tell me about my 4 link numbers....
yep... it's a big gay mud truck. add your thoughs, or just flame me. either way is fine.
if you need full specs on the truck, let me know and i'll post them... i've been debating adding more triangulation to the lowers by bringing them in at the frame end. however, this will require more fab work then just leaving them at the frame width. anyway... enough talk. here's a screen shot. give me some advice...
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress. 88 YJ - 350, 1 tons, 40's |
#3 (permalink) | |
my last truck had around 50% antisquat and worked great. however, if i can improve on things, i would like to.
Member # 92867
your roll axis angle is way to high.......13* is not desirable on any vehicle mud truck or not. The roll axis angle describes how the axle is going to steer itself. Say the body rolls to the passenger side...the passenger links push the axle forward, while the driver links get steeper and pull the axle back. This adds in steering through the axle itself, with disregard to the knuckles. This is oversteer.
43% is fine, get the roll axis angle as low as possible.....
96' F-150....460/c6/205/200 on rockwells 78' Bronco- 408m, C6, NP205, chromos, 40" boggers.... Last edited by BOGGER1966; 01-27-2009 at 07:31 PM. |
#6 (permalink) | ||
suggestions on how to get it there?
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress. 88 YJ - 350, 1 tons, 40's Last edited by iniviate; 01-27-2009 at 09:42 PM. |
#8 (permalink) | |
Member # 92867
since you havn't built anything yet i would get it perfect before you build it.....
96' F-150....460/c6/205/200 on rockwells 78' Bronco- 408m, C6, NP205, chromos, 40" boggers.... |
#9 (permalink) | ||
also... getting the roll axis lower puts my instant center back into the negative numbers. dropping the lower link at the frame gives me a 0 on roll axis. however, antisquat is -28 and instant center is -170. Quote:
i won't really get a chance to mess with it untill friday though. i guess i really need to read more about what each things does. i appreciate the advice.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress. 88 YJ - 350, 1 tons, 40's Last edited by iniviate; 01-28-2009 at 02:15 PM. |
Member # 92867
just play with it.....i would try to get the a/s higher then it is now......i dont exactly what to change to get what your looking for....
#14 (permalink) |
Member # 73506
Ideally you want the angle of your lowers to be 5-10º. Distance between the upper and lower axle side link mounts should be 25% of your tire diameter. Distance between upper and lower link mounts on the frame should be 50% of that number.
#15 (permalink) | |
Member # 44108
Where do you guys come up with these generalizations? Really, they just get more and more off the wall, starting with 70% uppers off the lowers. I have not seen a single 'rule of thumb' that made every style design easier to create, or function better. There are so many variables throughout each build that it is plain ridiculous to have any base template, in my mind. Dont mean to single you out toy, but you really see a lot of this going around, and it only spreads more. I just dont agree with it i guess. Did I miss it, or does it not say anywhere if this is a front or rear axle? Can you give us a picture of the truck? Some visual things and numbers not plugged into the calc (track width) will play into how you interpret the numbers in the calculator....what numbers you prioritize over others.
[center][SIZE="4"][url]Shop.FarmboyFabrications.com[/url][/SIZE] [B][SIZE="6"] [COLOR="DarkRed"]239.337.LIFT[/COLOR][/SIZE][/B] [SIZE="4"] [COLOR="Silver"]One Up Offroad[/COLOR][COLOR="DarkRed"] Rize Industries [/COLOR][COLOR="Silver"]Icon Vehicle Dynamics [/COLOR][COLOR="Yellow"]RCD[/COLOR] [COLOR="Silver"]Full-Traction[/COLOR] [COLOR="darkred"]Rubicon Express [/COLOR][COLOR="Navy"]KING[/COLOR][COLOR="DarkRed"] Sway-a-Way[/COLOR][COLOR="Navy"] FOX[/COLOR] [COLOR="Silver"]Dynatrac[/COLOR] [COLOR="Indigo"]Yukon Gear[/COLOR] [COLOR="DarkRed"]ARB [/COLOR][COLOR="Silver"]Detroit[/COLOR] [/SIZE] Including the largest selection of tires and wheels that you will find. Don't see what you are looking for? Give us a call.[/center] |
#16 (permalink) | |
i planned on running this same setup front and rear. here is a pic from when i started this topic. 102" track width. however... it's already built.... so here's the final numbers i went with. ![]() and some pics of it... ![]()
#18 (permalink) | |
it was a guess.... i figured if most rigs use the top bellhousing bolt and mine has way more unsprung weight... i figured it needed to be lower. yes, those are at ride height.
#19 (permalink) |
Member # 1919
you could build in a foot of adjustment in that thing
lowers frame end is pretty much where it can be but you could make the axle end adjustable with 8 or so different hieghts up from where it is now the uppers axle end are pretty much where they have to be but the frame end you could have mounting spots all the way down the vertical of that drop bracket being crazy tall like that makes it easy to build in options |
#22 (permalink) |
Member # 1919
