BBF stroker info - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 01-09-2009, 08:24 PM   #1 (permalink)
Member # 126680
BBF stroker info
Noting alot of us (so far) are running the BBF and many are asking about building for mud/torque, I thought I'd throw out a bit of info for the masses.
By adding a stroker crankshaft, the following occurs:
1) For every 50 cubic inches added, the rpm at which torque and horsepower peak at will drop about 600 rpm. So, if your 460 horsepower peaks at 6000 rpm, a 545 will peak at 5000 rpm. This assumes not changing anything else in the engine combo.
2) If you wish to maintain the same horsepower and torque peaks when you increase the stroke, you need to add between 12 to 16 degrees of additional intake duration for every 50 cubic inches added in displacement. Respectively, exhaust will have to be increased also.
3) The amount of torque below the torque peak, and at peak, will increase. This is a good thing, especially for street cars.
4) The larger the engine, the faster it will pull rpm. The weight of the rotating assembly is almost the same on all strokes, from a 460 to the 545 assembly, but as you increase the stroke, the engine now has more displacement pushing that assembly.
5) If you keep the same cylinder heads on the larger motor, you need to add overlap by using a tighter lobe separation, usually 1 to 2 degrees for every additional 50 cubic inches, until you get to 270 degrees @ .050" lift. Above 270 @ .050" duration, you need to bring lobe separation wider to limit overlap that is inherent after that duration. BSFC numbers go up needlessly with too much overlap.
The tighter lobe separation angle adds the necessary overlap to feed the additional inches, however, it does close the intake valve earlier. The horsepower peak numbers will be similar, but will occur at a slightly lower rpm with the tighter LSA. It is usually good not to advance the cam as much as usual.
If your compression ratio is "on the edge" running on pump gas, it may be inapproopriate to tighten the LSA because it increases lower rpm cylinder pressures. The tight LSA adds low and mid range torque because of the lower end cylinder pressures, but may not be needed if the vehicle combo is traction limited.
IDIeselman is offline   Reply With Quote
Old 01-09-2009, 08:37 PM   #2 (permalink)
Member # 126932
i dont know about all that you just posted but in florida we biuld them in our back yard shed im building a 638 ford idt premier block crower 4.750 stroke moters are just big air pumps the more air you move the more power and to make more torque than power you run high duration and lower lift on big er centerline also thats how did it offshore boat moters / on my jeeps 416 windsor im running 308 dur 560 lift on 112 center line and makes 80 ft lbs more than horsepower at peak about 6400 rpm
mightydog is offline   Reply With Quote
Old 01-09-2009, 08:48 PM   #3 (permalink)
Member # 126955
get over to my shed and build me some horse power!
kaosinc is offline   Reply With Quote
Old 01-09-2009, 08:51 PM   #4 (permalink)
Member # 126932
horsepower costs money how much do you want
Old 01-09-2009, 08:52 PM   #5 (permalink)
Member # 126932
to much info moters are much easer than that
Old 01-09-2009, 08:57 PM   #6 (permalink)
Member # 126955
ill take a real fire paint job worth...lmao
Old 01-09-2009, 08:58 PM   #7 (permalink)
Member # 126955
Mine too! Besides that, Are they hiring where you work?
sorry bud one man operation...i really do work out of a shed!
Old 01-09-2009, 09:00 PM   #8 (permalink)
Member # 126932
i know a guy who wants to get that done maybe we can work something out
Old 01-09-2009, 10:19 PM   #9 (permalink)
Member # 102365
not to be an ass or anything, but ........proper grammar and punctuation is important 'round these parts, ight homie
MOLON LABE
urbanmuddboger is offline   Reply With Quote
Old 01-09-2009, 10:34 PM   #10 (permalink)
Member # 126932
are you kidding me in our parts we do what we have to to get the point across not to be an ass but i didnt know i was still in school or that this was book or legal document got better things to do than be all punctual and shit but on another note if you need motor info i might be able to help you out if you can read what i type
