tractor tires or not - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 07-30-2009, 05:50 PM   #1 (permalink)
Newbie
farmerjake's Avatar
Member # 131035
I got a set of 15.50R38 any body run these? I am runnin 2.5 rocks with 49s is it worth the hassle to switch? They are about 62 inch tall and about 16 wide how much more power will they use? They are not as wide as my IROKs so I'm thinking they cut the mud better and not try to push through, never run tractor tires on a truck just a tractor.
farmerjake is offline   Reply With Quote
Old 07-30-2009, 07:37 PM   #2 (permalink)
Member # 125564
you answered your own question in m opinion...
that just makes them gay.
and this is coming from a guy who REALLY likes mud trucks..
kymudhunter is offline   Reply With Quote
Old 07-30-2009, 07:37 PM   #3 (permalink)
Tradin' Fool
76j20's Avatar
Member # 91612
I dont run tractor tires, but i am not a big fan of them on other trucks. I am fixing to be running 52" michelin xl's after i get my rocks installed. I was running 1 tons and 44's til i blew out a pinion bearing and said forget this and am going with the rockwells....
76j20 is offline   Reply With Quote
Old 07-30-2009, 07:51 PM   #4 (permalink)
kensdodge1's Avatar
Member # 90498
now runnin 18.5x16.1 ags on my power wagon i love em they work frigin great
kensdodge1 is offline   Reply With Quote
Old 07-30-2009, 07:56 PM   #5 (permalink)
Newbie
farmerjake's Avatar
Member # 131035
seems like there is a lot of people running them for the deep stuff. How big are 18.5x16.1s?
Old 07-30-2009, 09:19 PM   #6 (permalink)
Member # 123509
well the tractor tires are sometime a little more narrow and with the really agressive tread you can dig down and find traction. Plus you get the height for the more diff clearence, but the A LOT less center of gravity.
1979 Chevy K10 4x4 soon to be 4inch lift with DANA 60 14FF, 205
chevyforlife502 is offline   Reply With Quote
Old 07-31-2009, 06:07 AM   #7 (permalink)
Member # 15354
Send a message via AIM to iniviate
you will need aftermarket axle shafts or 5 tons to run that tire.
they will make your iroks look silly.
once you make the switch, you won't run a DOT tire in the mud again.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote
Old 07-31-2009, 03:39 PM   #8 (permalink)
Newbie
farmerjake's Avatar
Member # 131035
thanks for the reply iniviate its good to hear from someone running 62s and not just telling me look stupid on a truck. Do you think a 38 inch wheel is to big it seems like everyone is running a smaller wheel around 30 inch, is more side wall good or bad
Old 07-31-2009, 04:29 PM   #9 (permalink)
Quit looking
Belooky's Avatar
Member # 138061
From mud racing atv's my experience is that more sidewall give slightly more flex and more air capacity which equals more flotation. I prefer big wheels with small sidewalls.
Altman's Racing
1996 f250 D60, 10.25, 557bbf, bottle fed by giggle gas
Belooky is offline   Reply With Quote
Old 07-31-2009, 05:46 PM   #10 (permalink)
GREEN BASTARD!!!
cslimfu's Avatar
Member # 123458
ever wonder why top fuel has a small wheel and crawlers air down thier tires? traction. with a short sidewall it wont flex and grip. not to mention if you have a very short side wall and hit a sharp object, the side wall hits the wheel and cuts it and you have a flat and bent wheel.there is also too much side wall. it has to be relitive to the application. a 38'' wheel with a 42'' tire is no good just like a 10'' wheel and a 72'' tire is no good either. just my 0.02 worth.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote
Old 07-31-2009, 07:26 PM   #11 (permalink)
Newbie
farmerjake's Avatar
Member # 131035
with less sidewall are you more likely to blow the bead? with 62s and a 38 inch wheel you still get a 12 inch sidewall. Maybe I'll look around for some V treads in the 50 to 55 inch range I'm sure I can find something.
Old 07-31-2009, 09:12 PM   #12 (permalink)
GREEN BASTARD!!!
cslimfu's Avatar
Member # 123458
no. i didnt say blow, i said cut. wow, that sounds bad.
Old 07-31-2009, 10:47 PM   #13 (permalink)
Member # 125564
t-tire or no... the point is that running a 36" rim is stupid... it will be hand made, of cheap material, and when you do bend it... and you will.. you will have to TRY to find another case stout enough to run your tires and when YOU DO it is going to cost you like gold pussy... DOT is the only way to go if you OWN a REAL TRUCK
Old 08-01-2009, 12:53 AM   #14 (permalink)
zukibrothers's Avatar
Member # 26165
Send a message via Yahoo to zukibrothers
i do not run tractor tires, but wish i did. Alot of the guys in my club are starting to run them, they work much better then those silly DOT tires.
True procrastionation is the art of putting a task off until it doesn't need to be done anymore.
zukibrothers is online now   Reply With Quote
Old 08-01-2009, 11:29 AM   #15 (permalink)
xjtony's Avatar
Member # 50866
I'd like to have some tractor tires.... In the 48+ range
I wheel on the interweb.
xjtony is offline   Reply With Quote
Old 08-01-2009, 07:22 PM   #16 (permalink)
Member # 15354
why would you hand make a wheel when you could just run a tractor wheel?
i had $1800 in my 49" tractor tires and professionally made 24" wheels, both brand new.
how much are brand new 49"+ DOt wheels and tires?
....... and the tractors will out pull any DOT tire around in mud.
bring on any DOT tire you want. i'll come get you when you get stuck in the kiddy hole.
please come back when you know what you are talking about.
Old 08-02-2009, 04:00 AM   #17 (permalink)
DWT
Member # 19850
Don't hold your breath, my assumption is it'll be a looooooong time til that boy knows what he's talking about.
I run DOT's but once I find the AG tire I want in the right compound I'll run them at all times. Even with a mighty 22re pushing them.
Polaris 800 triple powered Odyssey. 150 hp of death underway. :grinpimp:
Taiwanese Garbage should stay in Taiwan.
DWT is offline   Reply With Quote
Old 08-02-2009, 08:07 AM   #18 (permalink)
Back Woods's Avatar
Member # 74825
go to an old junk yard and find some old tractor wheels that fit. if you bend them, keep running them anyways.
Back Woods is offline   Reply With Quote
Old 08-02-2009, 09:20 AM   #19 (permalink)
Member # 135248
Will a 16.1 tractor tire fit on a 16 or 16.5 rim? What are guys doing for rims on big tractor tires?
fastlt1 is offline   Reply With Quote
Old 08-02-2009, 09:30 AM   #20 (permalink)
Member # 15354
i've seen poeple run them on 16" wheels, but i don't know if it's safe or not.
they're using tractor wheels.... i don't understand how hard this is to understand.
tractors are heavier than mud trucks and are designed to be worked. the wheels aren't going to fail.
Old 08-02-2009, 09:57 AM   #21 (permalink)
Newbie
farmerjake's Avatar
Member # 131035
hell yeah some feed back worth somthing coming from some people running tractor meats. What is really stupid is how you get feed back from guys who have never run tractor tires. Guys who have never run them tell me they look stupid and then guys who do run them say they are badass I have never heard from someone who has made the switch to tractor tires say they were going to switch back to DOTs. If im getting stuck with 49s then its time for more power and bigger meats and for the price of 54 boggers you can get sweet v treads.
Old 08-02-2009, 12:00 PM   #22 (permalink)
xjtony's Avatar
Member # 50866
there is no difference in a 16 truck tire and a 16.1 tractor tire as far as rim goes. Ive seen the small ag tires on 16" wheels on trucks before.
Old 08-02-2009, 03:03 PM   #23 (permalink)
Karnage
spidr's Avatar
Member # 55444
I don't know how true it is, but I was told by a tire rep once upon a time that the .1 was meant to deter people from non DOT tractor tires, on light trucks and such. Kind of an instant acknowledgement that it wasn't DOT.
Sometimes you just gotta step back and take a breather.
spidr is offline   Reply With Quote
Old 08-02-2009, 06:53 PM   #24 (permalink)
Member # 128238
I'd rock tractor tires... just do it man. You don't hear people ever complain because they have tractor tires on their' rigs.
LegendKiller89 is offline   Reply With Quote
Old 08-03-2009, 06:16 AM   #25 (permalink)
Member # 15354
despite trying to be the typical pirate asshole, you're spot on with that comment.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
