Hey Proeliator - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 01-18-2009, 11:51 PM   #1 (permalink)
Member # 116277
Send a message via AIM to purecountry Send a message via Yahoo to purecountry
Hey Proeliator
I saw your truck, and I've read every spec I can find on it. Tell me if what I have is right so far. HP dana 60 front, locked, chromo shafts, dana 70 rear, locked, 10 inches (or so) of lift using leaves. 514 stroker with a 4 speed and a 205 set up, 44 boggers. Am I right? And heres my question for you. I found a bronco for sale on here that has a 460, a 4 speed, 4 inch superlift, 3" body lift, 15x14 wheels, and mt baja tires. Would this be a good donor truck? Id like to use the 4" lift, the 460, and the 4 speed. Add in a 14b ff rear, a dana 60 front, both chromoed, and some cut 39.5 boggers. If you were gonna one ton a f-150 would you use leaves for a straight mud truck? Or try and keep the front coils? I know this is confusing as shit, and I apoligize if I sounded like a fucked up window licker, but any help you could provide would be great. Thanks man. Jordan
[QUOTE=nahmus;10554695]
this country is trying to childproof the world when they should be worldproofing their children.[/QUOTE]
[QUOTE=SilverZuk;10606373]My wife doesn't go out, but if she did I would piss on her and kick dirt all over her before she left.
[/QUOTE]
purecountry is offline   Reply With Quote
Old 01-19-2009, 11:17 AM   #2 (permalink)
Member # 41097
i wouldn't cut those boggers unless you're pushing 600+HP if you plan on doing mud.
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
mustange70 is offline   Reply With Quote
Old 01-19-2009, 12:39 PM   #3 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
X eleventy billion.
Actually, I'm using stock leaves. I basically just copied Bob Chandlers design from his first few BigFoots. The thought was, when I go to bigger axles/tires, I could throw on some soft 4" lift springs and trim my fenders and still have room for 56"s. Set up otherwise sounds right as far as the basic drivetrain goes. There are some little details that I didn't think were critical for a mud bogger/dragger when I first build it, but have since added. Specifically, I fabbed up the crossover steering out of the gate, but later added the hydro assist which has been awesome. I cavitated my pump once which resulted in some grievous breakage, now it doesn't have to work so hard. Much like I didn't think I needed a twin sticked xcase, but once I did that I fell in love with it. I twinstick everything now. The radiator in the bed I did from the start.
What you are talking about would be a good donor truck, depending on the price. As far as using the coils over the leaves, its just a straight mud truck so use whatevers easiest for you. Where people go wrong with leaves is they get stiff, highly arched springs for lift and they flex for piss.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s.
Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url]
Proeliator is offline   Reply With Quote
Old 01-19-2009, 08:15 PM   #4 (permalink)
Member # 41097
Yeah diddo on the spring stiffness, you need to have some flex in order to keep control in the rough pitts, as well as keep all tires on the ground at all times.
Old 01-21-2009, 08:11 PM   #5 (permalink)
Member # 80181
stock leaves? and 10 in lift? please explian sir.
Brocko2 is offline   Reply With Quote
Old 01-22-2009, 07:47 AM   #6 (permalink)
Member # 36399
mega super drop down brackets
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 01-22-2009, 09:45 AM   #7 (permalink)
Proeliator's Avatar
Member # 12042
Yup. Do a little research on how Bob Chandler built his original Bigfoots. I had twofold reasons for going this route, one being that it was cheap and easy while still yielding pretty good performance. The other reason, is that if/when I wanted to put some ginormous tires and rockwells under it all I'd have to do is get some mild lift springs and trim my fenders.
Granted, if I were doing it today I'd just build a link system. Ten years ago, however, if somebody was building a giant mud truck they were usually using lift blocks and stiff ass banana springs......taking inspiration from Chandler seemed to make sense.
Old 01-22-2009, 02:23 PM   #8 (permalink)
loveshackle's Avatar
Member # 9925
And then he went out on the maiden run in a mud pit and had it videotaped.
Since then, he's just been sitting at home, writing passionate Thank You notes to himself, dreaming of Heef's balloon knot, flagrantly hinting his 'I can't discuss it' profession, and reposting said video on Pirate at every opportunity.
"All great change in America begins at the dinner table" ~ Ronald Reagan
loveshackle is online now   Reply With Quote
Old 01-22-2009, 03:12 PM   #9 (permalink)
Proeliator's Avatar
Member # 12042
Originally Posted by loveshackle View Post
You touch yourself everytime you think of me, and I really can't blame you
Old 01-22-2009, 03:19 PM   #10 (permalink)
Member # 1867
NAW, YOUR THINKIN' OF THE W-TRAIN.
KDIO is offline   Reply With Quote
Old 01-22-2009, 03:52 PM   #11 (permalink)
Member # 9925
No, he's right. It's an affliction.
Speaking of Affliction...
Who ya got, Pro?
Fedor...4:00...Round 1
Old 01-22-2009, 04:08 PM   #12 (permalink)
Proeliator's Avatar
Member # 12042
Offtopic, but an offtopic I can get behind My money would be on Fedor, by at least round two. My gut would say round one, but the money plays it safe
Old 01-22-2009, 05:48 PM   #13 (permalink)
Member # 9925
See black text above...
Taking the family to National Western Stock Show up in Denver, so it's gonna be a struggle to catch it. Luckily, I've got Dish & Direct DVRs at the house... I'll just be late to the party. Hell of a card.
Old 01-22-2009, 05:57 PM   #14 (permalink)
Proeliator's Avatar
Member # 12042
Snap, great minds think alike
Old 01-23-2009, 04:15 PM   #15 (permalink)
Member # 36399
Bravo.
