Heim Joint ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 11-17-2009, 07:03 PM   #1 (permalink)
notgonnamakeit's Avatar
Member # 83758
Send a message via AIM to notgonnamakeit Send a message via MSN to notgonnamakeit Send a message via Yahoo to notgonnamakeit
Heim Joint ?
Just wanting some opinions here, this is my first 4 link build. The truck is a Ford Ranger Splash with a 532 BBF, 2"X4" box tubing frame, Rockwells, Ballistic Coilovers, setting on 44" Boggers. The truck is going to serve duty mud racing, hill n hole racing, and most of it time fourwheeling. I'm going to run 1 1/4 heims for my lowers with 2" .250 wall DOM tubing. For my uppers I'm wanting some opinions on whether 1 1/4 heims are going to be overkill, should I run 7/8" or just spend the extra cash for the 1 1/4"s? Thanks, Jon
Mud Truck - 96 Ford Ranger-520BBF-Rockwells-14.9x28 R1's-14" FOA's
Mud Racer - 78 Ford F-150-466BBF-4.56's-spools-35" Boggers
Tow Rig - 02 Ford F-350-7.3PSD-Dynatrac 60-4.56's-37" M16's-20" XD Monsters
notgonnamakeit is offline   Reply With Quote
Old 11-17-2009, 09:50 PM   #2 (permalink)
Member # 139700
I would just use the same all the way around because then you need less spare parts and also the top bars will get the same forces as the bottom bars at different times so Better to stay the same the whole way around.
5 ton goodies. [url]http.adamsoffroadperformance.com[/url]
Adamsoffroad is offline   Reply With Quote
Old 11-18-2009, 04:52 AM   #3 (permalink)
Member # 146529
go with the bigger ones , you'll need them when buy a set of "v" tread tires
1forfun is offline   Reply With Quote
Old 11-18-2009, 07:23 AM   #4 (permalink)
Member # 109601
i ordered mine threw MC here on pirate. i talked to him about my setup (71' chevy truck, BBC, 54" mich/ setting up for v-treads, 2.5 rocks) and he said i would be fine with 1" shank, so me being the overkill king got the 1 1/4" shank and i could not be happier, and i should have no probs, these bitches are big and BEEFY. i always go big on parts; cause i never know what i'm gonna next........my 2 pennies
linky;
/forum/suspension/784568-bid-bad-forged-4130-rock-ends-joint-sale-free-misalignment-spacers.html
nvrsatisfied is offline   Reply With Quote
Old 11-18-2009, 07:53 PM   #5 (permalink)
Member # 83758
thanks for the imput , I was leaning towards the 1 1/4 to begin with just wanted some outside opinions
Old 11-18-2009, 09:24 PM   #6 (permalink)
Member # 41097
you'll bend those lowers in short time, i'd either step up the wall thickness or jump up in od.
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
mustange70 is offline   Reply With Quote
Old 11-19-2009, 07:09 AM   #7 (permalink)
HAWGWILD's Avatar
Member # 89954
HUH? Ive seen monster trucks run that size for years without problems.
JIM MACE
www.hawgwildmt.com
HAWGWILD is offline   Reply With Quote
Old 11-19-2009, 08:00 AM   #8 (permalink)
Member # 15354
Send a message via AIM to iniviate
i disagree.
my links are made from 2" schedule 80 pipe and they hold up to 62" tires and 5 tons.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is online now   Reply With Quote
Old 11-19-2009, 12:08 PM   #9 (permalink)
Member # 41097
2" sch. 80 is a larger OD than 2" tube (its 2 and 3/8), which will help out a bunch with the not bending that the regualar 2" may see.
Old 11-19-2009, 12:31 PM   #10 (permalink)
Xjcrawler736's Avatar
Member # 84970
Send a message via AIM to Xjcrawler736
Untrue, you will get much greater force on the lowers. Every time your tires smash into something the force directly goes into the lower due to there location at the center point of the axle. The uppers will get less force because they are on a higher point of the axle and are acting against the rotating force of the axle. Depending on if it is a double triangulated 4 link you will have similar forces side to side though.
Agreed. I would go with 1.5 " ID - 2.25 " OD .375" wall DOM.
In a lot of cases the monster trucks are using chromoly.
I can bend my stuff at will but I am bouncing my stuff off of rocks so that means nothing.
Andy~
RCrocs/Line Mt. - Route 63 Motorsports #736
Ultra4 #4343 Co-driver - Molten Motorsports
Xjcrawler736 is offline   Reply With Quote
Old 11-19-2009, 01:02 PM   #11 (permalink)
Member # 15354
good point...
Old 11-19-2009, 02:09 PM   #12 (permalink)
Member # 41097
Yeah i'm going to be using 2.5nps pipe (whatever sch. .250" thk works out to) sleved down the middle with some 3/16 rectuangular tubing to stiffen them up, yeah its a tad heavy, but i won't bend and i plan on beating it like a read headed step child.
And yeah monster trucks are usually using fairly high grades of link material, and they are stepping up the sizes of the link bars too (normal i've seen has been 2.5" od by 1/2" thick)
Old 11-22-2009, 01:48 PM   #13 (permalink)
HAWGWILD's Avatar
Member # 89954
I see a lot of my buddies sleeving thiers to make it stronger. I will probably do the same to mine eventually. I only know of a couple of guys using chomoly. Its just not used that much for monsters. Tom Meents is one of the few. Bigfoot used it for a couple of thier early tube chassis. For the amount of repair thats needed on a monster its just not a good platform.
JIM MACE
www.hawgwildmt.com
Old 11-22-2009, 04:17 PM   #14 (permalink)
Fullsize wheeler
pennsylvaniaboy's Avatar
Member # 83301
tractor supply sells great heims....even come with a nice connector bar between them so you dont lose them before they get installed
pennsylvaniaboy is offline   Reply With Quote
