97 Dodge Ram Kansas Built - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 05-02-2012, 09:23 PM   #76 (permalink)
bigal1's Avatar
Member # 119174
FAWK YEAH !!!
bigal1 is offline   Reply With Quote
Old 05-02-2012, 09:25 PM   #77 (permalink)
Member # 152491
I am also changing the suspension up to a triangulated upper link bars and dual shocks all cormers
KansasKrawler is offline   Reply With Quote
Old 05-02-2012, 09:33 PM   #78 (permalink)
Member # 216755
So it probably isn't a huge deal since you'll be in mud, but with the 5 link you are running up front you will get some bump steer. The diagonal rod that locates the axle under the truck keeps the axle on the same vertical plane, whereas your steering rod is pivoting on a different plane, and pushing the axle toward the passenger side. What this means is that every time your suspension compresses, it will force the steering to push out. this is why on a lot of solid front axle trucks the pan hard bar and the steering link are ran parallel from the truck to the axle, to keep the bars in the same plane, which will keep the truck steady and minimize bump steer
I'm not giving you crap, just pointing out an issue. its an awesome truck, and super clean for a mud truck.
Question - Did you just weld the links up and throw them on, or did you set up any sort of angle to manage anti squat, etc?
ilovesoccermoms is offline   Reply With Quote
Old 05-02-2012, 09:55 PM   #79 (permalink)
Member # 15354
Send a message via AIM to iniviate
that's neat and all.... but this truck doesn't have a "steering link" or panhard bar.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote
Old 05-02-2012, 10:22 PM   #80 (permalink)
Member # 216755
yeah i saw he was trying to decide between full hydro (which would fix the issue I talked about) and a normal steering set up. I'm guessing he went with the hydro?
Old 05-03-2012, 04:03 AM   #81 (permalink)
Member # 152491
Yes i went with full hydro steering on the truck and had no bump steer issues when i ran it last time.
Also i am changing the suspension so there is not gonna be any 5th link bar. Its getting changed to what is common on most of the big mud trucks parallel lower links and triangulated uppers
Old 05-03-2012, 04:06 AM   #82 (permalink)
Member # 152491
Iniviate.. sir i must say you have a very sweet truck nicely built i have fallowed your build threads on several web forums. Wish i was closer to actually watch it run in person.
Old 05-03-2012, 08:02 AM   #83 (permalink)
Member # 15354
thanks!
Old 05-03-2012, 04:18 PM   #84 (permalink)
Member # 152491
You are welcome. Im gettin closer should have more pics up after this weekend the suspension is almost completed
Old 05-03-2012, 10:33 PM   #85 (permalink)
Member # 140846
So was there any problems with your original 5 link design? Why change to a triangulated 4 link instead of keeping the original design and just swapping the axles?
dragon250 is offline   Reply With Quote
Old 05-05-2012, 02:15 PM   #86 (permalink)
Member # 152491
Well made some more progress this morning Ol Red is back sitting on its own feet with new suspension design no 5 links now triangle uppers parallel lowers plain and simple. The link bars are carryin a degree angel of 15 top and bottom.
Front link bars
Rear link bars
Old 05-06-2012, 05:46 PM   #87 (permalink)
Member # 152491
Now i just gotta little bit to go then its mud slingin time
Old 05-12-2012, 01:34 PM   #88 (permalink)
Member # 152491
Well its getting closer now, Only things left are to put pinion brake on, hook up steering, top off fluids and MOUNT THESE BEASTS ON!
Old 05-12-2012, 03:25 PM   #89 (permalink)
Dueling Dodges
swirvin21's Avatar
Member # 116370
doesn't look like they are gonna fit! LOL.... Looks good otherwise!!!
1998 Dodge Ram 2500 Twins: 1 black, 1 white...
"The only thing necessary for the triumph of evil is for good men to do nothing." Ooh Rah!
USMC 2003-2009
swirvin21 is offline   Reply With Quote
Old 05-16-2012, 04:00 AM   #90 (permalink)
Member # 152491
The only reason i wanted to change the link bar design was to gain more seperation on the bars and to help compensate for the amount of weight that i gained due to axles and tires and the amount of bite that i will get from the tires. I have seen several trucks built that were running big tires like 30.5-32s or 35,5-32s and totally trashed out there suspension because they didnt have the right or enough seperation in the link bars
Old 05-16-2012, 04:02 AM   #91 (permalink)
Member # 152491
Thanks Swirvin i should have the tires on the truck this weekend ready to play so ill know forsure how much room i do have, I gotta go get a tire flipped around on the rim today only gonna cost me 50 bucks which is better then me breakin my back over it.
Old 05-16-2012, 06:00 PM   #92 (permalink)
Member # 10736
I think it is a good idea to get rid of the fifth link and use triangulated links, but if you want even more separation, double triangulated works better. Those tires look huge. I think this truck will be a beast.
masonmachines is offline   Reply With Quote
Old 05-24-2012, 08:53 PM   #93 (permalink)
Member # 152491
Well the new tires are on and truck is almost ready for the mud this weekend. I hope its deep and nasty the truck really needs a workout.
Old 05-24-2012, 09:58 PM   #94 (permalink)
bigal1's Avatar
Member # 119174
AWESOME !!! man that looks like fun,paint them wheels red it will look better.
I think your next upgrade will be more power lol
Old 05-25-2012, 06:13 AM   #95 (permalink)
Member # 209858
Your passenger rear tire is backwards.
Anyways great truck. Can't wait to see more pictures and vids.
02 Tacoma TRD 4wd, 01 4Runner 4wd Sport, 67 Mustang
just another broke wannabe.
mustangstephen is offline   Reply With Quote
Old 05-25-2012, 08:08 AM   #96 (permalink)
Dueling Dodges
swirvin21's Avatar
Member # 116370
Looking forward to the videos....
What size ram is that? Any issues turning those meats with a single ended ram? Any reason you're not going with a dual ended ram since you're in full hydro anyway?
USMC 2003-2009
Old 05-25-2012, 11:23 AM   #97 (permalink)
Rope Dude
Custom Splice's Avatar
Member # 122622
Where ya running this beast this weekend?
Todd
Custom Splice- AmSteel Blue Winch Ropes
We Stock - Safety Thimbles, Tube Thimbles and Excel Hooks
Office- 785 856 1844 Cell-580 504 1405
Need WINCH Rope? pirate4x4 is the secret code in the store for free shipping.
Have you seen APE EATER RACING's site
Custom Splice is offline   Reply With Quote
Old 05-25-2012, 09:21 PM   #98 (permalink)
Member # 152491
were running in elbing kansas on this saturday may 26th starts at 1
