#56 (permalink) |
updates . . . well kinda of crappy, dyno guy lost both of his grandparents in a motorhome accident beginning of this week, soo no dyno time till next friday/monday, and i can't wait that long, as i'm racing saturday.
The headers are gonna be a pain to make fit, as the steering needs to be re run, and the brake booster needed to be removed (which i've already taken care of, need to get some u-joint for the steering though). Ened up having to switch over to electric fuel pump, soo new fuel cell, filter, pump, regulator, all new line, bunch of fittings, ends up being expensive, still need to port match the headers and pound out the tubes around the bolt holes, need to rig up some throttle linkage as the predator runs a funky setup, need to rewire the hole truck for the msd shit, shouldn't be to bad, but time comsuming. Anyway its been a long last couple days and it'll be even longer tomorrow, soooo i'll keep this thread updated, peace out.
90' C350 AKA 4 door 1 ton Bronco 96' Ranger: kings, EMF parts, 800hp SBF |
#57 (permalink) |
Member # 90970
Can't wait to see the end result. I too am using the boat anchor/ 400 in my truck. It's bone stock with an edelbrock intake, carb spacer, holley dp and some summit headers. I'm currently cleaning up a different 400 (f'd up the on in the truck). Seems like a decent motor. I'd like a 460 but I have the gears to run the 400 for now.
![]() Good luck
Big Gay '79 F250 2 1/2 ton on 53s Last edited by drthunder33; 08-02-2009 at 06:24 PM. |
#59 (permalink) |
Alrigty had an awesome first outing, had the fastest non rail(blowers nitrous and cut boggers/paddles type of rigs) run of the day, i had no issues with all the new crap i put in the rig, but i do have some issues, anywho i came to found the msd doesn't like my autometer tach and petronix rev. limiter due to the way it gives the signal to the coil, soo i swap the tach to run off the msd 6a box, and i still haven't got the rev limiter to work, gonna try to swap a couple wires around and it should be good to go, if not i'll have to drop some more coin and get something that will work with the msd.
Carberator, well i ran into issues, it was all gummed up, wouldn't give fuel over 3000rpm and it fell flat on its face, sooo i tossed the 750 demon back on it to get it running, and its definately too small, so i have to get the overhaul kit and get the carb rebuilt. I got the brakes and the steering all sorted out and working better than before soo thats good. but yeah heres a vid of the truck at idle, and i'll be uploading 2 more vids tonight as well: new motor - Car Videos on StreetFire
#60 (permalink) |
Member # 126500
throw the msd in the garbage!!! i had a msd6al on mine, it made it 167 miles.
it was still under warrent and msd wouldnt do anything about it. so i replaced it with this. http://www.malloryperformance.com/Pr...minselection=0 its a lot of coin, but its got 3 rev limiter, 3 stages of retard, etc, etc. its the best ignition i have ever had.. ever
#65 (permalink) |
you said u where looking for a place that makes upright headers try
http://www.decheaders.com/shop/index...h=64_66_79_106 and if you wanna make ur own summit makes header flanges but it looks like u got it taken care of im a bit late Last edited by ButtNuttN8; 08-04-2009 at 07:04 PM. |
#68 (permalink) | |
#70 (permalink) |
lol still haven't grabbed the cam card, anywho a couple more vids:
Cardston Mud Bog run 2 - Car Videos on StreetFire cardston mud bog run 3 - Car Videos on StreetFire cardston mud bog - Car Videos on StreetFire The one vid you can hear where i loose fuel pickup, so i'm gonna have to do something about that. Also in the one where i launch in to high of a gear i was fully convinced that the old snorkle setup had to go, i was running the spectre single 4" inlet goodies, and its just way to restrictive for my motor, so i grab a 5" tight radius exhaust elbow, followed by a rubber coupling and a rubber 45* elbow and made a new snorkle. The rubber coupling fits perfect over the carb in place of the old spectre unit, then i shoved the 90* bend in the coupling with the 45*elbow connected to that with a short length of 5" muffler pipe with a big ass dry washable filter on the other end of the pipe. It made a BIG difference, truck even idles better with the bigger intake on the thing, aside from the size increase the smoother radius bed leading into the carb throat should increase power as the spectre stuff is just to restrictive on bigger motors.
#73 (permalink) |
Member # 141654
i know this is really late but www.schoenfeldheaders.com is a good place to get lots of headers... runnin updrafts from them on a 360 mopig in a dirt drag truck... they seem to work pretty good and look great... just figured id try to get that info out there...
http://www.pirate4x4.com/forum/showt...928&highlight= |
#75 (permalink) |
got the videos uploaded:
millk river mud bog first run - Car Videos on StreetFire YouTube - Cardston mud bog run 1 YouTube - My last run in cardston YouTube - missed shift run in pollockville YouTube - Cardston mud bog run 2 YouTube - Pollockville mud bog in truck vid
