What torque converter for a big block mud truck? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 06-13-2012, 08:10 AM   #1 (permalink)
barneybasher1010's Avatar
Member # 55377
Have a 1974 Chevy shortbed with a 454 with comp cams K11-242-3(http://www.summitracing.com/parts/CCA-K11-242-3/), air gap intake, Holley 770 truck advenger carb, TH 350 tranny, 203 t-case, 3.73 gears in the axles and 36" tires. This truck is used for mud drags and need a better launch. It is great at the end of the run but lacks at the begining. What converter do you recondmend?
After the last race.
1985 Toyota 4Runner 22RE, 5.29 gears and 33-12.5-15 muds
barneybasher1010 is offline   Reply With Quote Quick reply to this message
Old 06-13-2012, 04:57 PM   #2 (permalink)
old ugly 54 chevy's Avatar
Member # 112785
looking at the cam specs i would say a 2000-2200 would suit you better
84 Ranger, dana 70u,ball joint 60, powerglide/np205, 350sbc powered, foa's
old ugly 54 chevy is offline   Reply With Quote Quick reply to this message
Old 06-13-2012, 05:11 PM   #3 (permalink)
Member # 123202
I would spend my money on a set of gears first.
mudevil is offline   Reply With Quote Quick reply to this message
Old 06-13-2012, 07:22 PM   #4 (permalink)
Member # 162728
I'd go with gears, then a 2500-2700 stall. It will be loose on the street, but it will be great for drag.
Chevy1TonFun is offline   Reply With Quote Quick reply to this message
Old 06-15-2012, 01:04 PM   #5 (permalink)
Member # 89055
That's not really that radical of a cam, even comp's website says you can use a stock stall speed. I'll say the next step up in stall speed would be ok, around 200-2200 any higher than that is pointless. I'll agree on the point you are losing out because of your gears; I'd change them first.
projectnitemare is offline   Reply With Quote Quick reply to this message
Old 07-01-2012, 02:17 PM   #6 (permalink)
Member # 55377
we went ahead and got a 2000-2300 stall and it helped alot.
