Member # 87083
Which cam for mud truck?
Building a 327 which will be a 331 after its bored and Im stumped on which cam I wanna run. The motor is gonna run in the 450-500HP range so I need a big cam. I've sorta narrowed it down to two Comp cams one is the 292H Magnum with a .501 I&E lift and the other is the XE284H Xtreme Energy with a .507 Intake lift and .510 exhaust lift. What works best in a hardcore mud bog truck? Help me decide!!. Thanks.
1992 Dodge W250, CTD 5.9/Getrag/205/60/70. |
#2 (permalink) | |
Member # 71185
What heads, intake, carb , etc? Whats the expected rpm range? |
#3 (permalink) | |||
i hope you're ready to get beatin up over this, cause you're way way out to lunch with your specs, and what your using it for, example:
, you are going to be disappointed with a 302 for a motor (in any shape or form) for a mud bogger.
90' C350 AKA 4 door 1 ton Bronco 96' Ranger: kings, EMF parts, 800hp SBF |
#4 (permalink) | |
Member # 603
![]() The rest I agree with
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
#5 (permalink) | |
Certified E-Thug
Member # 117771
skip that, LQ9 + Heads + Cam = 450 - 500 HP and a reliable setup. You could build a nice LQ9 w/ harness for 5 grand all day long in the 450-500+ HP range.
#6 (permalink) | |
Meh i'm a ford guy and 331 is 302 stroker shit soooooooo
Member # 81909
okay if you figure 1.5hp per cubic inch thats 495, not as easy as to do as you think though. you do not need .600 lift. duraration and lsa is more important. pick a cam that will peak at about 7500 rpm. at least 300 degree duration cam. go with a 108 degree lsa and make it a solid. Also your gonna need about a 12 to 1 compresion ratio to work right with that cam. single plane intake and 750 cfm carb. 1 7/8 headers. If your tryin to race in a paticular class all of that changes, rules dictate your horspower.
Member # 17313
Skip the 302 based motor.. not enough stroke..
A 408 works pretty, but really, if you go to any mud bog, you will see why everyone runs a 460, or 460 stroker.. it's all about cubes..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 87083
OK my motor is as follows so far. 1967 327 .030 over, forged steel crank, machined for splayed 4 bolt mains, forged aluminum pistons. The compression is 12.8:1 w/64cc head or 10.7 w/76cc. I was planning on running highly modifyed vortecs or save up for a set of cast iron 200cc world products heads. I'll have a 3000 stall converter and the diffs have 4.56 gears and I have 38s. Oh and i have 750 holley feeding it. Hope this answers some questions
#12 (permalink) |
Member # 17313
oh... a SBC... well in that case, all you need is a RV cam, and chrome kit.. 500HP garanteed!! Don't forget to tell everyone it's out of a corvette! because every hillbilly mud truck has a corvette 350(or 327 in this case) :lol:
But serriously, If you want to hit that kind of numbers, neither of the heads your looking for are realy going to do it without a ton of work, spend the $$ for good aluminum heads. As was mentioned earlier, your cam specs are way, way small. If your serious about making the number, your going to probably be spinning near or above 7k with it. I'd also look into a bit looser of a convertor, with only a 3.25" stroke, and especialy with a 205 in there..
#13 (permalink) |
Member # 138463
I hope its a really light weight truck, like feather light. I ran a 351w for about 4 years in mud bogs before I stepped up to something bigger. I'll never go back to a small block again. Anything you can do to a sb, can be done to a bb for way more power.
As for cam, screw the hyd. cams, you'll never get enough rpm outta them. Go solid or solid roller, you have to check the lash on a regular basis (I check mine after every weekend) but for a mud racer, thats a very minor thing to do. I ran hyd. cams till they started bending valves on the pistons. Then it was time to step up and get the real deal. I'll never use a hyd. cam for a race motor ever again!! |
#14 (permalink) | |
Member # 603
#15 (permalink) |
Member # 135210
Come on guys.... The guys that run the horseshoe races down here will tell you different
YouTube - Double R mud track Sheridan arkansas 7-25-09 The first half of that vid is stock class till like 2min or something. Stock class rules state Hyd. cams ONLY, no strokers, no dome pistons, stock heads no porting, a ci limit of like 370 Which leaves you with a 350 or smaller in a Chevy. And they will jump my ass when I tell them they are not running by the rules. Watch the first few races in that class and tell me what you think
Chrome may not get ya home... But it sure will get ya laid!!! |
#16 (permalink) |
Member # 603
That's the gayest rule ever. They've already got a limit on the cubes, just leave it alone. As is, a guy could stick a 350 crank in a 327 block, which incidentally creates a ...........wait for it.........350. But, he'd be illegal since he "stroked" it
![]() And I wonder how much of that other stuff they actually check. ![]()
#17 (permalink) |
Member # 135210
Vacuum! Thats it! They dont even really look to see if the block has 3 freeze plug bosses. You have to pay to contest another driver But no one will do it because They know it will be them getting checked at the next race
Chrome may not get ya home... But it sure will get ya laid!!! Last edited by rock jeep; 08-20-2009 at 08:54 AM. |
#18 (permalink) |
Member # 127909
3000 stall wil not be enough look tward 5000 if this thing it going to see any racing, 4500 with any "good Solid lift cam. I ran a Comp in a 355
12-612-5 PN - Comp Grind # 300b-6 I'd recomend 12-609-5 Grind # 285b-6 These are not roller, but it is what I used on a budget a few years back when I started pit racing a big chevy. I had a 4500 stall and it worked well. be sure to run a manual valve body in the tranny so you can take advatage of the revs off the line |
#19 (permalink) |
Member # 87083
I do have a solid roller Crower cam for this motor with about a .540 lift but I dont know if I wanna run it just yet. I gotta send it to crower to get I.D. As far as gearing go I can always stick with stock 4.10s I just wanted to run the stronger V6 3rds. I'm gonna check out that 285b-6.
#20 (permalink) | |
Member # 603
#21 (permalink) | |
Member # 87083
#22 (permalink) | |
Member # 31228
go build a 366 tall deck BBC out of a school bus with some good 702 closed chamber 427 heads and see where it takes you
'68 scout 800, TPI 383/700r4 D44's '66 K20 383/400/205 60/14 '62 nova 406/th350. 11.40's @ 118 Last edited by Buckshot33; 08-29-2009 at 01:51 AM. |
#23 (permalink) |
Member # 135210
Why would you do that when you go to a big block you have to step up to a LWB 3/4 or 1 ton and then the limit is 477ci??? That was not my point. My point is the guys in the vid swear they are running 355s with hyd. cams. Thanks for nit pickin though
#24 (permalink) |
Member # 76809
You'll be fine with the 38's and 4.56's with a 205...exactly what i run in my truck. I would strongly encourage you to go with a lot looser stall.....something in the 4500-5000 range. Get that motor running on top from the start. Dont be afraid to go into the .600 range on cams and I wouldnt hesitate to try an 850 or 950 double pumper on it if you are savy with a holley. And with the 12.8:1 static compression you will be over the limits of a MSD 6AL. Make sure that you use an ignition that will sustain a spark under those conditions.
Hope this helps. |
#25 (permalink) | |
Member # 124760
Was at a race last night 2 SBC spanked all the Big blocks.( 1 being our SBC ) small block's are very snappy motors, if there built right !! Good day
