chevy auto people - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 08-09-2009, 01:20 PM   #1 (permalink)
fuck off
randy92782's Avatar
Member # 102123
chevy auto people
what are you running in your mud truck?? I have a 350 turbo/205 in my truck now but hate autos. Since it's already set up for one i wanna just keep it instead of changing it over to manual like i normally would do. I have 2 465/205's.
Anyways the tranny needs re-built but idk if i should just re-build the 350 or buy a 400 with the same spline output as the 350 to mate to my 205 and build that.
If you run the 350 what did you guys have done?? I know i'm gonna need a stall but have never built a automatic before for this.
The truck:'80 Chevy shortbed 410c.i sbc looking to get around 400-425hp
6"lift and 35-37's
randy92782 is offline   Reply With Quote
Old 08-09-2009, 11:20 PM   #2 (permalink)
dfl701's Avatar
Member # 126764
if you hate your auto that bad then just go ahead and swap the 465 in. sounds like a no brainer. the 465 can handle some power
83 k5 with typical rust
dfl701 is offline   Reply With Quote
Old 08-09-2009, 11:31 PM   #3 (permalink)
______________
Corey Young's Avatar
Member # 21622
The TH400/205 has different input/output splines from the TH350/205. Sell the TH350/205 and put in a TH400/205.
Corey Young is online now   Reply With Quote
Old 08-10-2009, 08:51 AM   #4 (permalink)
fuck off
randy92782's Avatar
Member # 102123
Well i hate autos but my dad said i won't be happy with the manual. that's why i looked into building an auto. Plus i don't really like the gear change from 2nd to 3rd gear on the 465
I may do this if i can even find one. Kinda figured they'd be different for some reason
Old 08-10-2009, 09:14 AM   #5 (permalink)
you pinko commie fag
Honky Lips's Avatar
Member # 67732
i have 550 hp and nitrous on my k5. 38.5 boggers, 4.11 gears. 208 xfer case. my th350 has aftermarket sprag gear, red clutches and bands. manual valvebody. ultrabell bellhousing. holding up fine so far.
THIS SPACE FOR RENT, INQUIRE WITHIN
Originally Posted by jettscott View Post
That guy can go fuck himself with whatever power tools he has left.
Honky Lips is offline   Reply With Quote
Old 08-10-2009, 11:50 AM   #6 (permalink)
fuck off
randy92782's Avatar
Member # 102123
Alright then. Another question for ya. How much you have put into your tranny? I had no limit but since i can't stay out of trouble i guess i do now I'll just have to get a job now
Old 08-10-2009, 01:42 PM   #7 (permalink)
TEX
Member # 603
Most guys I know are happy with their TH350's. That's what I run.
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 08-10-2009, 04:59 PM   #8 (permalink)
Member # 106427
You shouldn't have any troubles with that 350 with what you are running. Get a good rebuilt kit, and I like to run the B&M transpack which turns it into a manual valve body with very firm shifts, holds any gear at any rpm and will down shift likewise. Quicker than you will ever shift that manual.
later
jenks
jenks21 is offline   Reply With Quote
Old 08-10-2009, 05:19 PM   #9 (permalink)
fuck off
randy92782's Avatar
Member # 102123
Right on. Thanks for the advice. Just saved me a little time and money there
Old 08-10-2009, 06:10 PM   #10 (permalink)
______________
Member # 21622
TH350= aluminum case lugs wear out, TH400s are designed better and stronger.
TH350/NP205 adapters break, TH400/NP205 adapter is designed better and stronger.
TH350/205 use a internally splined coupler (27 spline), Th400/205 use no coupler and bigger splines (32 spline).
TH350s have a 4 bolt tailhousing, TH400s have a 6 bolt tail housing.
A TH350 is a 1/2 ton trans and a TH400 was used in the military 1 1/4 ton CUCV trucks.
TH350, no thanks!
Old 08-10-2009, 07:57 PM   #11 (permalink)
fuck off
randy92782's Avatar
Member # 102123
TH350, no thanks!
Well shit! You guys just can't make up my mind. Appreciate the info there Corey. I think i'll probably never tear up the 350 but i'll keep my eyes open for a 400/205 just in case
Old 08-11-2009, 11:21 AM   #12 (permalink)
the_white_shadow's Avatar
Member # 103621
Kind of off topic. Is there anyway to lengthen the stock kickdown cable on my th350 or do i need to purchase a new Lokar cable or somthing similar. Do I even need to run one?
my truck will see mud, trails and few rocks, and It will not be driven on the street.
Thread High Jack over.
--Alex--
1982 Toyota 4x4 - The Dirt Squirrel: Phase II underway: 4.3L CPI, TH350, Marlin 4.7s/D300 doubler, D60/14B/5.13s, f150 leafs up front, artec 4-linked rear, Coilovers, blah, blah blah.
the_white_shadow is offline   Reply With Quote
Old 08-11-2009, 12:03 PM   #13 (permalink)
Member # 109601
i ran a 465 with 411 gears on 38" tires. did great BUT the only draw back was at times you can really kill the momentum from gear to gear...that was my only complaint and the clutch slipped a few times..... the granny gear is great, also if you are going to do dirt drags i think it would do fine, but in a long stretch of slop you tend to loose a little momentum....i would go with a good or modified Th400, and start slap shifting. i have pulled my sm465 and put in a TH400, but i have also upgraded my project to different means.
just my opinion...........................................
nvrsatisfied is offline   Reply With Quote
Old 08-11-2009, 02:37 PM   #14 (permalink)
Member # 106427
Here is another thread along the same lines you can read through.
http://www.scotts4x4.com/forum/viewt...hp?f=59&t=8336
later
jenks
Old 08-11-2009, 04:00 PM   #15 (permalink)
fuck off
randy92782's Avatar
Member # 102123
later
jenks
Thanks for the link. Pretty interesting stuff there
