Big or small??!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 07-12-2009, 10:20 AM   #1 (permalink)
Member # 125564
Big or small??!!
I have finally colected more then enough parts to build a comp. truck.. Nothing outragous, but a st. s class.. But my question is.
What is the best/ cheapest way to go for motor? I have quite a few rebuildable SBC's, as well as a 454, with performer cam, intake and carb with a set of headman headers.... I am going to tear down either one and do a once over (no machine work needed in either the bottom ends).
I know that a SB can rev alot quicker, and is lighter, but there is always that crowd that says there is no replacement for displacement.
If I run my BB I can run higher gears (3.73's) and still have the power to run, but all the local (ford boy's) suggest a small block because they will wrap up tighter.
insert input.
kymudhunter is offline   Reply With Quote Quick reply to this message
Old 07-12-2009, 12:53 PM   #2 (permalink)
Member # 122868
what size tires?
what t-case?
what tranny?
should be a fun build
I left the 4x4 world a while ago...
Thinking of going back.
JOKER4X4 is offline   Reply With Quote Quick reply to this message
Old 07-12-2009, 12:56 PM   #3 (permalink)
Member # 125564
38's, TH350 with NP205
Old 07-12-2009, 03:01 PM   #4 (permalink)
Member # 124760
Smile Good luck
SBC
All we run are well built SBC's and hang with the BB's all day long
That's how we roll
[QUOTE=randy92782;14030638]Yup us mud people are coming to the city next :flipoff2:
[/QUOTE]
[QUOTE=MUD SLUT;12001456]
As they say, "Ain't no party like a Trucks Gone Wild party, cause a Trucks Gone Wild Party just don't stop!!!"[/QUOTE]
Train Horn is offline   Reply With Quote Quick reply to this message
Old 07-12-2009, 07:08 PM   #5 (permalink)
Member # 128238
This should be a fun build.
LegendKiller89 is offline   Reply With Quote Quick reply to this message
Old 07-12-2009, 09:40 PM   #6 (permalink)
Member # 41097
if your running anything deep you'll want the big block, espically with the auto, cause if you grab a gear then have to drop back, the small blocks don't typically have the tq to get shit moving again.
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
It'll only be bigger, better, & tougher next year
mustange70 is offline   Reply With Quote Quick reply to this message
Old 07-13-2009, 08:17 AM   #7 (permalink)
Member # 138463
I agree, small block ain't gonna cut it if the mud is thick and deep. I had a sbf for many years but after I went to the bbf, I saw the light!! My BBF is built up alot more then my sb was but my 532 revs up WAYYY faster then the sb ever could, but I also have the right parts to make it happen.
Hillbilly Rockstar is offline   Reply With Quote Quick reply to this message
Old 07-13-2009, 11:14 AM   #8 (permalink)
TEX
Member # 603
Kinda depends. Say a 406" smallblock vs. a 427" big-block, I'd go mouse all the way. If it's 350 smallblock vs. 509" big-block.......
See what I'm getting at?
Maybe more important at this point is to pick the right TRUCK. I see more '73-'87 GM longbeds than just about anything else at the races, and they're probably among the worst possible choices due to the weight of the things. Toss in the 3/4 or 1-ton running gear that's pretty much a requirement on a truck that heavy, and now you have the handicap of too much weight AND too little ground clearance. Shortbeds & Blazers are much lighter, older (pre '73) & newer (post '87) body styles are also lighter, and mini-trucks & Jeeps are WAY lighter (though not always permitted in some of the lower classes with V8 swaps).
My advice, don't turn a wrench until you have a solid PLAN in place.
Thanks to:
Extreme Performance
Bear Creek Auto Recyclers
TEX is offline   Reply With Quote Quick reply to this message
Old 07-13-2009, 04:02 PM   #9 (permalink)
Member # 125564
I have the choice of either a short bed, of long bed (circa 73-87). I am leaning more towards the long bed though. The short bed are more popular around here, but when running 300 FT, in the rough, they can get a little squirrly.. But I didn't really think of the weight difference. I will keep that in mind, thanks for the input.
as far as engine comparison, it's either a MILD 454, or gonna be a MILD 350.. nothing major until I see a reason for it. Just trying to get my feet muddy at the moment. Thanks for all the input fella's.
Old 07-13-2009, 06:20 PM   #10 (permalink)
Member # 138463
if both are mild, then you might as well go for the bigger cubes. Anything that can be done to a small block for big power numbers, can be done to a big block for absolute insane power numbers.
Weight is definitly a factor that needs to be looked at. If 90% of the other trucks are the same long bed style trucks, then it might not be a big deal, but you start gettin into the higher classes and it becomes a huge factor in winning or losing.
Old 07-13-2009, 06:48 PM   #11 (permalink)
Member # 41097
on thing i see a lot of guys do with long bed truck is gut all the inner panels out of the body skins, this in itself will loose a couple hundred pounds in itself. Another thing thats done is bobtailing the rear, as in choppin everything off at the rear shackle mounts.
Old 07-13-2009, 07:20 PM   #12 (permalink)
Member # 125564
I don't plan on getting into the pro stock, or even modified classes.. Of course, When I built my trail truck I didn't plan on having tires bigger then 35's on half ton gear. But now I'm at 42's on 1-ton's. So I know that eventually I will want just a little more. I believe that I will go with the big block... To compensate for the slower revving motor, I will be able to run high gears in the axel.. (3.73's I reckon).
On another note, I know that in a perfect world I would have a TH400 to run behind it... but I don't. Any pointers on making my TH350 survive? I already have an aftermarket trans cooler. any other suggestions? as far as kit's or certain stall ratings? Thanks in advance.
Also, by chance does anyone know of a good sight to do more research on for a strictly mud truck?
Old 07-14-2009, 06:54 AM   #13 (permalink)
TEX
Member # 603
Go with the shortbed. 117" is plenty long. And I'd do the big-block.
Thanks to:
Extreme Performance
Old 07-14-2009, 06:56 AM   #14 (permalink)
TEX
Member # 603
Gotta be careful with that stuff or you'll wind up in a class with these guys:
Thanks to:
Extreme Performance
