Member # 96278
Real mud tech question
I figure WTF. I'll go...
Auto vs Manual? I'm not talking big HP mud drag rig, but low buck, run whatcha brung bogger. No big $$$ powerglides, high stall set ups, just cheap, available drivetrains. So if you were putting a rig together, say a fullsize on 36" to 38" rubber, what would you run? |
FOMOCO MOFO
Member # 63730
shift or no shift
Just depends on what yer' used to. Lots of guys love the juice trannys cuz you dont have to get out of the throttle to shift. My Big B' has 4 spd & I go pretty much wherever I want on 42's & 4.56 w/429 on locked up tons.
Member # 603
For a stock class or play truck, you can get away with a manual in deep mud. You'll get killed on any kind of mud "drag" event though unless the track is REAL short.
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
I agree with the manual, but I really like the auto in my F-350 because the 460 just has the bottomend to spin them all day long.
I also think that certian people shouldnt have a stick because of the damage that they do to their rigs when they get stuck. I have seen more drive shafts and axles go due to the "reverse dump clutch, grind first dump clutch, reverse dump clutch and so on" with out ever lifting the skinny pedal. Its not the trucks fault I know but a standard is right for some people and not others. But on the flipside, Having a manual is good if you kill your starter because you can drag it in gear to roll start it. Any thing is better than being towed out of the woods.
Owning a handgun doesn't make you armed any more than owning a guitar makes you a musician. |
Member # 56006
My thoughts on it are that you want all the wheel speed you can get & keep that momentum...I think no matter how fast you can push in that clutch & shift your loosing that much wheelspeed..Its like shifting into nutral...
This is just my opinion... |
I have owned 2 automatics in the last 12 years, neither one was registered, or even driven by me... I've always driven stick, learned to drive on a manual,was driving for 5 years before I touched an automatic. For a highway vehicle, I refuse to have it any other way.
For my wheeling pig, I think I may be switching over to an auto, I have no issues shifting it in the pit(don't even bother with the clutch) BUT, my 2 big issues are A) I haven't found a clutch that will handle a dump at more than 1500 rpm without spending a fortune, and B) I somehow always manage to end up packing a pressure plate full of mud at least once a season... I have clutch R&R down to 4 hours in the field with no jacks and hand tools now though....
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL] |
Member # 21031
Auto always works best in the mud that I've seen. Manuals have there place but deep mud/water will just burn up the clutch and the loss of momentum hurts when shifting. Of course you need the proper cooling for an auto not to have there own problems.
![]() 1989 chevy crew on 44 boggers LY6 6.0L 400 205 Rocks |
#12 (permalink) |
Member # 100284
Autos are great if you can keep them water tight and run the vent to the top of the cab as high as you can get it. The stick has no vent but the clutch plates can get packed in thick bog and then the clutch will slip unill it burns out all the goo.
Silver '06 'X' "The Pirate Boat!"
#16 (permalink) | |
Member # 603
TEX
#17 (permalink) | |
Member # 96278
I've gotten pretty good at picking gears for a particular run, and can bang the 3-2 shift without losing all momentum. Not to mention, with a stock 360, I don't have much power to spare. |
#18 (permalink) |
Semper Fi
i'm on the auto side here. been into to many situation when the stick just got me nowhere...
Frank 49, 55, 57, 58, 75, 80, 93, 02, 07, and still growing check out our 68 charger build http://www.pirate4x4.com/forum/showt...7&highlight=68 |
#19 (permalink) |
Personal preference is for a manual, for many solid reasons. However, if you are into racing than an auto is the way to go.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] Last edited by Proeliator; 01-08-2009 at 01:46 PM. Reason: I r retard |
#21 (permalink) |
Member # 88672
I have run manual and then auto in my blazer. I would not go back to manual. As soon as you touch the clutch your wheels stop in deep mud.
A... truck... kinda ... with stuff in it... |
#22 (permalink) |
Member # 65969
auto w/ maunal valve body
but auto for sure, no matter how fast you shift you cant keep the tires spinning, and if you had to go back a gear after you shifted youd be done
-2001 f-350psd,-85 s10 blazer-sbc, 3/4t axles-74 Ford crew cab-85 yota- 63"'s, boggers |
#25 (permalink) |
Member # 38055
4 low and third gear. Dump the clutch...
...thats how I roll... Edit: and I don't shift either...
Texas, It's still America down here... Last edited by Big Murph; 01-09-2009 at 11:05 AM. |
