Member # 121277
Gm 2.5 ton axles
Maybe this is a better section for this.....Im looking to see how good and durable gm 2.5 tons are, i found troop carrier with them in thats super cheap....helps appreciated.
i ran a set on 49" R1's with no breakage.
the front chunk spins backwords. you can either run the GM t-case, flip the chunk, or flip the housing. i chose to flip the housing, which gave me a drivers drop. 6.17 and 6.67 gears. the 6.17's should have stronger axles. i wouldn't pay more than $500 for a set. any more than that and you might as well go top loaders, where parts are much more common.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress. 88 YJ - 350, 1 tons, 40's |
Member # 121277
So if i flip the chunk ill still have passenger side drop like the older chevys..? Im thinking of putting them in and getting 15 inch wheels if thats possible and running 40s, then my 350 .040 450hp ... with the low gears can really spin em real good. The only thing about that is i still like to run it from mud bog to mud bog with out a trailer and i dont think these will work on the road...lol.....so i mite have to build my blazer with them...
HIGHLY CONTROVERSIAL
These axles are rare and so are the parts, but from what I've seen they seem to be super-stout. I know a guy that runs them and swears they are stronger than a toploader. Is there any truth to that, who know's? I must say he flogs the heck outta that thing with some decent power and hasn't broken a thing on some 50+" ags. There are a bunch of minesota rigs running them with lots of success too. They are also nice for a rear engine.
95 Chevy "THE JUGGERNAUT" 74.5x30.5x32s "cut" 16 ton's BIG Inch BBC PG 2-SCS's 4-Wheel Steering 14,000lbs 2008 GMC 3500HD CCLB SRW 6.6 LMM DURAMAX ALLISON EFI LIVE Pro Rock D60 |
Member # 112785
Not true,My brother ran a set on the street with 15" wheels and stock brakes.Granted the wheels had about 2" backspacing.He also cut the housings down and ran short axles on both sides |
Member # 20502
Both Boyce Equipment and Memphis have all the parts you could need. The brakes have dual cylinders and stop very well. I can lock up my 47s with ease. I know the brakes on my axles are to big for 15" wheels. Look at brake compared to the wheel in this pic, the brake has about 1 inch clearance of the wheel making the brakes about 18" in diameter. The axles came on M211s and M135s one of them may have smaller brakes. Boyce sells Detroit Lockers for them. Has anybody done Pinion brakes on theirs? I would like to see some.
If you flip just the 3rd member the short side axle need to be cut down about 3/4 of an inch to fit back in. There is about an 1 1/2 spline so its not to bad. You can do it with a grinder just take your time. I orginaly had the single speed transfercase from the 2.5 ton truck I found a 2 speed case from the 1.5 ton truck and it will be going in this winter. Last edited by jeepcj; 10-06-2009 at 05:02 AM. |
#10 (permalink) | |
Member # 55711
Oilfield Trash
Member # 64526
Pinion brake would be pretty easy to fab up, just make a bracket to bolt to the pinion support and use the pinion flange for the rotor just like a toploader pinion brake. Most of the strength issues that people have are because of the ball knuckle type joint instead of a u-joint, just like the toploaders with the non u-joint style shafts. Depending on how hard u beat on it and the horse power u are applying to it.
'91 k3500, 454, 4speed, 42" R-1's no lift '97 z-71, 3" BL, 38" tsl radial, 454/th400 '97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool, 34/10.50/16 ltb |
#12 (permalink) | |
Member # 20502
I know some of the FLA guys on Chucks Trucks have done it. But I have never seen how. I'll figure it out over the winter. The truck is a M715 with XLHs and a 427 tall deck stock. I do not plan on beating it to bad. I have the CJ5 for that. |
#13 (permalink) | |
Fullsize wheeler
Member # 83301
#14 (permalink) |
Member # 128152
The way the rear ends are set up...you just remove the cover and and switch drop -in to the other side (bolts all line up) you go from a high pinion to a low pinion like a 9-inch ford and this gets you the right rotation,and then it is easy to make it a crossover steer, by moving steering arm 90*. My truck had 4 wheel steering(two front ends, both narrowed) and the brakes on the front ends are (only) 16" drums. (the rear end had 19" drums) I had 2"back spacing and a short axle on both sides .
'74 ford,tube frame,rear eng,blown BBF,C-6,Profab, GM 2.5 ton front ,F106 rear, F/R lockers |
#15 (permalink) | |
Member # 121277
#17 (permalink) |
Member # 121277
Awesome looking rig...... a friend of mine is going to put them into his wrangler, soon(winter project). He wants to run 44s and i think they are going to take off the drums, narrow both axles and make brackets for pinion brakes so they can run 15 inch tires. A friend of mine is real good at fabbing up stuff like that so there all fired up to starting a new project, They said about welding up the rear set of spiders for now and seeing how it does. Also there is a guy close that makes driveshafts. The jeep has a mustang 5.0, 4spd and a 205.... It should be a pretty cool jeep when done, i should say whats left to the jeep....lol
#20 (permalink) | |
Member # 126764
83 k5 with typical rust |
#23 (permalink) | |
Member # 20502
Thanks |
