FOMOCO MOFO
Member # 63730
Mud drivetrains
How about some tech??? What are ya' runnin?? Tires/Axles/TC/Trans/suspension/steering..........What are ya' breakin??
My Junk; 79' Big B w/87' KPD60 4.56 Detroit 35 spline hub to hub.Cage weld on arms, no C-bushings/Rancho 4" coils/D60 rear 35 spline 4.56 Detroit shackle flip traction bars. 42" TSL.Sawzall fender mods, NP435/205.High Angle (Jesse) 1350 rear CV shaft. Last edited by Big79'Terry; 01-11-2009 at 11:50 AM. |
#2 (permalink) | |
my mud truck.... 18.4-30 R2's/5 Tons/Stock/4L80e/4 Link/hydraulic ........ not finished, so i havent broken anything. ![]() my jeep... 39.5 boggers/1 tons/none/SM465/stock YJ/XJ combo/hydro-assist .... haven't broken anything except 14 bolt u-joint straps my old mud truck was... 14.9-24 R1's/2.5 tons/3500rpm/th400/4 link/hydraulic ..... it didn't break anything either.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress. 88 YJ - 350, 1 tons, 40's |
FOMOCO MOFO
Member # 63730
Other coast...
Imagine that, the FL mud guy & the PNW mud guy hangin' it out for the crowd. Spent some time on Chucks trucks forum, you guys are wackier, more redneck than us!! Those trucks w/72" tractor tires & 1500 HP are awe inspiring!!! One of those trucks might make it thru our "TankTrap". We stuck a Cat 235 Excav all the way to cab in trap for Hangover 09'. Show us some pics please!?
Member # 53584
Heres a question I'm been pondering. When doing a 4-link (yes I have searched and read alot and still reading the rest) what version of 4 link are you using? I see alot of rigs running lower links parallel and to the frame while the uppers are triangulating from the axle center to the frame. I see this mostly on the supper tall rigs running ag tires though. Having just got back from Kuwait I'm researching all I can before begining to sling my rocks under my 79 f150.
The object of war is not die for your country but make the other bastard die for his! George Patton |
Member # 103250
im runnin a 79 f-150 with 44" gumbo mudders on 15x15 eaton rims. dana 44 front, 9" welded rear, 3:50 gears, 351m, 4spd., 205 t-case, l&l traction bars, 9" skyjacker suspencion lift and 3" body lift. so far i've broke 2 inner axle shafts, 1 stub shaft, broke the long side axle tube, snaped the front output on the 205, 2 rear 3rd members and i keep breaking the secter shafts off the steering boxes.
^Hates Liberals
Member # 80854
TH350/Np205, Rockwells (welded rear, Detriot Front), Leafs, Full Hydro, 49" V-treads.....................Oh yea, and I break TH350/NP205 Adapter plates for some reason
94' Yota Last edited by RebelRider; 01-11-2009 at 03:17 PM. |
FOMOCO MOFO
Member # 63730
Stuff........
83King...I campaigned the 1/2 ton F-trucks for 3 decades & am quite familiar with the shortcomings. Finally went to tons on the Big Green Hunka'Junk. Much happier
Less Drama . Get rid of that half ton stuff or downgrade tires, yer' gear ratio's high as well. Being locked up@lower gear ratio w/ heavier axles increases the fun factor by a bazillion!!! Keep floggin yer' FOMOCO brother!![]() Rebel.....Get a TH400!!! Last edited by Big79'Terry; 01-11-2009 at 03:38 PM. |
Member # 74068
Sounds like you need to run some type of Hydraulic assist on your steering. The hydraulic cylinder will take some load off your steering gear, and most likely prevent the failures you're seeing. Either that or it's time for full-hydraulic steering on that rig...
Tow Rig - 2004.5 Dodge 2500 CTD Trail Rig - 1991 Chevy K1500 - D60/14FF
^Hates Liberals
Member # 80854
That was my plan, but finding a th400 4wd was almost impossible at the time in my area. So i got a turbo 350 built to hold some HP. Been running strong for almost 2yrs................
94' Yota |
#13 (permalink) |
Member # 74068
I'd have to see your front driveshaft angle and know what the fracture looked like. I'm thinking it was caused by a bind, but that's just a guess without knowing more about your set-up.
#16 (permalink) |
Member # 116416
I'm gathering parts for an eventual build, but the drivetrain looks like this:
454 (have) Going to add a blower or juice. TH400 Manual w/ compression braking 203/LM205 (got the 203) 2.5T Steering Rocks w/ 2" Ouverson's (got the Rocks) The tire for straight mud will be a R1 or R2 style tire, 50"+. Last edited by lumberjack1986; 01-11-2009 at 06:54 PM. |
#17 (permalink) |
Dana 70 rear and Dana 60 front with 35 spline Superior chromoly axes, CTM u-joints, Detroit lockers front and rear and drive slugs. Used to run a C-6 but I couldn't keep it alive so I've been running an NP-435 and an oversized Mcleod clutch with success for the last handfull of years.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] |
#18 (permalink) | |
Member # 36399
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks 95 F-150 6" of lift, SAS 35" BFG's |
#20 (permalink) |
I protest, I drive nothing like you
#21 (permalink) |
Fawkin Fordhead
Stock 60/10.25/T19/1345 in my junk, haven't broken anything yet... But I'm running little tires(38.5 skinnies) and no real serious HP, an 8.0:1 460 does not big hp make...
Pro, that a single or dual disc McLeod clutch you're running? I've been kicking around the idea of going with one of those so I can keep my T19, I haven't been able to find a decent clutch that will take a launch with any sort of rpm in high range. 1500 seems to be about the max I can pull off without clutch smoke if I dump it. I know gears lower than 4.10's would help, but, if I could pull off a 3rd high launch I wouldn't need to worry about shifting in the 250 foot pit... Right now even in 2nd I have to get the clutch engaged before 1500, then hammer on it.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
#22 (permalink) |
Member # 126201
my truck
i got a 1975 ford f250 hiboy heavyduty its old running grear was a 390 to a 4 speed manual and a divorced 205 to a d60 rear 30 spline axle shafts and a f
d44 heavy duty with 27 spline axles and it was a kingpin style it also had hydro assist steering from the factory. now i got the same truck with 2.5 ton rocks its gonne have 46 american farmers 203-205 doubler and a 460 mildy built. i was thinking about 4link but to much money and not enough know how or a place to build it i wish i had pics but dont ![]() :evi
#23 (permalink) |
GREEN BASTARD!!!
Member # 123458
78 f-250, mild 460, t-18 and 205. 60's front and rear,4.56's detroit front,trac lok rear.4" lift 42" swampers.selling all that except the truck. have rockwells and 4 link parts, c-6 and new 205. also planing to stroke to 557. want to run 54 boggers but, will probably end up on xzl's(way cheaper).
