Radius arm tech for our boggers & dragger - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 11-05-2009, 10:27 AM   #1 (permalink)
Member # 41097
so the time is coming to start on the rebuilding of the race truck, starting with a new chassis (for a better frame mainly), with the main goals being a rollcage and getting rid of the leaf springs.
What i'm looking to build is a radius arm setup front and rear (like what the superduties run in terms of mounting points), and build them with high clearence as a main goal. But because this is a comp mud bog/drag truck i'd like to get some weight transfer, and get the ass end to squat, yeah i could go 4 link, but i want the truck to be as simple as possible, and the 4link add a fair bit of complexity to the rig, that and cost is the other big thing (hiems on all ends, 2.5x.5 tubing for links, cause i am going to beat it like it owes me money and the pansy ass shit i see a lot of guys running just will not cut the mustard).
So does any of the drag racers have any help here, since this just a modified ladder bar setup, i'm thinking it shouldn't be to bad, just something i haven't played with before.
The construction of the links will be done with some 2nps x.250 a106 smls pipe, which will be sleaved down the middle with some 2x1.5 x 3/16 rect. tubing down the middle to stiffen the hell out of it, without hopefully being no heavier than some 2.5x.5 link material, but a heck of a lot stronger. (i'm planning on hitting some tough truck style races, so i'm comprimising in weight in a few areas so it doesn't give me issues)
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
mustange70 is offline   Reply With Quote
Old 11-05-2009, 12:41 PM   #2 (permalink)
TEX
Member # 603
Ford style suspension works okay up front, but make sure you have enough shock damping to keep it from wheel-hopping in deep stuff.
Out back, truck arms (aka 2wd Chevy suspension from the mid 60's) is your best bet for the kind of suspension you desire.
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 11-07-2009, 05:03 PM   #3 (permalink)
Member # 130105
Why not just build your own beef Ladder bar setup....
"TO BE OLD AND WISE YOU MUST FIRST BE YOUNG AND STUPID"
Midget28 is offline   Reply With Quote
Old 11-07-2009, 07:29 PM   #4 (permalink)
Member # 41097
looking to do a few things with the truck i doubt i could do with a true ladder bar setup.
Thanks tex for the info, anyone have any geometry tips?
Old 11-08-2009, 08:32 AM   #5 (permalink)
mj
Member # 1919
simple math
each ladder bar/radius arm will need 3 bushings or rod ends, thats 6
the panhard needs 2 bushings or rod ends, thats 8
a triangulated 4 link needs 8 rod ends or bushings
a 3 link panhard needs 8 rod ends or bushings
a wishbone 3 link needs 7 rod ends or bushings
so what are you saving by choosing a ladder bar/radius arm ??
oh, and a radius arm is a "true ladder bar setup"
mj is offline   Reply With Quote
Old 11-08-2009, 12:23 PM   #6 (permalink)
Member # 41097
i already have a bushing source for next to nothing, so not to concerned there, a dual triangulated 4 link plows to much in the deep mud (which will be what the truck sees the most), and its easier to build high clearence in the radius arm/ladder bars or whatever you want to call it, plus i won't have to worry about a anti-sway bar, less mounting points to worry about, just simpler overall. I'm not going for max flex, that andsome place i race at have rules against 4 links vs. factory style suspension up front (and the the truck is a 82 f-150 )
