skidsteer tires????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 01-18-2009, 09:22 PM   #1 (permalink)
Member # 122252
im lookin for somethin very aggressive to put on my beater cherokee basically a mini tractor tire and i saw in a magazine people using skidsteer tires?
what size are they
what size rim do i need
how much do they run
jkwalkercchs is offline   Reply With Quote
Old 01-18-2009, 11:09 PM   #2 (permalink)
Member # 116277
Send a message via AIM to purecountry Send a message via Yahoo to purecountry
How big you looking for? Firestone makes a 31x15.50x15 v tread that work pretty good. There's a set of six on racingjunk.com for $650 for all, listed under listed bar treads. 11.2-16 (35.5x11.8-16) Goodyear Dynatorque 2's for a mid size tire, then you have 18.4 x 16.1 that are a 44.8x20.1-16.1, and they'll sometimes work on 16 inch rims. Ive seen it done by results may vary. Hope this helps
[QUOTE=nahmus;10554695]
this country is trying to childproof the world when they should be worldproofing their children.[/QUOTE]
[QUOTE=SilverZuk;10606373]My wife doesn't go out, but if she did I would piss on her and kick dirt all over her before she left.
[/QUOTE]
purecountry is offline   Reply With Quote
Old 01-19-2009, 05:32 AM   #3 (permalink)
Member # 23452
http://www.titanstore.com/info/423383 might want to try these guys. the ones posted in the link are around a 38" X 13" on a 16" rim. im sure theres some smaller ones but ive never really looked.
jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote
Old 01-19-2009, 07:58 AM   #4 (permalink)
Member # 124915
my neighbor uses them on his chevy and they seem to go pretty good..
JGant84 is offline   Reply With Quote
Old 01-20-2009, 08:40 PM   #5 (permalink)
Member # 123475
good luck finding 11.2/16 dyna torque tires. They are discontinued and getting hard to get. I got lucky and found some local, and they are well worth the effort to track down. They have about 1 1/2 inches of tread depth!!!
creepyjon is offline   Reply With Quote
Old 01-21-2009, 02:48 PM   #6 (permalink)
Member # 127530
heres some size's to help you out: 8x16=31x8x16 9.5x16=33x9.5x16
heres a real good site for prices on all different size tractor tires tuckertire.com, you will not find lower prices anywhere else. if you wanna call them, ask for jim dalton.
ridgecrawler is offline   Reply With Quote
Old 01-21-2009, 02:57 PM   #7 (permalink)
Member # 127530
as for skidsteer tires,they are to hard, and stiff not good for anything but blacktop, in soft ground they will not clean theirself as well as a tractor tire does. and if you run a lot of rocks, neither tire is worth much.
Old 01-21-2009, 04:17 PM   #8 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
I'll tell you what pissed me off to no end; well all know ag tires rule in the muck but I was pretty pissed to find out my buddies 46" firestone ags had a much smoother ride on-road ride than my 44" boggers
edit: It actually made sense since the ags have an overlapping center tread section, where the boggers did not; but I still thought it was freaking ridiculous. My DOT tires beat the shit out of me and the off-road only tires were as smooth as glass
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s.
Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url]
Proeliator is offline   Reply With Quote
Old 01-27-2009, 11:25 AM   #9 (permalink)
Member # 128286
My buddy runs 12-16.5 skidsteer tires on his CJ5. They work great and can be found all over ebay. Measure about 33x12.50...
daryl is offline   Reply With Quote
Old 01-27-2009, 12:39 PM   #10 (permalink)
Member # 36399
SO go V-treads.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 01-27-2009, 03:44 PM   #11 (permalink)
HIGHLY CONTROVERSIAL
MUD SLUT's Avatar
Member # 66936
Send a message via AIM to MUD SLUT
what size are they
If you are looking for loader type (skidsteer) tires, you need to search for R4 tires. Google it. It is an industrial/agricultural designation for tread pattern regardless of height and width because in ag there are so few tread patterns used they can classify them all with R-codes. There are 5 of them. Ex. R1's are regular v-tread tires with standard height lugs (avg 45 deg bar tread tractor tire), R1W's are the wet version R1's (same tread as R1, but taller deeper lugs) R2's are the rice n' canes that all the mudders want (same tread as R1W, but even taller deeper lugs) R3's are turf tires (similar to a lawnmower tire), and the R4's are the industrial type tires (similar tread to skidsteer/loader) Got it fool!
EDIT--or disregard all that and look at the pics on pg 5 of this link
http://asae.frymulti.com/data/pdf/6/.../Lecture28.pdf
95 Chevy "THE JUGGERNAUT"
74.5x30.5x32s "cut"
16 ton's
BIG Inch BBC
PG
2-SCS's
4-Wheel Steering
14,000lbs
2008 GMC 3500HD CCLB SRW
6.6 LMM DURAMAX ALLISON
EFI LIVE
Pro Rock D60
MUD SLUT is offline   Reply With Quote
Old 01-29-2009, 10:14 AM   #12 (permalink)
mudbug660's Avatar
Member # 85902
I've got a set of 12.4-16 "dyna torque?" measures a true 37" I had to have mine shipped from wisconsin or somewhere up north. They were ~$800 a piece new around here.
1972 fj40 5.3,465,205,44,14,40"
mudbug660 is offline   Reply With Quote
Old 01-29-2009, 11:37 AM   #13 (permalink)
Fullsize wheeler
pennsylvaniaboy's Avatar
Member # 83301
jlg lift tirees can be had here for cheap. they are like 31/12.50/15 and they want $30 used for a tire with half tread...cheap beater
pennsylvaniaboy is offline   Reply With Quote
Old 02-09-2009, 03:07 PM   #14 (permalink)
Member # 127530
ask him how well those tires work when he airs down, unless he's running beadlocks, you can't air down those tires, they just pop right off.
Old 02-09-2009, 03:12 PM   #15 (permalink)
Proeliator's Avatar
Member # 12042
Folks aren't running these tires for rock crawling, they are running them for mud. I know the air down/bead lock craze has become widespread; but its just not necessary for these tires/application. Just thought it was worth mentioning.
Old 02-09-2009, 03:13 PM   #16 (permalink)
Archimedean
rustywagoneersdotcom's Avatar
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
Ok, so what sort of road speed did he run these up to?
Someone sort of local sell me a Dodge NP435, or the mainshaft/tailhousing from one.
Or, sell me a Ford NP208 input gear...
rustywagoneersdotcom is offline   Reply With Quote
Old 02-09-2009, 03:30 PM   #17 (permalink)
Proeliator's Avatar
Member # 12042
No more than about 50mph. And that was on unbalanced beadlocks. Versus my Boggers on balanced steel rims.
Really, if you know anything about tread design and road handling, it wasn't really that much of a surprise. Like I said, the V tread design with the overlapping center tread that always has contact with the road trumps the Bogger design. I just thought it funny and ridiculous that his off road only tires were SO much smoother than my dot tires...
