Member # 130431
44 tsl question
hey everyone i was just wondering if there any reason why i shouldnt put some 44 tsl's on my 14" wide rims. interco suggest 12" wide but my last tires were 39.5 on some 14 and never ran into problems there besides 30 extra lbs in each rim during mudd runs. thanx 4 input
Member # 603
I ran my 38.5X15's on 15" wide rims & I've seen 42's on 18" wide rims. 20" seems to be the width of choice for 44" Boggers.
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
Member # 603
HIGHLY CONTROVERSIAL
Seen it before a zillion times. Just like you can put a 39.5x15x15 bogger on a 15x7 rim and it works too.
95 Chevy "THE JUGGERNAUT" 74.5x30.5x32s "cut" 16 ton's BIG Inch BBC PG 2-SCS's 4-Wheel Steering 14,000lbs 2008 GMC 3500HD CCLB SRW 6.6 LMM DURAMAX ALLISON EFI LIVE Pro Rock D60 |
one of the reasons they suggest a 12in is so the tires curves in and seals the bead to the rim putting pressure on the bead theres no problem running the rim if your just doin mud justwatch out how much you air downn to.
[QUOTE=R.DesJardin;13358886]Come on man, think about it, a Toyota doesn't have to be built to beat a [B]Jeep[/B]!:eek:[/QUOTE] |
wider the rim the more its going to push out the sidewalls and not allow the sidelugs to bite as much... i run 15x10s with 38.5/15 boggers... its perfect
97 Tahoe soon to have 60/14 4.88s, detroits, 52s, psc hydro assist, 38.5 boggers 02 F250 7.3 fx4 |
#9 (permalink) | |
Member # 1724
I am sure its been done... but certainly not the width of choice. I would say 14" would be closer to the width of choice around here. Last edited by four_by_ken; 04-09-2009 at 03:28 AM. |
#10 (permalink) | |
Member # 603
www.probadd.com for pics
#12 (permalink) |
Member # 130431
it will be doing a little timed mud bogging but mostly trail riding (no rocks). and im not too worried about the side lugs anyways the only time i need them is over 2' of slop and im sure they do there part. no bead locks were im at were im at ive never ever seen real bead locks besides drag cars/trucks.o well im ordering them tommorow if someone could explain how to post pictures id show it off. the only reason i started this post is my last set up (39.5) were on 15" wide rims and the sidewalls started cracking.
#13 (permalink) |
Member # 127909
the cracking is in there from the factory.... if your talking about the slices in the bead that looks like a razor blade slipped around the bead in a few spots.
only time I haven't seen that is with the new 44's for 16" diameter rims. The rim size they post on their site is typicaly the minimum they recomend Last edited by Brent Foster; 04-09-2009 at 03:14 PM. |
#14 (permalink) |
Member # 127909
http://viewmorepics.myspace.com/inde...mageID=8654188
http://viewmorepics.myspace.com/inde...4086&i=8654221 Mine were cracked...... got wrinkled up regularly and are still fine Last edited by Brent Foster; 04-09-2009 at 03:19 PM. |
#17 (permalink) |
Member # 130431
dunno he putem on a 350 yota and broke somthing and sold it. one of them rich boys that just wanted a big truck and nuthing that comes with it.but i ordered the 44s today they were just out of stock and i have to wait on interco, they said arund the 21st. hey brent what kinda math did you do when gearing different tire sizes front to back
#18 (permalink) |
Member # 127909
(RPM x tire dia.) / (total gear ratio x 336) = MPH
I just run through the ratios till i find less that 2% overdrive in the front. then you can have custom gears cut for the transfer or run different sprockets on a chain drive to get the correct total gear ratio to the front. Mark Williams website has some real nice gearing calculators to help with that also. |
