S 10 Mud truck - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 12-16-2010, 02:20 PM   #1 (permalink)
Member # 159116
S 10 Mud truck
Im building an S10 to Mud bog with and cant decide if I want to use the S10 frame or a blazer frame. Moost of the guys around here use Blazer (K5) frames but the front tire location is too far forward in the wheelwell. I would prefer to use the S10 frame but am worried that it might not be strong enough. Anyone used an S10 frame? Opinions?
Jeromy is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 03:18 PM   #2 (permalink)
Member # 101407
Make your own/
Elvis38 is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 03:41 PM   #3 (permalink)
Member # 146906
You need to verify the rules where you plan on racing as the frame could dictate what class you run in. The s10 frame is plenty strong especially if braced properly. There s10 frame because it was ifs or 2wd whatever you got creates some problems. You have to cut out and make all new mounts for your suspension. Using the blazer frame is probably the easiest and less expensive way to go. If you can get away it I prefer a custom tube chassis.
Big Bad Wolf Racing is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 03:46 PM   #4 (permalink)
Member # 159116
I cant make my own per the rules.
Old 12-16-2010, 03:48 PM   #5 (permalink)
Member # 159116
Its a 2wd standard cab shortbed.
Old 12-16-2010, 03:52 PM   #6 (permalink)
TEX
Member # 603
Tim Huellinghoff had one of the best Super Stockers in Missouri that was an S15 2wd originally. He kept the S-10 frame. You don't save a ton of weight, but you do save some. Plus, it keeps the wheelbase correct and you don't have that huge gap under the bed. Tim's truck had an F150 Coil & Radius Arm setup up front BTW & a 488" BBC. He had to notch the frame a hair to make room for the underswept headers.
Thanks to:
Extreme Performance
Bear Creek Auto Recyclers
TEX is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 04:06 PM   #7 (permalink)
Member # 34281
Send a message via Yahoo to keller
I would actually put $ on the newer S10 frames being stronger than the old open Cchanel frame of the blazer.
the only reason they swap bodys over to the other frames is the ease of the leafs up front.
ot they allready had a truck and then swaped over to a s10 body.
Shop build
My buggy build
keller is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 06:12 PM   #8 (permalink)
Member # 163610
Agree
if u cant use a full tube chassis then stick with the S10 frame n save weight, we have a ranger on rockwells with 49's under it and that frame holds up.
and there is very little mods to that frame, so IMO use ur frame n build..
84 WILDFIRE CHEVY, ROCKWELLS, 4 linked,2.5x18 coilovers, full cage/under carriage, tall deck 427
D.J.Blazer is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 06:38 PM   #9 (permalink)
Member # 101407
Would have been useful info in your OP.
Old 12-16-2010, 06:56 PM   #10 (permalink)
Brent Foster's Avatar
Member # 127909
use the s-10 frame, much lighter.but you will have issues with the metal. that hydroformed stuff has thin spots. nothing to worrie about ,but you'll find a few when you weld. the rear frame rails are low for a proper 4-link.. can't get into it here but if you like I'll PM you my number and wecan chat about it. I also have some drag style 4-link designs that work real well for muddrags.
heres the last ride
http://www.facebook.com/photo.php?fb...066.1510812775
Brent Foster is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 07:03 PM   #11 (permalink)
Member # 15354
Send a message via AIM to iniviate
the S10 frame can bend right behind the cab, where it turns up.
it happened to mine and i've seen it happen to a couple of others. these are all 2.5 ton trucks though.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 01:07 PM   #12 (permalink)
Member # 166340
what axles come stock under the s10?
Elite13 is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 04:04 PM   #13 (permalink)
Member # 15354
junk...
10 bolt rear, ifs front...
Old 12-19-2010, 05:07 PM   #14 (permalink)
Member # 153965
this competition mud bogg truck (buddy of mines) is on a shortened K5 blazer frame with 3/4 ton axles...
georgiaboy2500HD is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 05:56 PM   #15 (permalink)
Member # 166340
what motor and tranny is he running? and tire size?
Old 12-21-2010, 01:05 PM   #16 (permalink)
Member # 161269
you will be just fine with the stock frame under there.. no pics, but 2 summers ago we built a 2wd s10 truck with a d44 and 14b with a 355 in it and a rear mount rad.... that truck was fun because it could still be driven on the road... unlike everything else we have built...
burnsy86 is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 04:09 PM   #17 (permalink)
Member # 26821
nothing wrong with thin, well designed, box chassis. If you are linking it, make sure to weld fish plates to the frame before you weld your link mounts straight to it. also make the ends of the fish plate < > not square and avoid sharp corners.
uninformed is offline   Reply With Quote Quick reply to this message
Old 01-26-2011, 11:02 PM   #18 (permalink)
Member # 181434
heres the only pic of mine i could find. s10 frame. mines bent. but the guy that put the axles under it before i got it didnt brace the frame right. Building a box tube/ tube frame this year
norris is offline   Reply With Quote Quick reply to this message
Old 01-27-2011, 06:12 AM   #19 (permalink)
Member # 127909
Was there a roll cage in these bent frames? I build an 1.5" .095 - .120, 12 point cage in all my s-10's. I've never bent one.
The new owner of the old orange one has put it through a beating that i didn't think it would take. As far as I know he bent the toyota front housing, but not the frame.
All my S-10's other than a new one I'm heloing a buddy build have been 4-linked though.... that may be the difference. This new one have a 9" and 44 leaf sprung, so we will see what it does.
Old 01-27-2011, 06:57 AM   #20 (permalink)
TEX
Member # 603
The Toy front housings are prone to do that if you don't truss 'em. Agreed on the cage comments. If you have a competition level cage, you're a lot less likely to tweak the frame.
Thanks to:
Extreme Performance
Old 05-15-2012, 09:28 PM   #21 (permalink)
Member # 172687
Send a message via AIM to joeydodgemuddin
any specs on how he choped the frame?
joeydodgemuddin is offline   Reply With Quote Quick reply to this message
