Member # 133449
Coating your sensors to protect from water/mud?
In the past month and a half I have went through two TPS's. I know I can coat my sensors with dielectric grease, but I don't really know what kind/where to get it?
What do you guys use? Also, I used some permatex gasket sealer on the seam of the new TPS, think that will hold up? |
#2 (permalink) | |
fuck off
Member # 102123
#3 (permalink) | |
Member # 37859
That should work. Use just enough to seal it. not so much that it runs inside there and onto the sensor. If water can't get in, it can't affect the sensor. |
^Hates Liberals
Member # 80854
Dielectirc grease is your best bet. You can pick up a can at your local parts house for around $8-$9. Do every connection that you can get your hands on including plug wires. Dont go too crazy with the amount, because too much can often effect connections...................
94' Yota Last edited by RebelRider; 08-15-2009 at 03:04 PM. |
