Member # 91009
Which Tires to RUn: Newer 39.5s or worn 44s?
Here is my rig. An 84 CJ-7 with a mild SBC 350, T-176, D300, D60/FF14. I'm wanting to enter our next mud bog. Question is:
Run the 39.5s that are on it. Pretty good tread left or swap on my worn out 19.5x44x15s? More tread on the 39s = Good Taller tire of the 44s = Good. Also, what about tire pressure. I usually run <10 psi on the trails/rocks (beadlocks). What is better for the mud? Thanks.
Member # 603
Run the newer tires. Big, fat, bald tires aren't going to be of much use.
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
Member # 91009
With the D60 front and FF14 rear, the Jeep is heavier than most Jeeps. The land was recently cleared just for this event. I don't really know much about different types of mud, but the dirt is kind of a fine silt. With water added in, its fairly thick. This is up on the North Shore of Oahu. The 44s are mainly worn in the middle, maybe 1/4" tread left in the very middle, the middle and outter lugs are fine. Here is a 3 min. video showing the mud.
http://s7.photobucket.com/albums/y28...eiwaMudBog.flv Last edited by roadwarriorsvt; 09-10-2009 at 12:13 PM. |
Member # 141654
ahhh this is why i like automatics... gotta get the wheel speed up... that all depends on the HP of the engine and the gooyness of the mud... if you get 2 chances id try to leave in 2nd and try to get em spinnin.. if that dont work... prolly gonna have to stay in 1st.. usually tryin to change gears in a situation like that is a downward spiral
Without question run the 39s.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] |
#14 (permalink) |
Member # 56696
If you run the 44's real low on pressure the side lugs will bite in more. Shouldn't have that much problem turning half bald tires....you'll have two more inches of clearance too.
80 toyota p/u, 4.3 vortec, th350, dual cases, frt/rr 60's, 7.17's, 42 irocs, trail ready's,full hydro |
#15 (permalink) |
Member # 91009
Thats true. Good point. I'm looking for some old rims to mount the 44s on, then I'm gonna see if I can access the mud pit and make a run with both. If that doesn't pan out, I'll stick with the 39s.
