We love mud !!!!!! - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 01-19-2009, 07:43 PM   #51 (permalink)
Member # 82927
Originally Posted by Train Horn View Post
running 538 gears
i will admit im not really happy with loosing my locker , if it doesnt make much difference im NOT gonna be happy , but the guys swear by it !!
we shall see , when my ankle is better & im able to hammmer down then i will no for sure ! stay tuned
im running abut 500hp right now , its pretty peepy
KEEP THE LOCKER! That thing is light so with 500hp it should be flying? BUT 538 on 39.5? Speed is about tire speed, take those out and run some 373 or 410? If you have the motor thats all it takes, as long as you have the tq and hp it works. I run 44 boggers with 456's and can hold 2nd at 6500. Although I am running a 700hp/700ftlbs 582. My truck also wieghs in at 7800 lbs! When you run that 538's you are running out of gear to fast.
I would bet you $100 if you have a good motor like you say that if you swapped some gears you would gain speed and in turn run a quicker time.
By the way those pits look short? How long are they?
TLittle is offline   Reply With Quote
Old 01-19-2009, 08:42 PM   #52 (permalink)
Train Horn's Avatar
Member # 124760
thanks for you input !! we always like possitive input
makes sence ......but we are gonna stick with the 538 for now
if this doesnt work out the truck will be done totally different in the VERY near future !!
we will change the gears & 4 link it also
we run at a few tracks ........they range from 80ft to 250
Originally Posted by randy92782 View Post
Yup us mud people are coming to the city next
Originally Posted by MUD SLUT View Post
As they say, "Ain't no party like a Trucks Gone Wild party, cause a Trucks Gone Wild Party just don't stop!!!"
Train Horn is offline   Reply With Quote
Old 01-19-2009, 08:51 PM   #53 (permalink)
Train Horn's Avatar
Member # 124760
Taken out locker
one more thing ....its not as much gaining speed ...as it is not going straight
the truck has had a few near flips !!!!!!!!!
Old 01-20-2009, 12:39 PM   #54 (permalink)
Member # 82927
Some of your problems are right here. Work out the steering instead of the locker! I bet it steers real good one way and not the other right? Looks like the shittttttttty old chevy steering on it right? Of course having those blocks in there not doing any good either! And it is pretty short wheelbase too. Believe me instead of loosing the money on the locker? You said you paid $400 and would sell for $200. Just work out that steering and then find someone that thinks they need 538's and get you some 410's or 373's hell you can prolly find some of those for free! since everyone thinks they need real deep gear sets.
Old 01-20-2009, 12:39 PM   #55 (permalink)
Member # 82927
Shit the phone rang and I forgot this pic!
Old 01-20-2009, 03:18 PM   #56 (permalink)
Member # 99218
I disagree with this. The lower your gears are the less stress you have on the axle shafts (I would run even lower gears 6.17 or 6.37). To get wheel speed change the t-case gearing or tranny. If you can't afford a SCS or ProFab case, look at the 3 speed kit (that's if you running a toploader).
2-cents
hilbillypulling is offline   Reply With Quote
Old 01-20-2009, 05:14 PM   #57 (permalink)
Train Horn's Avatar
Member # 124760
the blocks have been removed .....my old motor ( stock 350 ) i had headers coming out wheel wells and they rubbed my brand new 39.5's so that was a quick fix to get me to a event !! they r now gone !! and still hasnt made a lick of difference ...ahhhhh it piss's me off
thank you very much for the tips !!
also .........we run a 205 tranfer case and its 2-1 gear ratio
we get to second gear at 6300 rpms with the 538's
we took the locker out hoping to have less breakage & easier to steer
we run a spool in the rear so it will still be good , we may be able to hang 3rd without the locker now . its all a TEST & TUNE !!!!
if it breaks we already have a dana 60 for the front & a dana 70 for the rear !!
Old 01-20-2009, 05:17 PM   #58 (permalink)
Train Horn's Avatar
Member # 124760
2-cents
thank you for the feed back !!!
money isnt a issue , its tryin to make due with what we have
we have 2 other more immportant trucks to sink money into .......lol
my truck is more of the play truck ........but now im gonna focus on consistancy races & break out class's to get more into the game !!
and represent for the girls !!
Old 01-20-2009, 05:22 PM   #59 (permalink)
Member # 99218
I'm also not a big fan of spools. Let me change that, cheep spools. Deflection is a major problem with these. I think Eaton had a deflection bolt that worked to fix this problem, but corp 14FF & 70's don't have this option. The detroit is great but I think Randy's or Driveline has a open carrier spider gear replacement that works better than any spool
Old 01-20-2009, 05:27 PM   #60 (permalink)
Member # 99218
Yea, i get having having fun (it got me band from here a few times) but who likes working insted of playing? If money ain't the issue and consistancy is the goal.........buy a few parts and have a HELL of a time
Edit: Overdraft on Chucks
Old 01-20-2009, 06:50 PM   #61 (permalink)
Train Horn's Avatar
Member # 124760
we run a detroit in the dodge , it had a auburn but they sucked !!
Old 01-20-2009, 07:56 PM   #62 (permalink)
Member # 82927
Glad the blocks are out! Got the only case worth a damn! I run a 205 also. Although for bogging some will run a 208 for a wieght savings? Of course you can hold 6300 you have 538' with 39.5's.
But that steering link pointing down to the ground is you handling problem, or lots of it. Work on that, maybe build some crossover with a hydro asst.? Keep up the good post!
2-cents
So that is your choice? But the lower gear get a weaker pinion! Also you must use the common sense rule here. If you run a 538 or 617/637 as you say how fast will it run down the road?
45mph? Run a higher gear and you can go faster right? of course you can that is as long as you got motor to turn it. So if you can go faster then that means more tire speed right? I will put my 44's with 456's and my 582 up against your combo all day!
Old 01-21-2009, 10:02 AM   #63 (permalink)
Member # 99218
At 6.17 and lower the pinion is not an issue. That's why I suggested running a lower gear
45mph?
Common sense would be to remember that her truck is perpose built for mud, not running down the road at 45mph
Ok, I'll webwheel first with my little alky inj. 463, th400 in 3rd & 31" tires:
tranny 1.1 x case 1.25 x axle 6.17 = 8.483
RPM 8,500 / final 8.483 = 1002.00
1002.00 x 95 tire dia = 95190in.
95190 x 60 min/hr = 5711400in.
5711400in / 12 in.per ft. = 475950ft
475950 / 5280 ft per mile = 90.14 mph
Old 01-21-2009, 10:28 AM   #64 (permalink)
TEX
Member # 603
2-cents
The SCS & ProFab are illegal in some of our lower & mid-level classes. Just another thing to consider.
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 01-21-2009, 11:09 AM   #65 (permalink)
skipped_Link's Avatar
Member # 37865
2-cents
Lower gears are not going to help your axle shafts, as they are after the reduction, it may help with drive line u-joints, t-case out puts, ect,
But even that is only theory, & theory that I think could be proven wrong in some cases, if you have the power get your wheel speed up, 39.5 boggers I would shoot for 4.88:1 or 5.13:1,
I was running 5.13:1 with 44" tires, but I had plenty of power to work with.
Project: Monster Buggy
http://pirate4x4.com/forum/showthread.php?t=615419
skipped_Link is offline   Reply With Quote
Old 01-21-2009, 11:59 AM   #66 (permalink)
Member # 99218
You are 100% correct with this statement, I was wrong. I had it backward.
But even that is only theory, & theory that I think could be proven wrong in some cases, if you have the power get your wheel speed up, 39.5 boggers I would shoot for 4.88:1 or 5.13:1, I was running 5.13:1 with 44" tires, but I had plenty of power to work with.
This theory has been proven time and time again in truck pulling. There is something about the 5.13 to 5.88 ratio that causes driveline failure. Outputs, joints and mostly pinions with 5.88's, it don't matter if its up front or out back.
2-cents
Old 01-21-2009, 02:16 PM   #67 (permalink)
Member # 37865
2-cents
The pinion is getting pretty small with a 5.88 gear, could be part of the problem,
When hooked to a sled, & getting a good bite to the track it don't matter if its, 4.10 or 5.88, in a sense you are stopping the tires & inputting the same load to the D-lines & D-line u-joints, even though the lower gears makes it easier to spin the tires, if they are hooked good & not spinning then everything would see the same X number of ft lb of torque that the engine is putting out,
Mud racing, ( & even drag racing the 1/4 mile) is similar but mostly at the starting line with the launch.
It is hard for me to wrap my mind around this, & even harder to explain it.
Old 01-21-2009, 02:53 PM   #68 (permalink)
Member # 99218
The 5.8++ pinion on the R/W 103 rears break, but when changeing to the 6.17 pinion on the 106 the problem (almost) goes away. The gears heads are very close, but the shanks are very different. I don't know the differance between pinion size for the Dana 60 or 70.
After spelling out finals, engine rpm and wheel speed, my skull can't wrap around my brain.
Old 01-25-2009, 06:21 PM   #69 (permalink)
Train Horn's Avatar
Member # 124760
Im proud !!!!!
Trucks gone wild held a awsome event today at bithlo motor sports in bithlo fla
the first Tri truck challenge of 2009
23 awsome teams signed up , and a car crushing event
Our truck PITBULL , ( team mates ) CRAZY BITCH & WIPE OPEN
Placed 2nd for the 321 !!!!!!!
it was a great day ........im hoping to get some photos up soon , waiting for my photographer ..to chime in
Old 03-18-2009, 05:47 PM   #70 (permalink)
Train Horn's Avatar
Member # 124760
some pictures of me & my truck this weekend
It was deep
some of my carnage
Old 05-04-2009, 11:03 AM   #71 (permalink)
Train Horn's Avatar
Member # 124760
Trucks gone wild " Spank the monkey race " 2 monkeys on poles one at one end of track one at other end , spank and go
Pit bull running his SBC & his FOA's
Team mate " The grouch " running his BBC
Me " THE PUP " SBC ......wasnt running up to par & something electrical going on
Old 05-06-2009, 02:51 PM   #72 (permalink)
TEX
Member # 603
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
Old 05-06-2009, 04:15 PM   #73 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
What are the motor specs on stucco money?
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s.
Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url]
Proeliator is offline   Reply With Quote
Old 05-06-2009, 05:09 PM   #74 (permalink)
Member # 48292
i like the pup, but wtf is up with the tc crossmember? that shit looks like a blind retard fabbed it up.
slightdrift is offline   Reply With Quote
Old 05-06-2009, 05:13 PM   #75 (permalink)
Proeliator's Avatar
Member # 12042
JoeBlow
