Welded spiders or Traction lok - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
View Poll Results: Rebuild the Traction lok or Weld it
Rebuild traction lok 2 4.17%
Weld the traction lok 46 95.83%
Voters: 48. You may not vote on this poll
Old 01-09-2009, 11:17 AM   #1 (permalink)
Trail Mule's Avatar
Member # 103609
I have a grand wagoneer that I installed a high pinion king pin dana 60 and a sterling 10.25 in the rear. The sterling has a traction lok limited slip that has seen better days. My question is should i rebuild it or weld it up? The wagoneer rolls on 37's with double beadlocks, and the axle has 4.10 gears. I live in Texas and there isn't that much snow or ice. I would drive this thing on the road about 60 percent of the time the other 40 percent would be in the mud and trails. But mostly mud. I know that the tires would screech around corners but I could live with that much more than I could live stuck in a mud whole 10 inches deep. Could this limited slip be made tighter or should I just weld it.
Trail Mule is offline   Reply With Quote
Old 01-09-2009, 11:34 AM   #2 (permalink)
Member # 102365
linclion locker that bitch
MOLON LABE
urbanmuddboger is offline   Reply With Quote
Old 01-09-2009, 12:51 PM   #3 (permalink)
Member # 8914
Weld it. Track locks don't hold up well to larger tires.
Bald1 is online now   Reply With Quote
Old 01-09-2009, 01:06 PM   #4 (permalink)
Kenny714's Avatar
Member # 34803
Just welded my 10.25. I'll probably swap to a Detroit after this one breaks if the bank account allows it.
Kenny714 is offline   Reply With Quote
Old 01-09-2009, 01:58 PM   #5 (permalink)
secondarychaos's Avatar
Member # 122327
The vote thus far is unanimous.
my junk is lincoln lockered and i love it.
secondarychaos is offline   Reply With Quote
Old 01-09-2009, 04:29 PM   #6 (permalink)
1tonstepside's Avatar
Member # 21031
Weld her up and spend the money somewhere else.
1989 chevy crew on 44 boggers
LY6 6.0L 400 205 Rocks
1tonstepside is offline   Reply With Quote
Old 01-09-2009, 08:36 PM   #7 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
welded and wrapped in bacon.
David H. Petraeus for President 2016
guidolyons is offline   Reply With Quote
Old 01-09-2009, 09:32 PM   #8 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
I suggest finding an open carrier and welding that, it will be stronger than a welded up TL.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
Old 01-12-2009, 06:41 PM   #9 (permalink)
Trail Mule's Avatar
Member # 103609
What welder did you use. arc or mig welder.
Old 01-13-2009, 11:46 PM   #10 (permalink)
GREEN BASTARD!!!
cslimfu's Avatar
Member # 123458
Thumbs up
the main problem with those trac locks if the fact that they chew away at the carrier.then they get soo worn that the clutches slop around and break, or they burrow thru the carrirer and it splits in half. i have had both happen twice. i am now running a detroit and lovin it. i am sure it all depends on the use and mileage from the user before but, i got 35,000 out of my daily driver power sroke with 32's.i got 10,000 out of my mud truck with 38's then replaced it and its still holdin after 5,000 some with 42's.
cslimfu is offline   Reply With Quote
Old 01-14-2009, 03:33 PM   #11 (permalink)
Member # 41529
weld it but do it right and weld the spiders to the carrier too as well as the side gears. mig works well for me, brake clean the shit outta everything first.
78 F250 supercab healthy 460 and 38" XMLs
91 YJ soa, 60front/80rear, locked, 38.5x16 TSLs on h1s, np435/twin stick 205, 385 series ford power
JR650 is offline   Reply With Quote
Old 01-16-2009, 11:19 AM   #12 (permalink)
Member # 65863
weld it and when you go to turn just give it more gas
85gmac is offline   Reply With Quote
Old 01-16-2009, 01:29 PM   #13 (permalink)
Member # 63800
weld that axle
"I’m more flux-core than hard core." -- rustywagoneersdotcom
OffRoad is offline   Reply With Quote
Old 01-19-2009, 02:28 PM   #14 (permalink)
Member # 120490
why weld it when it will cost u about 35 bucks to put in a mini spool
ufospy is offline   Reply With Quote
Old 01-20-2009, 05:13 AM   #15 (permalink)
Member # 85700
he'd have to switch to an open carrier to go mini-spool.
dubrocker is offline   Reply With Quote
Old 01-20-2009, 07:47 AM   #16 (permalink)
Trail Mule's Avatar
Member # 103609
As far as I know there is no such thing as a mini spool for the Sterling 10.25, and I have a limited slip and I would have to get an open carrier which would cost almost as much as a Detroit.
