Member # 39312
Grease
What kind do you use? Do you spend the $$ on synthetic stuff or do you grease on the cheap?
I run into a lot of water so I use the synthetic in my driveshaft u-joints. It just seems to hold up better. The wheel bearings get repacked after every few trips so I use what is on hand or cheap.
The skies are always sunny in the heart of flavor country. |
lucas red n tacky, or the green stuff they make...
-j-rOd [COLOR="Lime"][SIZE="3"][B][URL="http://www.pirate4x4.com/forum/showthread.php?t=654042"]85 Roach Build Thread[/URL] [/SIZE][/B][/COLOR] [COLOR="Silver"][B] 84 Toy Farm Beater 85 Toy Trail Roach 223:1 85 Toy SR5 xcab DD 88 4Runner Fambly Beach Ride 07 Dodge 2500 4x4 Quad Cab, 5.9 CTD[/B][/COLOR] [B][COLOR="Lime"][SIZE="4"][FONT="Arial"]Nobody ever lays on their deathbed wishing they'd spent more time at work...[/FONT][/SIZE][/COLOR][/B] |
Member # 120246
i just use an off the shelf marine grease its worked for me so far. i dont see the point in spending extra money on stuff you replace on a regular basis anyway
you rock eatin, tater-brained, chicken chasin hubcap stealin gooberheaded fucktard. |
Member # 23452
just dont do like a buddy of mine did. he used grease for his excavator witch is made for impact and abrassion, not for wheel bearings. tosted them in the first 50 miles, LOL never seen bearings and race's weld them selve together.
me i use standard marine blue grease, never had a problem. not looking forward to filling the rockwell ends. any one know how many tubes you put in each end??? jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money. |
Member # 25643
x2 - Waterproof, Sticky stuff, use it in everything including CTM's.
[url]www.RainierVisitorGuide.com[/url] [url]www.MountStHelens.com/offroad.html[/url] 51 Willys PU, 502 Chev, 60/80, Alloy/CTM, Hydroboost, 44" Boggers, 205, T400. |
#11 (permalink) | |
Doesn't marine grease burn up in wheel bearings though? I would rather spend a extra couple bucks on red and tacky than replace wheel bearings
Owning a handgun doesn't make you armed any more than owning a guitar makes you a musician. |
#12 (permalink) |
Member # 87083
I recommend Cat Ultra 5 Moly Grease, contains 5% moly, water resistant against fresh and salt, designed for high-speed/high-load applications and offers corrosion protection.
1992 Dodge W250, CTD 5.9/Getrag/205/60/70. |
#15 (permalink) |
I just run standard on pretty much everything, except for my CTMs. Although, I re-grease very regularly. I run whatever that synthetic green monkey snot excuse for grease that Jack recommends on the Ctms.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] |
#16 (permalink) |
Member # 25643
Green Grease specs out a little better than Red N Tacky but I doubt you'd ever notice a difference.
http://www.greengrease.net/PDF/ggfactsheet.pdf http://www.lucasoil.com/images/media...ed_n_tacky.pdf Last edited by Magnum_Willys; 01-18-2009 at 10:03 PM. |
#18 (permalink) |
Muh...I use cheap marine wheel bearing grease and CRC moly grease for my birfields. My real secret is that I don't use greasable tie rod ends, balljoints (on my daily driver), u-joints, etc. Why? Because I have not seen ANY gain in longevity with the greaseable units. I happen to believe that keeping the parts seals so water can't get in and grease get out is just as effective as greasing them ever 3000 miles. I'm probably going to get blasted for that opinion, but look at factory rigs. Balljoints typically last 100,000 miles on a front wheel drive car. You put greasable Moogs in which are a quality product and you're replacing them again at 150,000 miles. I'm just sayin'......
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE] [QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit. [/QUOTE] |
#19 (permalink) |
Who?????
Member # 64846
Jess from High Angle recommends Prolong in the 1410 CV in my front shaft, so I'm running that in my shaft, Lucas Red and Tacky everywhere else.
#20 (permalink) | |
HIGHLY CONTROVERSIAL
95 Chevy "THE JUGGERNAUT" 74.5x30.5x32s "cut" 16 ton's BIG Inch BBC PG 2-SCS's 4-Wheel Steering 14,000lbs 2008 GMC 3500HD CCLB SRW 6.6 LMM DURAMAX ALLISON EFI LIVE Pro Rock D60 Last edited by MUD SLUT; 03-09-2009 at 02:34 PM. |
