Fullsize wheeler
Member # 83301
Which winches
hey guys thought this would fit better in the mud forum.
So for my trail truck etc im planning on putting a rear mount winch for major stuck recoveries, and who knows occasional log skidding. I have a chelsea pto and a hydro pump. My question is would you rather have a pto winch or a hydro winch(driven by pto pump)? My current thoughts are pto(i have all the parts) hydro would force me to get a control valve, tank etc |
Member # 65941
My buddies and I use the 5ton garwood winches from the front of the 6X6s and they work great. At idle they either pull out whats stuck or start ripping shit in half.
In Akron OH there is a company called Adelmans Truck Parts, they are a wrecking yard for big trucks. We bought ours there for $295 a peice and they came filled full of good cable. That was a year or so ago. Any place that has rockwell axles or 6X6s should have some. It really depends on your mounting situation. Its a lot easier to run hydraulic hoses than a straight drive shaft. But on the other hand, you'll have to mount a hydraulic tank somewhere under the body. As far as cost goes, I had more in my pto shaft than I did my winch. 2 ujoints, 3 yokes, 1 slip yoke, 1 or 2 carrier bearings and shaft cost a little more than $375. I'm not sure what you'll have in a tank, controller, fittings and line. Hope this helps, Dave. Last edited by wvmudder1; 04-09-2009 at 12:18 AM. |
Member # 106806
PTO would be easiest and most cost effective it seems.
But it limits you to only one winch, rear in your case. Hydro would allow you run a winch front & rear. Also you dont have to rely on the clutch for engaging/disengaging the winch and you are limited to engine speed (iin most cases) to regulate winch speed. Hydraulics would allow you independant speed controll of the winch. You are also able to feather the winch to allow for fine controll of line speed, inching it in and out. But a tank, spool, hydro motor and hoses are not cheap, ad an easy $1000 to your build. I run hydro front & rear and figure I'll be $4000 into it. Cost and ease of maintenance the PTO setup wins. For versatility, controll and possibly speed the hydro takes it. I feel that both are in most situations superior to electrics.
my build: [url]http://ovo.ca/forums/showthread.php?t=867[/url] |
Fullsize wheeler
Member # 83301
i have a winch but its only one gear. so depending on which way the pto spins...means either in or out. the pto i have is alos one way its either engaged or its not.....what i havent detirmined is whether it will mount on my sm465 or my 205....any insight? it has helical cut gears...
