How much will 1/2 tons handle? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 03-29-2009, 05:15 AM   #1 (permalink)
Member # 116277
Send a message via AIM to purecountry Send a message via Yahoo to purecountry
Alright kinda random question, so I'll stick it in the mud section since thats the trucks intended use. Will the dana 44 hp front and 9" rear in a 1978 ford f-150 handle 33 to 35" boggers, if they have Superior 4340 chromoly front axle shafts and some CTM 300M alloy u-joints up front with a detroit, and 35 spline shafts in the back with a spool. Motor will be a 528 making in the neighborhood of 750 hp, and 700 tq, with a built c6 and np 205. Truck will be used in the mud and a lil trail riding in the southeast. No rocks at all. Thanks guys, Lcpl Duncan USMC
[QUOTE=nahmus;10554695]
this country is trying to childproof the world when they should be worldproofing their children.[/QUOTE]
[QUOTE=SilverZuk;10606373]My wife doesn't go out, but if she did I would piss on her and kick dirt all over her before she left.
[/QUOTE]
purecountry is offline   Reply With Quote
Old 03-29-2009, 05:24 AM   #2 (permalink)
Member # 86685
44" tires maximum
s10er8 is offline   Reply With Quote
Old 03-29-2009, 05:40 AM   #3 (permalink)
Member # 116277
Funny. trying to keep it off tons right now. Thats why I asked if they would keep breakage to a min. with the up grades mentioned, and 33 to 35" tires. This isn't chucks, and I'm not one of the idiots who thinks 44" boggers and a 3/4 ton dana 44 go together perfectly.
[/QUOTE]
Old 03-29-2009, 06:01 AM   #4 (permalink)
Member # 123475
WOW, that much horsepower and torque is rockwell territory!
creepyjon is offline   Reply With Quote
Old 03-29-2009, 06:03 AM   #5 (permalink)
Member # 92688
From what I've been told and read through the years, up to 35 is "rule of thumb" for 1/2 ton axles. With that much horsepower, I'm guessing you will be blowing it apart. I would say for a stock engine and stock 1/2 ton gear, 35's would be your limit. However, you're throwing 750 hp at it. I don't think it's worth the busted parts and repair. I would just save for 1 tons.
If you are hell bent on running said combo, you'll have to baby the throttle with that front end. Just my two cents, but I'm sure more knowledgable people will have more accurate input.
Remember, when your buddies tell you to try it, you are the one having to fix and pay for all the breakage...
Thank you for your services in the 'core.
The internet is evil. Privacy is under rated. People share too much.
bluecrew is offline   Reply With Quote
Old 03-29-2009, 06:14 AM   #6 (permalink)
Member # 116277
Yeah I found a killer deal on a 528, I was gonna go with just a mild dove headed 10:1 .60 over 460, but $3,800 ready to rock and roll is just to good to pass up. Ive got a 14 bolt I can slap in, so I guess I'll just save and put a chromoed 60 in there. Hopefully not to much of a bitch converting it to coil springs and radius arms. Would like to get my truck on the level or pro's eventually with serious axles, some 44 boggers, and soem serious hp. Thinking I can get 850 to 900 on spray with that motor eventually once everything is up to par.
[/QUOTE]
Old 03-29-2009, 06:16 AM   #7 (permalink)
monster30's Avatar
Member # 123871
u need rocks..that much powerthey will blow apart
even with axel upgrades..
monster30 is offline   Reply With Quote
Old 03-29-2009, 08:04 AM   #8 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
you better baby the hell out of it. i ran 1/2 tons under a suburban with 38s and a strong 400ci engine and really had to know how to handle it. ease into and off the gas. no rocks just mud. pretty much the one time i romped it i broke a front shaft. so just baby the hell out of it and you might be fine.
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 03-29-2009, 08:53 AM   #9 (permalink)
TEX
Member # 603
You'll be perfectly fine. You may need to upgrade components in the 9" at some point (a good nodular housing and 35 spline shafts), and you may have occasional breakage, but no way I'd go any bigger than 1/2 ton stuff for 35" rubber. Keep the weight as low as possible to help with durability. A 44 front is pretty much the axle of choice in mud up to 38.5" rubber and horsepower levels even exceeding what you're going to have. A 9" is the rearend of choice even for 44's (40 spline at that point). YOUR issue is going to be traction. You will be hard-pressed to "hook up" on 35's with 750HP.
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 03-29-2009, 09:01 AM   #10 (permalink)
Member # 125564
I say sell the motor, get something with less power, and buy some real axels and tires... your going in reverse on your build..
kymudhunter is offline   Reply With Quote
Old 03-29-2009, 10:29 AM   #11 (permalink)
Member # 79629
Fucking brilliant, lets put rockwells on a truck with 35's.
(Nitpicking) And someone please learn how to spell axle properly.
[QUOTE=Boheefus;9710026] I breathed a huge sigh of relief. I felt like the catcher at an all anal bukkakke party.
[/QUOTE]
mopar redneck is offline   Reply With Quote
Old 03-29-2009, 10:46 AM   #12 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
Tex is right, I know a guy running around 700 on motor through a TTB44 with 38.5x11's up front, and other than keeping up on u-joints(he had the same issue in his previous chassis with a solid 44) he hasn't had any breakage. The thing never hooks up, and thay's why the axles live.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is online now   Reply With Quote
Old 03-29-2009, 10:59 AM   #13 (permalink)
Member # 41097
diddo with tex and 82, keep the weight down, cut the hell out of the boggers, and i would invest in some cheaper chromo shafts and joints for the front, and for the rear i'd look for a good nodular center and some 35spl junk to upgrade to when you find some, but other than that they will be fine, keep the weight down andd play ball.
Couple things that will help the diffs live is to keep the tolerances really tight in everything to avoid shockloading everything, and to pay attention to the u-joints, once they starting getting loose and sloppy change them out.
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
mustange70 is offline   Reply With Quote
Old 03-29-2009, 04:31 PM   #14 (permalink)
Member # 126680
^^^^^What he said^^^^^ You must have bought prosandguys engine?
I don't know what he is doing but, You found one hell of a deal. Drive it with a little caution and you will be fine.
IDIeselman is offline   Reply With Quote
Old 03-29-2009, 04:44 PM   #15 (permalink)
GREEN BASTARD!!!
cslimfu's Avatar
Member # 123458
yeah, it will break constantly. you will be ripping the u joint ears off even with the upgraded shafts.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote
Old 03-29-2009, 06:32 PM   #16 (permalink)
Member # 41097
some of you peeps must not hit the mud drags to often, look whats under 99% of the rails and high horsepower buggies skippin over the top of the mud, usually nothing heavier than a d44, that said they don't typically break a lot of stuff on the track. I see more broken parts on the smaller rigs running 44" rubbers and d60 or guys running 38's and d44's.
Old 03-29-2009, 07:25 PM   #17 (permalink)
Member # 76809
With the 35"s I dont see where you will ever have a problem unless you hit something to stop a tire, but in this case even a 35 spline dana 60 is prone to break. I run a 60 up front with 38.5 boggers and the only breakage I ever have is if I get some air time and come down on one front wheel WFO. I'm still running the 30 spline stubs and very seldom ever break one. One every two years is not worth the upgrade. I drive my shit like I stole it, never back off of it, and launch it hard as hell with the transbrake. FWIW I'd have to say that my Rat is a bit more than you are talking too.
OKMudn is offline   Reply With Quote
Old 03-29-2009, 07:57 PM   #18 (permalink)
Member # 116277
Yeah, working out payments right now, and yeah I feel like its an awesome deal.
[/QUOTE]
Old 03-29-2009, 09:16 PM   #19 (permalink)
78FORD4x4's Avatar
Member # 125311
Location: Sittin' here doin' my part to make sure the welfare checks cash.
Talking
I have a 78 ford with a dana 44 and a 9" (stock shafts) and I run 42" iroks. I haven't broken a shaft yet but I do destroy hubs all of the time. (Warn, Milemarker, and Superwinch) I really dont know how the axles have lasted as long has they have, it must be luck b/c I have put the truck on rocks and held the 400ci wide open with the tires smokin. I am always hard on the gas when muddin and climbing hills. But my engine only has around 300-350hp. I would think with 750+hp you could destroy almost any thing you put under it if you wonted to. Try it and see. As for me, I love showing people what a dana 44 can do, exspeshaly when the say it will fail.
F-the haters. Build it beef and beat it like a red-headed step-child.
78FORD4x4 is offline   Reply With Quote
Old 03-30-2009, 06:21 PM   #20 (permalink)
Member # 113989
i bog a 78 f150 frame with a 49 ford body. 9 inch/d44.38.5 boggers,mild 460.always had problems with u joints breaking.then i got the great idea to put a locker in the front.then it would snap right front axle on every launch. installed a set of warn axles, hubs and a set of ctms,took the locker out and have made 25-30 passes with no problems.launching at 4000! lack of traction is definetly the key factor here.
hillbillykrawler is offline   Reply With Quote
Old 03-30-2009, 06:55 PM   #21 (permalink)
Member # 86685
And he will be running 35 spline rear shafts, superior fronts with ctm joints
44" maximum for his setup
truss the front housing and keep a few spare junkyard 3rd members around until you can get an aftermarket dropout
I hate to even admit that we ran a Ford but it's been over ten years ago that we had a 79 with a 44/9 on 44's with a big block and it stayed together in the mud. half of the time anyways
Old 03-30-2009, 07:44 PM   #22 (permalink)
Member # 128238
You should be fine.
LegendKiller89 is offline   Reply With Quote
Old 03-30-2009, 11:48 PM   #23 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
keep the weight down. that means "PUT THE TRUCK ON A DIET". take out the carpet, the heavy bench seat, the glove box door, the heater assembly, the radio, anything that is not necessary, and make it light!.
at 3000 lbs with a stockish 402/th400/np205 i have already broken a 31 spline 9" rear shaft, which took out the spool bearing and center section bearing cap, as well as a right front stub shaft.
im running chromo shafts in front, too. 38.5 boggers in front, cut 39.5s in the back and 5.13 gears.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 03-31-2009, 10:08 AM   #24 (permalink)
Member # 94747
This has 2000 horse and runs a 9 inch rear 44 front.
the 9 inch is a fab 9 housing with mark williams center section and 40 spline spool and shafts AFTER he got tired of blowing up d60's. The front is an EB lp bj 44. Most of the time with 35 inch cut boggers/ground hawgs. No locker just a spicer power lok and warn iner outer shafts. It did break shafts in front but mostly when the rear would pop and all the power went to the front. Lose a rear drive shaft and wieght & power transfer to the front at the same time. The old early 70's ford lockout hubs are the strongest we ever found even stronger than warn premiums.
jr4x is offline   Reply With Quote
Old 03-31-2009, 10:31 AM   #25 (permalink)
GREEN BASTARD!!!
cslimfu's Avatar
Member # 123458
straight line, no flexing and how much does it weigh?
