#76 (permalink) | |
Member # 122354
#77 (permalink) |
FOMOCO MOFO
Member # 63730
Only on Pirate can we go from: Hey...check out these cool tires to.......radial vs. bias farm implement performance to.......tractor engineering by blacksmiths.....to "gay bashing" by a highly educated [asshat]
......to "Only on Pirate" in the MUD section. Some times the truth can truly be stranger than fiction. In a couple of weeks we'll find out how well they perform.
#78 (permalink) | |
Member # 80230
![]() LOL
#79 (permalink) |
Member # 40162
Be warned though- while there website shows a lot of good stuff, the last couple of times I have inquired about ags, they didnot have what I was wanting.
"Time you shut your cake-hole, YOKO!!!" |
#80 (permalink) |
Member # 117744
Pro,
I see you are planning on running the Ag's all the way around, and not just on the rear. Do you know anyone running 1 tons with these (18.4x16.1's) all the way around? I have read about the rigs on Alaska4x4network, but I am not sure they are quite so "throttle happy" as you! It seems that most people run them only on the rear for mud trucks utilizing 1 tons. I have talked to a couple guys from Florida about it, and they claim that the main hinderence on the D60 front is the knuckles, king pins/balljoints, and bearings/spindles. Either way, good luck! Problem is, if shit breaks, you won't know what caused it, the nasty new motor or the nasty new meats, haha! Last edited by EarthResin; 02-16-2010 at 08:57 PM. |
#81 (permalink) |
Archimedean
Thanks for the heads up. If I go the V-tread route it will likely be the 38's as shown on the toyota a page or two back...
Someone sort of local sell me a Dodge NP435, or the mainshaft/tailhousing from one. Or, sell me a Ford NP208 input gear... |
#82 (permalink) | |
Member # 80230
#83 (permalink) | |
At this point I'm more concerned about my intermediate shaft. I have it absolutely in phase and have never had any problems with it, but those ags and new motor will put a hell of a stress on everything.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] |
#84 (permalink) |
Member # 46318
When I still had my highboy, I twisted two intermediate shafts before I ever broke anything in the dana 60, but the front was open at that point. High RPM clutch drops both times...I then built my own d-shaft out of 1/4 wall tubing and never had a problem after that.
#85 (permalink) | |
Member # 47448
98 Durango - Rockwells, 4 wheel steer, 43x16.00R20 R4's |
#86 (permalink) | |
Member # 47448
I've seen the 48's on the highway, but damn the 66's...could you count the lugs as it rode by? Even at 70 they wouldn't be rolling that fast at all..
#87 (permalink) | |
Mah Negroes
Member # 101407
At work we build Terragators. Have you ever seen one of them bouncin down the road? Granted they are heavy as fuck, but damn, No way i would ever drive them on the road on a pickup. |
#88 (permalink) |
Member # 43251
I bought my Apple aka American Farmers from a local Farm tire dealer in Victoria Texas, they were about $400 each with $45 tubes, I ordered Marsh Raching wheels in 16 x16 with the centers unmounted so I could figure out backspacing on my truck. I had to drill my own intertube valve holes as they come undrilled, I used a 5/8 drill and chambered the hole so it would not cut a intertube or valvestem. The tires do grow like crazy when aired up, the 16 inch wide 16 inch wheel is easy to dismount and mount with the 16 wide width, the intertubes act like beadlocks and i have them with 25 psi. The tire V-tread design allows one to just float over most of the mud down here without having to rev up the motor to clean them out like the wannabee bogges r/tsl/nitro/buckshotss etc etc and really any street type mud tire, you dont need the big motor or lockers to run these, they are so much better than what most have experienced in mud tires its not funny, some day some of the tire makers will figure out there is a small niche for v tread DOT tires in a reasonable price, the XM- v treads are DOT and rated at 55mph and come on Unimogs, problem is they are only avail in 20 inch wheel widths. I paid $200 a wheel with centers from Marsh, I had to add hyda steering and 12 inch Alcan springs to get them to clear, am still building the truck. Tire size is 18.4x16.1x16 8 plys. Wish they were available in a shorter size as only way to run them is 2 cut or lift bunches. Mud life mag has a tire store in Florida@ sets of American Farmers with wheels for $2200 for 4, great deal, but the wheel is not wide enuff for me, I think peeps r runing them tubless with 2 narrow a wheel to fully experience the performance they offer.
#90 (permalink) |
Member # 146548
Dillo is right you dont need a big motor to run these tires, they float good even with my heavy ass truck. I have a stock 5.4L running these on my SD. Only upgrades to the stock 1 ton drivetrain is 5:38 gears, lockers F/R, Solid Axle hub conversion with drive flanges and 35 spline Chromo outer shafts on D60. Stock tie rod and drag link with drop pitman arm and Redneck Ram Hydro Assist.
I have been in plenty of holes with this thing and have not broke anything yet (knock on wood), except for a too short front driveline slip yoke, that is fixed now though. I have a RE 6.5" lift on the truck and did about 3" of trimming and put the flares on it. It works good, and up here in AK from what I have seen I am glad I picked an AG over a bogger or any other tire. BTW I have had this bitch up to about 55 MPH running down a road, she bounces a little but handles really good. Parts for these trucks are really comon up here, I have a complete set of spare front and rear axle shafts and steering assembly, that I got for free after the deal worked out. I plan to upgrade to Rockwells in the future and a 53" version of this same tire, but until I get a shop that is not happening because she fits in the garge right now by 1.5" ![]() I think you will like the rubber
04 F-250 45" Ags; 90 F-350 W/97 CTD 12V; 05 Ram 3500 CTD; 11 F150 Ecoboost |
#91 (permalink) | |
perfection
Member # 83634
i sold my 44 boggers and upgraded to a set of 18.4x16.1 firestones, got the idea from the ak rigs since there terrain seems to be alot like home here in the alberta mountains, and v treads are just bad ass
84 K30 tubed truggy, built 454,465,208, 60-14 5.13s, 18.4x16.1 tractor tires ![]() 93 gmc big block solid axle dually tow pig 95 f250 5speed 4x4 7.3 powerstroke tow rig, 5 inch pipe 71 international 1200 4x4 slow build 97 chevy solid axle 4x4 dd |
#92 (permalink) |
Archimedean
I don't necessarily want to find actual DOT v-treads. I just want to have some idea if certain brands have any heat/construction issues if they just happened to get used on pavemnt at higher speeds in an 'emergency' situation.
#93 (permalink) |
Member # 108046
I used to run one at my old job, the radials were much better than the old bias plys, especially in the morning. My machine had the bias plys on them and it would catch air in the front in the morning on a perfectly flat road.
#94 (permalink) | |
Member # 47448
#96 (permalink) | |
Member # 47448
#98 (permalink) | |
Mah Negroes
Member # 101407
I'm gonna say no. Atleast in Minn. Friend of mine owns a Tile buisness. He stripped an old Suburban. Put an old tractor cab and a couple reels of tile on the back. The Trooper wasn't too impressed to see that abortion flyin down the road at 65. He tried to register it differently, but was a no go. |
#99 (permalink) | |
Member # 108046
On the other hand, I've thought about getting an old Sammy or Sidekick and throw skid loader tires on it for a little run-around scouting vehicle, but its a little too big to throw a SMV sign on it and call it a ATV. |
#100 (permalink) |
Member # 43251
I have a W500 powerwagon and its 2 tons or so. It has a flatbed on it and i have had the same thought about Floation tires on it to drive on the hiway legally. We have a feed store coop down here and they have newer 2 ton trucks with those giant 45x20x20 tires on it and some have those 22.5 newer style floats on them as well, I dont see how if one stuck them on a reg and inspected truck and said you were going to your farm or ranch or really even drove it to a 4x4 meet or park they could legally stop you. I just see them with farm plates on them and I think those float tires are dot rated, but i am not sure??? Does anybody know about those giant floats if they are dot?
We have oil and gas exploration down here a lot on the coast of texas and in wetlands, sometimes the crew trucks come from LA with giant floats on them with like extreme low presure tires and no imprint type tires, but the truck is usually a 2 ton 4x4 with a flatbed so they can work during wet condition while laying sesmic cable, anybody in La ever see these rigs or around Houston Texas?? Seems to me there is some kind of a oil and gas conversion place around Houston that removes the factory fenders and builds the flatbeds so they can place those huge floats on them, it would be intersting to see what that place has in its junk pile or just to drive by and see what is offered, seems to me there had a website with huge terra tires piled up off of Hiway 6 somewhere, i lost the link but will go google terra tires and see if i can find it, maybe somebody else know about special terra floats and where they come from. The powerline company in Victoria buys about 5 sets on these a year when it used to rain according to my tire guy up the road, they run the smaler from terra float up front and the giant rear setup. Anybody work for a place like this or know of it?? I think Underworths in iowa builds the wheels for some of the terra floats for these type rigs?? |
