My 5 ton 79 bronco - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 03-21-2011, 09:23 PM   #101 (permalink)
lurchseesu's Avatar
Member # 112455
Originally Posted by Adamsoffroad View Post
but not sure about the coilovers yet. I broke one of them in fl at puddin creek.
What caused the breakage? Just old parts or too much truck for one shock per corner? Taurus used 2 per corner, correct?
lurchseesu is offline   Reply With Quote Quick reply to this message
Old 03-22-2011, 08:56 AM   #102 (permalink)
Member # 139700
probly the fact that they are 22yrs old and I didn't do anything to them other tha n add fluid and install them. lol
5 ton goodies.
Adamsoffroad is offline   Reply With Quote Quick reply to this message
Old 03-22-2011, 07:34 PM   #103 (permalink)
Member # 10736
Are the 50 spline u joint shafts forged or machined from a giant bar? Forging would save a lot of material but I wasn't aware that the market was big enough for the production.
masonmachines is offline   Reply With Quote Quick reply to this message
Old 03-23-2011, 09:54 PM   #104 (permalink)
Member # 139700
The first sets started as billet but he just spent the dough on forging dies and will be using new forgings very shortly to make them and yes it will save a whole lot of time. plus with the forgings he had them made so he can use the same ones to make just about any size and spline shaft you want be it a 5 ton or planetary or what ever.
5 ton goodies.
Old 03-23-2011, 10:20 PM   #105 (permalink)
cslimfu's Avatar
Member # 123458
So on the 50 spline shafts, rough price for stubs and inners and for a detroit? I do not even remotly need them now but, probably will in the future. It would be nice to have a idea on what to start puttin away.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote Quick reply to this message
Old 03-24-2011, 08:51 AM   #106 (permalink)
lurchseesu's Avatar
Member # 112455
Pricey according to his site.
"Featuring:
2 9/16" diameter 50 spline shaft
"Gearhart Engineering Exclusive" U joint
featuring 2 1/4" diameter bearing cap
$3,500 per kit with spool or $3,900 per kit with locker"
So x2 and you're looking at around 8k.
Just for comparison, on a 2.5t what does a set of violater shafts, ujoints, and ultralocker set you back from Ouverson? $3100ish an axle plus machine work?
Old 03-24-2011, 12:21 PM   #107 (permalink)
blown4x4's Avatar
Member # 43190
"Featuring:
This is off a price list I got from Ouverson last week
Front conversion kit $2350
Rear $1520
Add $800 to the front kit if you want gun drilled shafts and lockouts
Add $150 plus shipping if you want him to machine your carrier halfs
All this is a moot point to the the original poster. There is no way 2.5 tons would survive under that beast. One day I will have my own personal monster truck like his. LoL
1976 F-150 2.5tons locked disk braked 466bff ord doubler 44" boggers coil-overs air bumps etc
blown4x4 is offline   Reply With Quote Quick reply to this message
Old 03-24-2011, 02:49 PM   #108 (permalink)
lurchseesu's Avatar
Member # 112455
Yeah, the Gearhart stuff isn't too bad of a price considering. If you want to run 70+" tires, you gotta pay. Of course you could run PS250 or Clark planetary ends for half the price. But then you have the whole weight (turning a 1200 lbs. axle into a 2500 lbs axle) and hp sappage issue. If you're shooting for something (relatively) lightweight like Adam, then the Gearhart stuff is a logical choice.
Old 03-27-2011, 05:51 PM   #109 (permalink)
Member # 139700
hey if your finding clark stuff for half the price let me know cause I can make a killin after I sell them to the monster truck guys. lol
5 ton goodies.
Old 03-27-2011, 06:16 PM   #110 (permalink)
lurchseesu's Avatar
Member # 112455
Hit some of the junkyards around here. Clarks, Pettibones, Case, etc. Lifts, loaders, forklifts, etc. You'd be in heaven. All scrap price.
Old 03-27-2011, 06:51 PM   #111 (permalink)
Member # 139700
Then u better buyin. I can make you some good money off that stuff. It's all been scrapped up where I'm at and the stuff is gettin real rare.
5 ton goodies.
Old 04-03-2011, 10:08 PM   #112 (permalink)
tonka tester's Avatar
Member # 174484
lol, no... its all in your yard
tonka tester is offline   Reply With Quote Quick reply to this message
Old 04-07-2011, 11:02 AM   #113 (permalink)
Member # 139700
haha yeah true.
5 ton goodies.
Old 12-03-2011, 06:37 AM   #114 (permalink)
Member # 139700
lol Guess I should update this a little gettin way down in the pages.
5 ton goodies.
Old 12-03-2011, 06:38 AM   #115 (permalink)
Member # 139700
I'll put up some more pics tonight and somevids.
5 ton goodies.
Old 12-03-2011, 07:29 AM   #116 (permalink)
Member # 1724
Beyond badass!
four_by_ken is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 07:06 PM   #117 (permalink)
Member # 139700
lol I guess a rachet strap and a bungee wasn't enough to hold the hood down.
5 ton goodies.
Old 12-03-2011, 07:19 PM   #118 (permalink)
Member # 139700
Here are some pics of the new axles I'm preppin to go in it soon.
These are the kingpin supports Gearhart made for me these are some HD mofo's.
In this pic there is a helmet on the chunk but I'm not using it. My top bars will be parallel and hook to stands built on either side of the chunk.
Also next step is I'm building full steel plate knuckles to replace the cast steel factory ones. it'll also have dual steering rams and wheel tethers plus brand new 10.26 gearsets in the chunks. And I also have the HD 5ton spindles for on them also. They should be pretty tough when I'm done.
5 ton goodies.
Old 12-03-2011, 08:54 PM   #119 (permalink)
Member # 10736
Can anyone get the pictures to work on the last page? I want to see the goodies
Old 12-03-2011, 09:02 PM   #120 (permalink)
Member # 55444
I can see the pics. Kingpin braces look badass.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 09:18 PM   #121 (permalink)
Member # 123202
Originally Posted by spidr View Post
i can see the pics. Kingpin braces look badass.
x2!
mudevil is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 09:26 PM   #122 (permalink)
Member # 83657
Ya know my 5 ton 79 bronco needs to go. This thread needs to be renamed as ever red necks wet dream. I think that would be much more fitting.
brent460 is offline   Reply With Quote Quick reply to this message
Old 12-04-2011, 12:32 AM   #123 (permalink)
lurchseesu's Avatar
Member # 112455
I take it, it's getting some of these as well?
Old 12-04-2011, 05:49 AM   #124 (permalink)
Member # 139700
lol yeah those will be added too after the rest is finished.
5 ton goodies.
Old 12-04-2011, 06:35 AM   #125 (permalink)
Member # 83301
I have seen these in person, pic simply do not do it justice......these axles are awesome....
Adam you should post some pics of the toter for this thing.
'79 chevy k30 vortec 350/sm465/205/205/5.13's with big tars and toob
