told i have a stronger 5 rib case? just wanted to check around, i hear about all the chevy guys pouring tons of money in their 400s so i wanted to see if i needed to
Old 05-21-2012, 10:40 AM   #6 (permalink)
Hold Fast
Elvis38's Avatar
Member # 101407
What about a Powerglide??
Elvis38 is offline   Reply With Quote
Old 05-23-2012, 06:30 AM   #7 (permalink)
Member # 89055
A C6 will hold decent power in stock form but not 500-600hp and be reliable. A lot depends on what you want to spend. You can go for a basic rebuild and upgrade to race frictions, beefier servo and a good shift kit which will hold up decent. A lot of the 4R100 parts will fit, like drums, planetaries, and roller washers. You can get drums machined for extra clutches or billet if needed. You can drop a lot of cash pretty easily on a trans just like you would an engine.
Matt
projectnitemare is offline   Reply With Quote
Old 05-23-2012, 08:18 PM   #8 (permalink)
Member # 179727
local shop says he can put kevlar clutches, rebuild my valve body with a shift kit and converted to manual and a upgraded servo for $600 without a coverter, seem fair and a good build?
Old 05-26-2012, 06:30 AM   #9 (permalink)
Member # 139700
thats not too far off. I build full roller c6's and they are a bit more cash. lol but with some better clutches and the wider band they'll take a beatin for a while.
5 ton goodies. [url]http.adamsoffroadperformance.com[/url]
Adamsoffroad is offline   Reply With Quote
