little Ford on 44's. build thread - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 03-02-2010, 04:14 PM   #1 (permalink)
FOURX4TRUX's Avatar
Member # 61228
Ive got a 95 f-350. i think i ended up somewhere around 15" of lift using a 8" superduty kit.
MECHANICALLY INCLINED......... I SCREW UP EVERYTHING
FOURX4TRUX is offline   Reply With Quote Quick reply to this message
Old 03-02-2010, 04:24 PM   #2 (permalink)
TEX
Member # 603
Do you wear a firesuit when you drive?
Thanks to:
Extreme Performance
Bear Creek Auto Recyclers
TEX is offline   Reply With Quote Quick reply to this message
Old 03-02-2010, 04:31 PM   #3 (permalink)
FOURX4TRUX's Avatar
Member # 61228
cheap way to get a front shaft in a lifted truck. that is the stock front shaft with no modifications, the rear will have to be lengthened.
Old 03-02-2010, 04:57 PM   #4 (permalink)
Jmudder79's Avatar
Member # 80273
Are you gonna put any bracing back to the frame on those front drops? Just to be on the safe side?
Jmudder79 is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 07:22 PM   #5 (permalink)
FOURX4TRUX's Avatar
Member # 61228
Gettin gears in her today. 5:38's and detroits front and rear.
Old 03-11-2010, 02:02 PM   #6 (permalink)
Member # 156058
thats the exact same as my truck, i did the same in the front. i havent got my drive shafts in yet but when you clocked the transfer case did you need anything special? i was told i may need a clocking ring? and did your rear end move ahead at all when you did the shackle flip? mine came ahead 3 inches.
wayfastwhitey187 is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 04:11 PM   #7 (permalink)
FOURX4TRUX's Avatar
Member # 61228
You will need a clocking ring, just buy one off ebay for dana 300. you have to buy metric bolts to assemble it. my axle did move, i just drilled the block to offset the difference.
Old 03-11-2010, 05:44 PM   #8 (permalink)
Member # 156058
why do you need the clocking ring? isnt the transfer case like a rim? you can put it on any way? how much did you drill your blocks?
Old 03-21-2010, 04:19 PM   #9 (permalink)
Member # 156131
nasty truck what size lift are those leaf springs?
combs136 is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 09:25 PM   #10 (permalink)
Member # 94248
read much?
Dick Hangin' Balls Dragin' Racing
craigbassett44 is offline   Reply With Quote Quick reply to this message
Old 06-04-2010, 06:02 PM   #11 (permalink)
FOURX4TRUX's Avatar
Member # 61228
Old 06-04-2010, 06:02 PM   #12 (permalink)
FOURX4TRUX's Avatar
Member # 61228
Next step.......Cummins
Old 06-04-2010, 07:17 PM   #13 (permalink)
Member # 41097
pansy . . . . . .
why don'tca run what real men run . . . .514(or bigger) with a 10-71 huffer sittin on top . . . . or a built stroker and 500 shot of the giggle gas . . . .
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
It'll only be bigger, better, & tougher next year
mustange70 is offline   Reply With Quote Quick reply to this message
Old 06-04-2010, 08:19 PM   #14 (permalink)
blown4x4's Avatar
Member # 43190
Originally Posted by mustange70 View Post
pansy . . . . . .
I agree.
I like your truck as well, it reminds me of the truck that I used to wheel in my sig
1976 F-150 2.5tons locked disk braked 466bff ord doubler 44" boggers coil-overs air bumps etc
blown4x4 is offline   Reply With Quote Quick reply to this message
Old 06-04-2010, 08:37 PM   #15 (permalink)
FOURX4TRUX's Avatar
Member # 61228
I allready have that in another truck..... check out some of my other posts.
Old 06-06-2010, 11:20 AM   #16 (permalink)
Member # 145385
fourx...what rear traction bars are you running? did you make them?
thanks
Rich
btw badass truck!
SoupCan is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 12:04 PM   #17 (permalink)
Member # 41097
Soo then you have an excuse to build something bigger . . . . .
Old 06-10-2010, 02:16 PM   #18 (permalink)
Member # 161465
This truck kicks ass....nothin' like a long bed flyin' high over a set of 44's! lol
-John
'81 K5: 10b/350/465/205/10b, 6" susp/2" body, rollin' on the BALDEST 39.5" Boggers on the planet...
GothRod is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 05:09 PM   #19 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
Fully gay. Anybody with a truck all jacked up like that has issues Starting with me! :blackgrin:
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, 46" Titan R1s. Evil social media page link:
Proeliator is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 06:35 PM   #20 (permalink)
Member # 41097
says yee of flaming jacked up truck gayness . . . . .
Old 06-10-2010, 06:54 PM   #21 (permalink)
88mitsu's Avatar
Member # 125523
black text owns all
which cummins are you putting in it
PRIMO VICTORIA!
88mitsu is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 08:27 PM   #22 (permalink)
Member # 41097
the bastard . . .
Lets hope he puts something in with a 10-71 on top, even if its a cummins, just imagine the looks lol, could probably find a couple big ass detroits to rob of parts lol.
Old 06-11-2010, 06:24 AM   #23 (permalink)
TEX
Member # 603
If it HAS to be a Cummins, at least do something cool like convert it to alcohol
Thanks to:
Extreme Performance
Old 06-12-2010, 09:24 PM   #24 (permalink)
Member # 86041
I boxed the frame horns on the inside all the way from the engine crossmember to the shackle reversal mounts. The frame likes to crack where the stock shackles bolt in. right where the frame folds in.
I also extended the spring mount past the front body mount to brace it up.
My spring mounts only drop 3 inches and i run 42's, yours has alot more leverage.
1994 F350 IDI Turbo Diesel, 43's, 4:88's, BW1356, ARB's F&R, Propane, 16.5 F Winch, 12K R Winch.
redstang410 is offline   Reply With Quote Quick reply to this message
Old 08-26-2010, 10:00 PM   #25 (permalink)
FOURX4TRUX's Avatar
Member # 61228
