Proper R&P Selection - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 08-26-2009, 01:08 PM   #1 (permalink)
Member # 136485
Hi,
I have a 4cyl '97 TJ with stock std tranie and t-case. I'm swapping in HP44/9 to run 37's on and I'm wondering what gear ratio to run. I mostly play in the mud and I'm wondering if anyone has a similar setup or suggestions? This is my first Jeep 4cyl so I'm kind of lost...
Thanks
J_Impact is offline   Reply With Quote
Old 08-26-2009, 01:30 PM   #2 (permalink)
rock jeep's Avatar
Member # 135210
I am running a 44 and 9" and 37" boggers in the mud with 5.13s on a TJ But I have a 4.0. I mostly run 2nd and 3rd in low range and 1st-2nd in high depending on what I am doing. With a 4cyl and that set up I think you would be stuck with 1st in low. But I have never had a 4cyl. I have seen guys with 4cyls run similar setups w/ 4to1 in the t-case on the rocks but you are gonna need a lil more wheel speed than that. With you being way up past yankeeville in that thick mud you might wanna think big block
Chrome may not get ya home...
But it sure will get ya laid!!!
rock jeep is offline   Reply With Quote
Old 08-26-2009, 02:04 PM   #3 (permalink)
Member # 136485
Big block... one thing at a time Already planning that route, hence the 44/9 axle swap. If I can get away with running the 4cyl for 2 years and not pissing myself off then I'll be happy. I'm not a fan of 4 cyl but for the right price... It's any extremely good start.
Old 08-26-2009, 02:55 PM   #4 (permalink)
Member # 106427
I always say if it is worth gearing it is worth over gearing. A lot of people choose a gear that will match them with stock rpms at cruising speed. But bigger tires and wheels and more mass to get moving so I usually try to go a few steps above, if not alot. If you are in low and out of gear you are screwed. If you are over geared it seems like you can go up a gear easier than when you run out of them.
If you are worried about street manners then that is a different story, but in my eyes if you are building a truck with bigger than 33's gas mileage should be left behind.
http://nationaldrivetrain.com/Tech_pages/app_chart.html
I tend to use this as a reference for my set ups, and chose a gear in the yellow below the orange. But that is just me. Different strokes for different fokes.
later
jenks
jenks21 is offline   Reply With Quote
