Who has a sm465 tranny - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 08-05-2009, 02:02 PM   #1 (permalink)
mackdaddy's Avatar
Member # 112489
How do you like it? And how does it perform in the mud. I've got one and debating on whether to use it or not. I've heard it was a slow shifting tranny with a big gear ratio spread and may not be the best choice in the mud. Any help or opinions needed. Thanks
Mack
mackdaddy is offline   Reply With Quote
Old 08-05-2009, 04:05 PM   #2 (permalink)
OUTLAW MOTORSPORTS
4doorchevy's Avatar
Member # 69112
you for sure ant gonna speed shift it but it is tuff as hell. iIhad one in a 4door crew cab chevy on rockwells for bout five years and only tore the reverse gear out one. Took it out to put an auto in and have hated it ever since. Just my 2 cents
97 tj 6.0 nv4500 241c on tons in the works
4doorchevy is offline   Reply With Quote
Old 08-05-2009, 04:45 PM   #3 (permalink)
Member # 88939
Tough as nails thats for sure. The adapter between the tranny and t-case is the weaklink.
Great for crawling and trails but man it is really tough to find a gear that works perfect in the mud and sand. And yeah, it shifts like a tractor.
That being said, 1rst gear (not granny) in high seemed to work great.
If off-roading is outlawed, then only outlaws will off-road.
Let us speak courteously, deal fairly, and keep ourselves armed and ready. Theodore Roossevelt
Rekless_Off_Road is offline   Reply With Quote
Old 08-05-2009, 10:59 PM   #4 (permalink)
Karnage
spidr's Avatar
Member # 55444
I like them
The thing to remember is that you can get away without axle gearss because of the bull low, and they will take nearly everything you can throw at them.
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is offline   Reply With Quote
Old 08-06-2009, 06:52 AM   #5 (permalink)
POS
chev85k10's Avatar
Member # 118893
Great for trails and what not but hated it in the mud. Couldnt find a sweet spot.Big power and big tires tear em up just like everything else. Ive snapped one 10 spline and two 32 spline outputs. Maybe because of a big block and to much commitment..just my opinion tho. Cheap and easy to work on.
chev85k10 is offline   Reply With Quote
Old 08-06-2009, 07:46 AM   #6 (permalink)
HAWGWILD's Avatar
Member # 89954
manuals and mud dont mix!
JIM MACE
www.hawgwildmt.com
HAWGWILD is offline   Reply With Quote
Old 08-06-2009, 09:06 AM   #7 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
1st gear (not L) works pretty good for me in the mud. I like the fact that you don't really have to worry about them overheating like an auto.
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 08-11-2009, 12:26 PM   #8 (permalink)
Member # 109601
does fine, but tend to loose a little momentum from gear to gear in a long stretch of muck, i would start in 2nd dump it and go, shift to third keep it at 4-5000rpm and keep the tires clean, and hope for the best. like said above NO SPEED SHIFTING. i never did a timed run or anything just out playing in my pit mostly.....
nvrsatisfied is offline   Reply With Quote
Old 11-27-2009, 12:23 PM   #9 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
I wish reverse was numerically higher ratio. Hard to get any wheelspeed out of it esp. in low range
Almost think a HD 3 speed would be better sometimes
I do love the strength and the no-overheat, that's a huge plus
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote
Old 11-27-2009, 12:49 PM   #10 (permalink)
Certified E-Thug
montecarlo31's Avatar
Member # 117771
My best friend has a 1979 Chevy 3500 DRW w/ a dump bed on it. He's got a 454 BB w/ Cam, heads, headers. running to a SM465 to a 2 speed transfercase to 4.56 gears on 35" tires. The truck is just a work truck but runs great with the granny gear, it can just lope a load of logs up a hill in mud without issue. As mentioned it's bullet proof and you can't overheat it.
montecarlo31 is offline   Reply With Quote
Old 11-27-2009, 08:33 PM   #11 (permalink)
Member # 92688
Running one in a mild mud truck. Can't speed shift to save your life. Tough as they say. 1st (granny low) is nice. I wheel in 4hi 2nd gear. No overheat worries and bulletprooof-ness is worth it all to me. I only wheel it in the mud anyways, so I pick a gear and run it til the fuel's gone!
The internet is evil. Privacy is under rated. People share too much.
bluecrew is offline   Reply With Quote
Old 11-28-2009, 05:04 PM   #12 (permalink)
Certified E-Thug
Member # 117771
You can say that again. If you try to speed shift these they only hurt your feelings and ego.
Old 11-28-2009, 08:47 PM   #13 (permalink)
Member # 92688
THAT made me laugh spitting bacon all over my lap. True, which makes it all that more funny. So very true. Anyone who's run one, knows, you WILL not pick up chicks while trying to drag race! (because that's what you do with a 465, right?)
Old 12-06-2009, 03:48 PM   #14 (permalink)
flatblack83's Avatar
Member # 121277
I drove mine in mud boggs for years, speed shifting it tho mine got jammed up and had to be rebuilt, too many beatings i guess with a medium built small block. Its tough tho paired with a 205 its unstoppable....
flatblack83 is offline   Reply With Quote
Old 12-08-2009, 07:55 PM   #15 (permalink)
fuck off
randy92782's Avatar
Member # 102123
I've ALWAYS ran a 465 in the mud. I loved it except i got a bunch of mud shoved up in my clutch and when i tried to push it in i bent something. Never could figure that out so i pulled it.
Now i built an auto to try out. I'm gonna regret it though I think
Originally Posted by monkeyevil View Post
Tranny's are the gateway drug to gay.
72 Chevy 454/465/205 33's
89 Chevy Suburban 454TBI/400/205 6" Procomp lift on 37's
94 Chevy ext. cab 350/4L60e/241 6"BDS lift,35" MTZ's
randy92782 is offline   Reply With Quote
Old 12-08-2009, 09:31 PM   #16 (permalink)
bigal1's Avatar
Member # 119174
I ran one with tons and 456 gears,205 case and a mild sbc.It was the best tranny for the mud I ever used.I had 44s on it also,the gear combo that worked for me was ,205 in low and trans in first,not granny.And mash the gas,I never shifted.I dont know why the fawk anyone would try to shift gears through a mud pit.You find the right gearing that allows you to control engine rpm and tire speed ,floorboard that fawker till it wont go no more....thats how I played in the mud.
bigal1 is online now   Reply With Quote
Old 12-09-2009, 04:42 AM   #17 (permalink)
Member # 121277
I have to start out in 2nd and stand on it then to 3rd, i cant do 1st since i have to shift too soon. I have 465/205 tons with 456s and 39s. But also thats with the t-case in high...the wheel speed helps, I can usually use 2nd and go up to 5500 and shift to 3rd and keep the rpms at 5000 or so until its thick then back to 2nd....usually does real well.....maybe with a stocker or close to stock 350 id use low in the t-case. Now my 465 has the usual L-1-2-3.... the first 2 just make rpms...( my 350 is a lil potent tho 453 dynoed hp)
Old 12-09-2009, 10:32 AM   #18 (permalink)
Member # 46184
They are tough and reliable I have been abusing mine with
580hp and 611ft/lb's. They are far from a cadilac but they will get you home.
01 CTD
84 k30 supercharged 496
85 Toy front clip and some DOM
[COLOR="Lime"]Team Pirate 2009 Baja 1000[/COLOR]
simmons3067 is offline   Reply With Quote
Old 12-15-2009, 10:09 AM   #19 (permalink)
Jules083's Avatar
Member # 123683
Like everyone said. Hard to shift fast but bulletproof. I liked mine, granny first was good for driving around tight spots and not having to mess with the clutch, pick a higher gear for the mud. I'm running a C6 in my build now, might someday put a 465 in it.
Jules083 is offline   Reply With Quote
Old 12-17-2009, 11:08 PM   #20 (permalink)
Member # 137644
Send a message via MSN to HEAVY METAL
4hi 2nd gear with a bbc is mint!
WHEELIN A P40 WARHAWK
HEAVY METAL is offline   Reply With Quote
Old 12-18-2009, 06:18 AM   #21 (permalink)
Member # 99971
I'm running a sm465 behind a 383 stroker in a 77 short bed chevy. 1 tons with 4:56 gears and 46'' Michelins. Really tuff!!!!. I've destroyed two clutches (gear droppin), but never hurt the trans. Make sure you have the dust shield on or it will pack the clutch with mud, been there,done that. Long as you're just playin and not racin, the sm465 is great
LA77CHEVY is offline   Reply With Quote
