22r's with boggers - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 01-09-2009, 09:56 AM   #1 (permalink)
Member # 48292
22r's with boggers
What's the biggest size boggers you guys with 22r's & 22re's run? I was running 35.00 X 16.00's and in 2nd gear low it would start to bog in certain area's and I would have to sip the clutch to keep up the rpm's. I would have dropped into 1st but with 5.29's I didn't want to crawl around in the mud.
slightdrift is offline   Reply With Quote
Old 01-09-2009, 10:02 AM   #2 (permalink)
Member # 73850
I don't think you are going to have much of a choice with a 4 banger.
My friend's death trap yota, cut 39.5's, stock 4.10's. He plays in 1st gear 4 low and just kinda creeps anywhere he wants to.
"Seriously, don't be dumb." -Roxywheels
coonbottom is offline   Reply With Quote
Old 01-09-2009, 10:53 AM   #3 (permalink)
Alpine4x4's Avatar
Member # 110475
Im running 35x14.5 boggers on my 22re. The engine has headers, cam, exhaust, and bored .40 over. 5.29's in the axles and lockrights. In 4 low 3rd I can scream through mud like nobodys business
"I got a shotgun, rifle, and a 4-wheel drive and a country boy can survive"
Originally Posted by EMIEVEL View Post
If off-roading is outlawed, then only outlaws will off-road.
Outlaws we will be!
Originally Posted by Mustard Dog View Post
I'm in!
I love adding cute guys to our clique!!
Alpine4x4 is offline   Reply With Quote
Old 01-09-2009, 11:02 AM   #4 (permalink)
Member # 39312
I used to run the 16/35/r15 boggers on the rear and 36x14.5 radials on the front with a 4.88. Like you said I couldn't keep up the wheel speed. I went the complete other direction (skinnys) and picked up a set of 34.10.50 LTBs. They don't pull like boggers, but I find I have a lot more fun because I'm able to spin them.
I had a friend that used to run 44's with a 22r. He broke a few ring gears but it worked pretty well. Don't know what gears he ran though.
The skies are always sunny in the heart of flavor country.
grandeyota is offline   Reply With Quote
Old 01-09-2009, 12:16 PM   #5 (permalink)
79chevy39.5's's Avatar
Member # 67935
my buddy ran/runs a 22r bottom 20 r head with weber cam header and with 4.10 he really couldnt spin at all in thick stuff burned up a clutch......in soup it was fine
but he went to 5.29's and he can spin in the thicker stuff now
79chevy39.5's is offline   Reply With Quote
Old 01-09-2009, 01:39 PM   #6 (permalink)
Member # 126201
i had a old worn out 22r with 35-16-15 boggers and in low range 1-2 gear you can go anywhere
fordb0y75 is offline   Reply With Quote
Old 01-09-2009, 03:23 PM   #7 (permalink)
Member # 126141
I run 35x14.5 boggers on my 4runner, they do pretty good with the 22re. In 2wheel drive i can spin them and keep them clean. In 4 wheel high i just dont have enough motor to keep all four spinning. 4low works good in 1st gear but in 2nd they do bog the motor down a little if im in really thick mud.
muddy-pines is offline   Reply With Quote
Old 01-09-2009, 03:33 PM   #8 (permalink)
Member # 126201
when i had my toyota i always ran in 4 low and went thru the gears as needed
Old 01-09-2009, 06:24 PM   #9 (permalink)
78FORD4x4's Avatar
Member # 125311
Location: Sittin' here doin' my part to make sure the welfare checks cash.
I have a auto 4runner on 33s and it wont pull a greased string out of a cats ass!!
78FORD4x4 is offline   Reply With Quote
Old 01-09-2009, 07:33 PM   #10 (permalink)
Member # 48292
then don't be a pussy and swap in a 5-speed, 1st & 2nd gear, low Pull HARD! son
